Home Logo
Posted on Mar 20, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Walk in shower leak into room below
Walk in shower - 3 years old - leaks into room below after a long shower. New caulk did not solve problem. Poured 3 buckets of water down drain but did not cause leak. Leaks only when taking a shower. Where do I look for the problem without having to rip up the shower walls (vinyl) or the floor?
  • J P May 11, 2010
    Is this a tiled shower or a moulded plastic shower? If it is tiled, then the grout may be cracked maybe at the floor wall joint if your house is settling. You may need to strip caulk, buy a little $4 bag of grout and repair the grout.
    If this is a plastic molded unit, then where did you replace the caulk? The most common cause of shower leaks is because the installer did not caulk around the Hold/Cold lever(s). Splash 3 buckets of water against the hot /cold controls. If no leak here then there may be a crack in plastic somewhere. Is the shower against an outside wall in a very cold part of the country? Is there a warrantee on the shower if you bought it? Check with manufacturer. If no luck then call a good plumber.
  • Hannah Schroeder
    Hannah Schroeder Nov 09, 2017
    It's weird that adding new caulk didn't solve the leaking problem. My shower is leaking into the garage in the floor below, but I haven't tried caulking it yet. I might try that, but it might be faster for both of us to hire a plumber to take care of the problem.http://bodenplumbing.net/services
Tim Hunt
Level 2:
New Friend:
  • Expert 68 Answers
  • Posted on Nov 10, 2017
Tim Hunt
Expert
Level 2:
New Friend:
Answers
68
Questions
0
Helped
44609
Points
189
As a contractor i can tell you the shower pan has failed and has to be replace which means the ceramic or marble or what ever is on the walls at least 16" up to do so-you can install lower with some other color ceramic if you cant find exact match-its not something you can do unless you know how or a pro
Mike Zhu
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 07, 2016
Mike Zhu
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2178
Points
Water leaks into room below most likely is caused by water ingress from damaged caulking between tiles.
For big water leaks, better look for other root causes. For example, my walk-in shower room wall installed with 4 Hangsgrohe bodyspray heads (BODYSPRAY, AKTIVA, ITEM SKU: 28451821). These bodyspray shutoff valve is independent of shower head shutoff valve. So shower head works fine. But when bodyspray shutoff valve is turned on, water leaks heavily like waterfall into below living room. I cut out wet damaged sheetrock of the ceiling from the living room and found the leak was from one of the 4 spray heads. Overhauling the suspected bobyspray turned out its coupling was loose and nozzle holes was partially blocked by calcium buildup, which caused water to go back into the wall. It's considered design defect as the bobyspray coupling may lose once got whacked for whatever reason.
Thomas F. Schneider
Level 3:
  • Master 2,715 Answers
  • Posted on Mar 20, 2009
Thomas F. Schneider
Master
Level 3:
Answers
2715
Questions
Helped
1106216
Points
6961
I would unscrew shower head pipe and either pipe dope it or tefilon the threads and then reinstall it. I would also take the handle(s) rosettes off and look for a leak from there with a flashlight, while shower is on. I believe the most comon leak for walk in showers are the door seals. Are you sure it is not coming out from under the door? Another test that yuo may want to preform is to Stopper the drain, fill the shower pan with water and watch for bubbles, or look for leaks from below.
3answers
My tub is plastered into the wall with caulking. Recently, I have noticed that the caulking is dissapating and loosening up the tub. Fortunately, I have not see a change in my water flow. I want to
Unfortunately this is usually caused by a leak and the drywall is wet , and or the tub is sinking due to water damage to floor. If the drywall is solid then use a utility knife to remove old caulk, then after area is clean apply silicone caulk around the tub. apply neatly but with plenty enough to fill the void. I then spray a dish soap an water mixture on the calk then remove excess by pressing thumb down and sliding it long caulking. This presses it into the gap and also removes excess, which leaves you a neatly caulked tub.
Below Ground Exterior Wall Leak
Call b-dry are some one like that you have a problem with hydro pressure that is ground water is being forced to come up water will take the path of lest resistance . Had the same problem got it fixed several years ago and no problems sence.
1helpful
I'm insytalling new tile in shower should the frame of the shower doors be caulked?
Hello. Definitely yes. You want the tile, grout and caulk to be a semipermanent barrier for the water. If you do not caulk the frame, water will get in there and either leak or cause mold to form. Use a good quality silicon caulk, either clear, or white or a color that matches your grout lines. J.
Jul 28, 2010 • Home
Cast-iorn tub to fiberglass shower kit not sealing
keep caulking or change to ceramic tile, or one piece shower units ,without seams
Mar 03, 2010 • Home
2helpful
Caulk coming off in Corian stall shower
If you have the option of not using the shower for a while, I would put a dehumidifier in the shower to **** the mositure out from below. If cost is no object, you can go ahead and pull the base. The key to the caulk is to completely remove the old caulk, clean carefully and use a silicon based caulk. Be sure to let it dry properly (see caulk cure times on tube).
1helpful
Delta RP34357 Traditional Diverter Tub Spout has been leaking around base and/or water running along bottom of spout toward wall from opening; today, whole spout blew off wall when faucet was opened only...
If this spout is less than one year old, I would contact my general contractor to get his plumber over to look at it. Most GC's (general contractors) will warrant their work for one year. If it is not under warranty, you should be able to fix this problem. Spouts do not typically blow off like that, so I am wondering if there is not an underlying circumstance. At any rate, I will assume the best and tell you how to reinstall the spout. There are several variations on spouts, but the one that is most common is a slip connection. Meaning that the spout will slide over a 1/2" copper water line protruding about 3" from the tub. After sliding the spout on, there is an allen screw on the bottom of the spout that snugs up against the copper pipe (again this is the most common type of install). If yours is different, let me know, and I will walk you through other processes. Before sliding the spout back on the copper, use plumber's putty around the opening that the copper is sticking out of. This will help to prevent water from getting behind the tub. Also, after the install; check the spout to make sure there are not any leaks. If no leaks are detected, use a clear silicone tub/shower caulk and go around the faucet. The caulk does not have to be a 1/4" bead to be effective. Run it around the spout, and using a moist towel, go back over the caulk to remove the excess. If you have done it right, you will not even notice the caulk, except for the gaps. Hope this is helpful.
1helpful
Moen shower head leak
Single handle shower controls always have some water trapped inside. It has probably freeze damaged the cartridge
15helpful
Leak in the shower is leaking water through the ceiling
Hi lorenzotwalk,
I'm Harvey the Master Plumber.
Your problem is: When you use the shower, water leaks through the ceiling.
First, since it only leaks when you're using it you can ignore the water lines. Now comes the detective work. Look very closely at any place the water can squeeze thru, i.e. cracks in grout or caulk, etc. Don't forget to look on the floor imediately outside the shower and around the shower door if any. If found it must be scraped out, cleaned and dryed to get good adhesion, then caulked with a high quality silicone caulk (color of your choise). Any other caulk will crack no mater what they say.
Let dry for 24 hrs.
If you havent found this kind of problem it's time to look at the drain line connection. You may have to open the ceiling to do this, that's why I'm always carefull in the first step. Turn the water on and watch the drain connection. If it leaks there, it must be repaired. In this case you might cunsider checking the Repair Directory for a repairman.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 18, 2008 • Home
Top Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Home Expert? Answer questions, earn points and help others
