Question about IBM ThinkPad R52 Notebook
R52 onscreen display issues
Hi, I have a couple of issue with my R52. The battery charger icon ( the green battery ) is no longer visible. I used to see the volume increase / decrease icons whenever I press the volume keys. Fn+F7 used to show me the projector settings. This doesnt come up too. I dont see any display on my monitor when i press those buttons now.. Can someone please help ? Thanks a ton in advance.
  • IBM Master
  • 12,061 Answers
What ya need to do is enable the "system utilities" this is software that administrates all ya settings like those ya talking about.. below is a link for ya drivers etc. perhaps it is still in Control Panel and it;s just been disabled somehow.. else DL and install them. www-307.ibm.com/pc/support/site.wss/MIGR-58931.html
Posted on Aug 17, 2007
SOURCE:
My IBM Model 1847 no power
Probably your Power unit is bamaged. Get a new one and change it. If you are not sure how, call a tech service to do it.
Jan 24, 2014 | Lenovo IBM ThinkPad R52 1846, R52 1847,...
Hello my question? can i operate my IBM r52 thinkpad with out a battery? because the battery will not charge and the thinkpad will not operate with the power cable?
Remove the battery and connect the laptop with the charger and it should operate normally. However, in the absence of battery you won't be able to get backup.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 09, 2011 | IBM ThinkPad R52 Notebook
My IBM R52 laptop displays some vertical thin lines (red,green,blue,white,etc). I noticed this problem arises basically IBM R52 and R80 models. Some of my friends too are suffering from this problem and...
This sounds similar to a fault i had with an old dell laptop... very thin vertical lines running the length of the screen. Unfortunately it was an LCD problem, the screen was kaput replacing the screen solved the problem.
To test if it is an LCD fault, simply plug your laptop into an external monitor... if you get no lines on external monitor then its a faulty LCD screen.
Is that solution genuine enough for you?
Aug 27, 2010 | IBM ThinkPad R52 Notebook
How do I turn on the wireless switch on an IBM Think Pad R52?
Not all R52's have the bluetooth/wireless option. If yours has it, there will be a light for it located somewhere around the keyboard or the bottom of the screen.
To toggle the wireless on press Fn+F5 key combo, the corresponding led should illuminate.
If it doesn't turn on then check in Device Manager. If there any "unknown devices?" in device manager it might be worth getting these downloaded and running:
ThinkPad Power Management driver, OnScreen Display utility and Wireless device drivers.
Reagrds.
Feb 22, 2010 | IBM ThinkPad R52 Notebook
I cant find bluetooth on my IBM R52 laptop i have tried above solution but bluetooth is not shown on wireless radio
there is a configuration part in BIOS for bluetooth and an icon under the display. Is it possible that the laptop has not a bluetooth hardware.
Oct 25, 2009 | IBM ThinkPad R52 Notebook
Thinkpad R52 wirelss/audio issue after running windows repair.
1st update the chipset drivers & then update the audio & wireless drivers.
Aug 02, 2009 | IBM Lenovo ThinkPad R52 Motherboard -...
I need to activate my bluetooth in my IBM r52 model,how do i do
Press Fn+F5 to open the Wireless Radio Control and turn on the Integrated Bluetooth features.
Whenever you start the computer or resume operation after it has been in standby or hibernation mode, you must turn on the Bluetooth features.
Feb 23, 2009 | IBM ThinkPad R52 Notebook
R52 bios
usually bios updates, fixes compatibility and improves performance of some hardwares..
Latest bios or IBM R52 is ver 1.29
the difference of version 1.28 to 1.29 is - improves controlling of displayed screens with external monitor
to see all the changes from version 1.01 to 1.29 go to  http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-60768
Feb 01, 2009 | IBM ThinkPad R52 Notebook
IBM Thnink Pad R52 Shuts Down unexpectedly
it might be the battery, try plugging it in while doing that.
Jul 09, 2008 | IBM ThinkPad R52 Notebook
IBM ThinkPad R52 PC Notebook display problem
Hi , connect a external display monitor, re run your laptop, if same remove the battery and use the ac adaptor. if the same something wrong on your mainboard, check with your supplier.
Aug 15, 2007 | IBM ThinkPad R52 Notebook
IBM ThinkPad R52 Notebook Logo
187 people viewed this question
Top IBM Computers & Internet Experts
Ekse
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
