Question about Zebra Z4Mplus Label Printer
White lines on labels.
I'm getting white lines on the front end of each printed label and I'm wondering if the printhead is going bad. I can crank up the heat settings and it helps for awhile but then it starts again. Any ideas? Can the printhead be changed easily or does a technician have to be used?
  • ApexZebra Aug 17, 2007
    Looks like I can get a 300dpi printhead at several locations online for around $500. Hopefully it will be easy to replace.
  • 661 Answers
The thermal printheads can be replaced, all that is needed should be a Screwdriver. the problem that you will most likely have is finding a source for the replacement part
Posted on Aug 17, 2007
SOURCE:
Printer not Printing barcode label properly
best guess would be a thermal printhead has an element out and needs adjustment. However with out a model number and a picture of the printout that is the best I can do.
Aug 24, 2015 | Office Equipment & Supplies
Tip
Avoid buying a new thermal print head!!
Thermal printheads - white lines - - move your image!
Hi People,
I've been a printer engineer for many years now, before that i worked designing label formats and operating thermal transfer printers that produced over 2,500,000 labels daily. During my time operating thermal transfer printers I discovered that sometimes you can have a printhead that blows 1 pixel out, and no more will blow for 3 - 6 months! As sod's - law would have it, the blown pixel would be through a barcode or image, making the printer unuseable until the expensive (usually 300.00 - 1500.00 pounds) printhead has been changed. If you have many vertical white lines through your labels or tags, this might not work. Most makes of Thermal printers that have an LCD display will have margin settings and/ or image movement settings that you can change through the operator panel, you will have to consult your user manual. Simply move the image across the page until the white line caused by the blown printhead is in an unprinted area or sufficiently hidden between characters! In addition to this, if you are using software such as bartender, label matrix or similar, you should be able to edit the label image or label format on your Pc, and manipulate your label format in a matter of seconds, again moving or changing your data fields in a way that hides the offending white line between characters or in an unprinted area. I know this will not always work, but its worth a go as you could extend the life of your print head by upto 6 months.
By M.Schroder
on Apr 06, 2010 | Office Equipment & Supplies
Gaps in barcode with Zebra S4M
The gaps run in the direction of the label feed? You have a bad printhead. Bad dots on the printhead prevent it from printing your format in the areas that you see the blank lines.
There is no easy fix other than replacing the printhead. You can prevent (or actually prolong the time between failures) in the future by periodically cleaning your printhead. It's recommended that you clean the printhead after every roll of labels. The printhead is underneath the hinged assembly. Over time, ribbon or adhesive from the labels builds up and causes dots to go bad - creating the blank lines you see. Clean your new printhead with rubbing alcohol.
May 15, 2010 | Zebra S4M Thermal Label Printer
Hi There How do you print a test page from the Zebra printer itself which shows print head condition etc We've used teh self test print but are lookign for somethign more detailed etc. many thanks
Printing the "PAUSE" test will print a nice black box that will show white lines or voids for any printhead elements that are not functioning. Turn the printer off, press and hold the PAUSE key while turning on the printer. After 5-6 seconds, let go of PAUSE and let the power up self test finish.
The test label will starting printing. To stop, press PAUSE. This is also usefull for seeing the "parallelism" of the printhead by looking at the lines that print at the begining of each label. Should be the same number of lines on the left as the on the right.
Easiest way to cancel the pattern is to cycle power.
Hope that helps !
May 04, 2010 | Zebra 140XiIII Plus Thermal Label Printer
When I print my labels, there are lines that run through it
The lines(voids) are being caused by elements that are worn off the printhead. No energy is getting there to release the ribbon, causing a void area. To see the full extent, just create a label, using your widest label, that prints a thick black line. You will easily see the "void" areas as white lines.
This is common over time due to the constant contact with the ribbon. The elements wear down just like the tires on a car from the constant contact with the road.
The only way to correct is to install a new printhead.
Apr 28, 2010 | Zebra Z4Mplus Label Printer
The printer will print a bar code but the reader will not read it. the reader reads the bar code from a second printer just fine
Sounds like there are some elements worn off of the printhead causing some of the bars to not be printed. To test, create a label that prints a thick black line or solid black box across the width of the label (assuming a 4" label). Any vertical white lines that show indicate elements that are not functioning.
You could also put one label above the other, lining up the barcodes and you'll probably see bars that are missing from the label that won's scan.
The only ways to correct the problem are to install a new printhead or move the barcode field on the label so that the missing elements fall in the spaces between the bars.
Hope that helps !
Apr 08, 2010 | Zebra TLP 2844-Z Thermal Label Printer
All of the sudden my bar codes are not fully printing. Missing some lines on the bottom. Also the numbers are not printing rel clear. Have ran this label before and no problem. Now it is all bar codes.
Try cleaning the printhead, then print the zebra test print. (see user manual) or just print a solid black box 4" wide by 1" long. If you have white vertical lines through it you may need a new printhead.
If print test is good try increasing the heat/darkness setting
Nov 09, 2009 | Zebra 140XiIII Plus Thermal Label Printer
White vertical line runs through a shipping label
The problem is that the printhead is damaged and will have to be replaced. Assuming there are no other letters in the TLP2844 model number you gave then the part number for the printhead is G105910-053 and will cost around $100. Hope that helps.
Aug 26, 2009 | Zebra TLP 2844 Label Printer
Our Zebra 105se printer has started missing labels. For ex., it will be printing a batch of 40 and every third or fourth label it shoots out an empty. sometimes it puts out two empty labels but in the end...
Clean your platen roller. It's the white rubber roller (that turns and pulls your labels through your printer) located under your printhead. When this gets slick it causes your labels to slip while printing.
You should use rubbing alcohol to clean it. Your computer guys may also have some cleaning wipes in a foil packet that you can use.
Jul 13, 2009 | Zebra 105Se Thermal Printer
Printer Stripe S-500 Zebra
Question, when the printer prints is there an image of the data on the ribbon when it spools onto the ribbon takeup spool? If so, the ribbon may be installed backwards. I'm sure you know what you are doing but one must check even the smallest detail when trying to solve these strange problems. If the ribbon is installed correctly and there is no image of the data on the ribbon you may be dealing with a bad printhead and the printhead needs to be replaced.
Dec 19, 2007 | Zebra Stripe S500 Thermal Label Printer
Zebra Z4Mplus Label Printer Logo
223 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Gateway information...
Marvin
Marvin
Ekse
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
