Question about Sharp 14U-FM1 14" TV
Sharp Tv, can't tune in channels
Hi, My brother has just moved his tv to another room. He lost all his channels. Now everytime you try to tune it in the menu for tuning and sort a big green key comes up and it won't let you. How do I fix this?
  • Anonymous Jun 14, 2008
     can't tune in channels problem
    Problem Solver:
  • 18 Answers
Sounds like he accidently put it in parental lock, the remote should have the "key", the user instruction book will have the answer also. Hope this helps
Posted on Aug 17, 2007
6ya staff
SOURCE:
TV link not working with my LG 50PH660V 50-inch Widescreen 1080p Full HD 3D Smart Plasma TV with Freeview HD/600Hz. I connected coax cable to my Sky Box, switching on the RF on, but I can not get it w
Hi Jim, your nearly there, all you need to do is go into the tv menu and move from DTV to the old type channel numbers and then find the bit where you can manually tune the tv to channel 68.
Have a sky menu picture running and you will see it come in.
Feb 03, 2015 | LG Televison & Video
Cant tune channels
It sounds like you need to do a complete installation as if TV were new.
This is done from installation menu
Feb 14, 2014 | RCA Televison & Video
Auto tuning digital tv lcd Sharp LC-32LE345X
Maybe your Sharp TV wants you to go back to setup and go through the whole routine again.
Nov 21, 2013 | Sharp Televison & Video
Hi, I have an alba lcd32880hdf tv and moved tv to different part of room, when I turned the tv back on and did auto tune channels came back up except itv ones so went to retune again but tv then came up as...
The Tv is working fine, from the description it is that one channel not coming in, the blue screen indicates no signal. It could be that the signal in that room is a little weaker and just going below the thresh hold to allow it to come through. It is possible the station might have been off the air, try another auto tune.
Apr 08, 2012 | Televison & Video
Trying to tune tv but it will not tune in to channel 7s and channel 10s . Have tried auto and manual tune. suggestions?
Good day!!
Example Situation:
If you can get the first thirteen channels, then that proves there are no broken wires or damaged equipment between PVN and your room. Your cable - all 67 channels - has already been activated before you even move into your room. So, if you are only getting channels 2-13, you definitely have a programming problem with your television. We understand that your TV probably worked great last year or at home, but you have to set it up from square one when you move in to Penn again. Many times when you unplug a cable-ready TV, the memory settings are lost, and you have to start over. Therefore, you will need to program your set from the beginning.
If that situation happened to your TV please re-program your set.
Here is a link on how to re-program your Set.Just click the link bellow:
http://www.upenn.edu/video/setup/tsfaq.html#2-13
I hope your problem could be solve by this solution.Just add a comment for more query.Thank you!!
Aug 30, 2011 | Televison & Video
I cant tune in my tv its a sharp dv5103h abd i have lost the manual
Dear customer,
Sharp TVs often require you to press the TV Tuning preset key which is a yellow function key.
   Setting Up Your Sharp TV
Turn on your TV.
  1. On your Tune In remote, press TV and release.
  2. Press and hold Set until the green light on Tune In blinks once, pauses and then blinks twice. Now release the Set key.
  3. Enter the first three-digit TV code for your Sharp from the list which follows:
    093, 165, 039
    These codes are listed in order of popularity, and the green light will blink twice if you perform this procedure correctly.
  4. Aim Tune In at your TV and press Power. Your TV should turn off. If it does not, repeat steps 2-5, trying each code listed in step 4 until you find the one that operates your TV.
Now Test Your TVWhy test? Many times more than one code appears to work. Testing is desirable to be sure you have the correct code for your TV or the other devices you are setting up.
  1. Press the Power key to turn on the TV, then press mute, channel scan ("CH") and volume ("VOL") keys. Tune channels 7 and 11 by entering the number followed by the Enter key.
  2. If your TV does not pass the test, return to Step 2 at the top of this page. Enter the next three-digit code and repeat the process.
U can also refer to the following link for ordering manuals  http://www.aerialsandtv.com/tvservicemanualsmainpage.html
Plz rate this solution..
Apr 09, 2009 | Sharp Televison & Video
Sharp VCR vc-a41 tuning to TV
do you have cable? if yes both tv and vcr should be on ch #3 (to record).......ok no cable you are already set up look at tv right....just need to record..you need your vcr remote.....turn on vcr...press the menu...go to ch settings..auto scan will look for and lock in your channels...also make sure the air/cable selection is on air (unless connected to cable)....hope this helpful....feel free to rate
Oct 14, 2008 | Sharp VC-A410U VCR
Sharp LC-52D62U HDTV won't tune-in channel 21.
Sounds like the signal is probably too strong. The TV is not the problem.
Jan 16, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
SHARP TV CHANNEL LOCK
Probably the best way is to contact SHARP directly. The owner's manual can be downloaded from SHARP's homepage for free.
Sep 16, 2007 | Sharp 25L-S100 25" TV
Sharp 14U-FM1 14" TV Logo
1,015 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
