I plugged my tablet up to charge so i could use it later when me and my family went on a trip and normally when its charging its red and then turns green when its charged but not its just orange and wont turn on and i don't know why, its not been dropped hit or anything, please help because i don't understand what has happen... =[
SOURCE: Nextbook quad-core windows 8.1 tablet 2in1
Take it back, the more you delay the less chance they will help you or replace it.
Testimonial: "But I ordered it online"
SOURCE: Battery will charge to 100% only 50%
Its probably because of your tablets power source. If you have used your tablet very often then it will begin to cause the battery to drain more quickly and it will also not fully charge. It could also be a problem with your charger. There could be a short in it or something else that would cause it to stop charging the device at a certain point. The tablet isn't powered by a removable battery so don't try to open up the back and tear out any circuit that you think is the battery as this may cause even more damage to your tablet. If you have a warranty on the device then try taking it to the store you bought it from and see if they can help, but if you don't then be prepared to spend some cash. You could also take it to a tech store (if you know of one) and maybe they could run a diagnostic on the tablet to see what's wrong. If you're trying to charge your tablet while its turned on it could also be the amount of apps that you have installed on your device. Apps can actually cause put a strain on the battery and cause it to preform poorly. Try to avoid large apps (apps that take up a lot of space) because they can actually cause the device to run slower and it will also force more power to be drained from the battery which in turn will keep the battery from charging fully while its on. Try either one to see which one works for your device.
SOURCE: How can I remove the battery from Nextbook with windows 8.1 Tablet?
Hi
I have had a look at this problem and the best I can find is a webpage here:
http://www.freaktab.com/showthread.php?1303-NextBook-Next7S-Premium-Taken-Apart-with-Pictures!
which does tell you how to get at the battery. However, with its comments about breaking tabs which hold the case together when you take it apart, I'm not sure that I would attempt this. In any case, before you try this, plug the charger into the mains and see if you get a voltage at the tablet end of the charger, using a suitable multimeter, set to a suitable range. If you don't get a voltage here, you need to replace the charger.
I hope this all helps, and just in case you haven't got a manual, you can download one here and save it for future reference:
http://www.nextbookusa.com/pdfs/NEXT5_Manual.pdf
Cheers
Mike
