Question about RCA F27650 27" TV
TV keeps turnig itself on....Sony kv-27fs12
I just was given this tv to me by a friend, and every mornig it turns itself on. I checked to see if the timers were set, they are not. Not sure why this is doing it. It happens about the same time every mornig. Thanks
  • 1 more comment
  • kp33 Aug 17, 2007
    Do you mean there is a problem with the remote or something inside the unit. When I got the tv there was no remote so I ordered one, do you think there could be something wrong with the remote triggering it to turn on. I will say this, last night I put the remote in the drawer when I was done with it, I didn't think the remote could send a signal to the tv from inside a drawer, but the tv still turned on...........thanks
  • kp33 Aug 18, 2007
    this is wierd as well, it only happens when I set the sleep timer, last night I did not set the sleep timer, and the tv did not turn on byitself.....
  • kp33 Aug 18, 2007
    any reason why it happens only when I set the sleep timer?
    Problem Solver:
  • 16 Answers
There is a problem with its remote timer circuit., it needs to be repaired by a technician.
Posted on Aug 16, 2007
  • Dhaval Patel
    Dhaval Patel Aug 18, 2007
    i dont say that remote is bad. i m saying that the circuit inside the tv which operates the remote has a crystal inside it. if the crystal is bad it may respond such wierdly.
    a tv technician will soon fix it. by changing the remote circuit ic inside tthe tv.
  • Dhaval Patel
    Why did not u rate my reply
    i m helpin g u only to get rated ok now rate the reply
I have a Sony kv-27fs12 the picture go out but you still can hear it and the standby light turns on first it flash 5 times then stop and do it again now flash continuously please if you know let me kn
Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective. If you want to know more about the blinking codes to Sony Brand TVs, check this link.
Jan 14, 2013 | Sony KV-27FS12 27" TV
When i try to turn on my sony kv-27fs12 keep turn off and blink 4 time a red led make a pause and keep blinking 4 times, what that could be?
Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
Vertical sweep failure. Check all the solder terminals to vertical output IC. If it do not help, replace that IC.
Jul 03, 2012 | Sony KV-27FS12 27" TV
No Power Sony KV-27FS12
IF the unit is completely dead (no standby light at all) then teh main fuse is most likely open. Try replacing that first. If the stnadby light is on, then when you attempt to turn it on, the light shouild blink. If so, the blinking should be a repeated count with a short pause between sequences. Post that count here as it will indicate what circuit has the problem. We will continue from there.
Thanks,
Dan
Feb 11, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Sony Trinitron turns on in the middle of the night for no reason
maybe the people next door have a powerful remote, and when they turn their tv off a night it turns yours on?
Dec 11, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Tv remote sensor gone crazy
bad switches behind front control buttons
Oct 27, 2008 | Sony KV-27FS12 27" TV
Weird sound coming from the inside
TV needs some kind of service and dust inside to be removed.
Regarding sparks sound, it can be leakage of high voltage of Fly-back Transformer. Qualified tv technician can check and repair it as high voltage risk is involved here.
Thank you.
Sep 23, 2008 | Sony KV-27FS12 27" TV
Moved tv from 1 location to another
hi there, it may need some fine tune for the sony kv-27fs12 to be connected directly to cable jack wall. do some test. ty
Jan 10, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
KV-27FS12
hi there, there is a problem at your power supply section. do some test, it maybe a electronic part faillure. ty
Dec 28, 2007 | Sony FD Trinitron WEGA KV-27FS120 27" TV
PICTURE TROUBLE ON SONY TV ..KV-27FS12
most sony tubes bow in the corners, they just arent built that well
Apr 11, 2006 | Sony KV-27FS12 27" TV
Open Questions:
Letterboxing: The top and bottom of the screen are cut off I originally obtained this TV from my Bro who passed away from cancer at age 31 a few years ago & I was never able to find out what he did with the manual. However, I was able to find a manual online but after viewing it, I still wasn't able to find the info. that I am trying to obtain for the correct settings to get rid of these black margins at the top & bottom of the screen. I am trying to find out what video output format is supported by this TV model, as far as the resolution and output format, specifically for a Cisco or AKA Scientific Atlanta 500GB HD-DVR through Cox cable? My available settings with Cox cable & the DVR I have( Cisco or Scientific Atlanta 500GB model)are the following-Resolution:480i, with output format of either:Zoom 16:9 Pic or Letterbox 16:9 Resolution:480p standard, with output format of either:Zoom 16:9 Pic. or Letterbox 16:9 Resolution:480wide, with either output format of:Stretch 4:3 Pic, Preserve 4:3 Pic or Sidebar 4:3 Pic Resolution:720p wide, with output format of:Stretch 4:3 Pic, Preserve 4:3 Pic or Sidebar 4:3 Pic and finally, resolution:1080i wide with output format of:Stretch 4.3 Pic, Preserve 4:3 Pic or Sidebar 4:3 Pic? Everything worked fine with the screen size when I had a 160GB Motorola HD-DVR with Cox under the video output settings of:resolution:480i and video output of:Zoom 16:9 Pic until, I grew tired of constantly running out of space & had them switch me to a 500GB HD-DVR. They were supposed to install another Motorola HD-DVR but just with 500GB version but when the Cox maintenance employee showed up to swap them out and install the 500GD HD-DVR, he only had a Cisco/Scientific Atlanta 500GB available on his truck, which is I guess what they use for the Contour service but he attached a filter to the back of the coxial cable to make it a regular HD-DVR without Contour(even though they tried charging me extra for contour for 3 months before I finally got that straightened out since the maintenance workers & billing dept. are often not on the same page as I found out at Cox. I have tried calling Cox for support & they say that I need to find out & know my TV's video output settings. I explained to them that it worked perfectly fine just weeks ago with 480i resolution and output format of Zoom 16.9 Pic before they switched to the Cisco/Scientific Atlanta HD-DVR from the Motorola DVR and that I didn't have the manual and I stated why and they basically said, too bad, figure it out yourself. Can someone please help me out? I have the TV set up for the correct zip code, cable box-Yes, the cable box output channel-video 1/Aux (since that is what the TV manual I read online said to use if you are using the 3-color coded cables instead of the coxial cables to plug in from the TV to the HD-DVR) & I have the Cable box remote control code set to code 008 (Scientific Atlanta) that I verified to be correct by checking it through the TV's automated code search. The serial # for the TV is:C306B2084 and the Chassis # is:ATC113BB1 and its the 27" RCA Entertainment Series Guide Plus Gold Gemstar that is X-Box ready. Thanks so much, Todd
Feb 26, 2017 | RCA F27650 27" TV
RCA F27650 27" TV Logo
41 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
