My Pentair 250 minimax pool heater will not stay lit. I light the pilot and the burners will all go on, but 2-4 minutes later everything will be off. Any help would be great, thanks.
SOURCE: My pentair minimax plus 250 M pool heater won't
For most pool heaters, if they will not start up in the spring, the problem is corrosion in the wiring somewhere... I would remove and clean all wiring connections and then try. The amount of current is very small and so any bit of corrosion can cause the unit not to work.
It all so could the t-stat again, but you would need to check that with an OHM meter. No continuity when the heater should be on will confirm that the t-stat is bad...
heatman101
