Question about Canon LaserClass LC 8500 Plain Paper Fax
How to change the sender's info
We recently taken over another office's fax machine but did not get the manual. When we send out a fax it still shows the old office's address info and we want to change it to ours.....any help out there ?
  • 59 Answers
Lift the panels on the keyboard. press data registration and press set. press set again and use the down key to scroll user name and set and press the clear button and you can enter the new name by using the numericals keys corresponding on the alphabet like your cell phone. when finished press set and press the down arrow to tel number and press set. press clear and enter your fax number. and press set when finished and press stop.
Posted on Aug 18, 2007
Sending fax displays comm.error
There are many things that can interfere with proper sending of faxes. Has anything changed in your office recently? Phones changed? Did you recently get DSL service from your phone provider? If so, you probably need a DSL filter on the line going to your fax machine. Try faxing to different faxes to make sure that it is not the person you are sending to that has the problem. If you are using Voice Over IP or VOIP phone, good luck, as older fax modems do not always play nice and you will likley need to speak with your VOIP provider to ensure they have their lines configured. If nothing has changed in your office then perhaps your modem has just failed, it does happen. A new cord between the jack and the machine is a a cheap test as well. If you have a telephone, unplug the fax and plug in the phone and see if you can make a call.
Sep 04, 2014 | HP LaserJet 2840 All-In-One Printer
We have a FAX-2820. this is a dumb question, but does the fax header line come from the sender when we are receiving the fax? Does a header go out on any fax we would send out?
Yes, The fax header should show you who sent the fax to you. Every fax is supposed to have a terminal ID (senders fax number and Name)
Andrew
Sep 22, 2011 | Brother IntelliFax-2820 Laser Fax
We switch phone carrier and our fax number was also change, but everytime we send any fax to somebody our old fax machine number shows. So, how to remove the old number and let the new fax number printed...
If you are able to access the fax menu, you should be able to change a number of parameters including the number display of the sender. Good luck.
Dec 22, 2010 | Garden
Program sending address on brother mfc-6800
The settings should be able to be changed one of two ways. Either under fax settings on the printers menu, or under fax settings under the printer properties panel on the computer.
Mar 10, 2009 | Brother MFC 6800 All-In-One Laser Printer
Got new hp elite m9402f computer but new hp fax doesnt answer
hi there,
initially you have to check and correct this few settings.
To receive a fax manually
1. Make sure the device is turned on and you have paper loaded in the main tray.
2. Remove any originals from the document feeder tray.
3. Set the Rings to Answer setting to a high number to allow you to answer the
incoming call before the device answers. Or, turn off the Auto Answer setting so
that the device does not automatically answer incoming calls.
4. If you are currently on the phone with the sender, instruct the sender to press Start on their fax machine.
5. When you hear fax tones from a sending fax machine, do the following:
a. Press the left arrow or the right arrow to select Fax B&W or Color fax.
b. Press Start.
c. After the device begins to receive the fax, you can hang up the phone or remain on the line. The phone line is silent during fax transmission.
Hope this initial info helps you.
micromaster-
Jan 19, 2009 | HP J4680 Office Jet All-In-One Printer
I have never had a problem with my fax machine until recently. All of a sudden, the machine rings and rings when a fax is trying to come in; it will show call pickup; to receive the fax, I have to pick up...
The machine has probably been taken off of auto-answer. You can download the manual from Brother's website here:
http://www.brother-usa.com/manuals/default.aspx?ProductID=PPF2800&ProductGroupID=2&WT.cg_n=Support&WT.cg_s=Manuals
Then you can verify it's set up properly. If the problem is due to some failure in the fax machine (always possible) you can find service options on Brother's site as well.
Dec 16, 2008 | Brother IntelliFAX 2800 Laser Fax
Fax will only send and not receive
Call your fax machine from a regular phone and listen for fax tones. Sender may be dialing the wrong number. Is your phone line DSL?
Sep 05, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
Incoming fax
Do you have the manual? Check your smart ring feature.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Sep 05, 2007 | Brother IntelliFAX 2800 Laser Fax
Sender Id
Sender ID ecblank.gif ecblank.gif dot.gif ecblank.gif This is a descriptive title that identifies the sender -- usually the location of your fax machine or the name of your company or office. It is printed at the top of every fax you send. You can enter up to 32 characters. The first 16 characters will also be used as your Personal ID, which may appear on the displays or reports of other fax machines you are communicating with
Setting the TSI/CSI and Sender ID ecblank.gif ecblank.gif dot.gif ecblank.gif1 Press Menu/Exit to enter the menu.
2 Input speed access number 02. 3 Input up to 20 numbers and characters (0-9/Hyphen/ Space/+), press Enter. 4 Press Menu/Exit.
Sep 27, 2006 | OKIFAX 5950 Plain Paper LED Fax
Canon LaserClass LC 8500 Plain Paper Fax Logo
110 people viewed this question
old marine
old marine
