Question about LG Electronic Window Air Conditioner
Fan making loud noise like it needs oiled
Last night the a/c started making a loud noise. Sounds like when a fan needs cleaned and/or oiled. Filter has been cleaned and everything else works fine. We turned it off until we know what the problem is and how to fix it but the temp outside today is 102. HELP!
  • CindyR Aug 22, 2007
    Thanks for your help! I'll try that tonight. Haven't had a chance yet. We were going to pull it out and see what it looked like anyway. Now we know what to look for. :)
  • 50 Answers
Most of the fan motors can be oiled. You will have the slide the ac forward and remove it from the case to access it. You will find yellow pull pins on each end of the motor, a lite drop or two is all that is needed.
Posted on Aug 18, 2007
What could it be when i excellurated i heard a loud noise an oil started leaking under the van and smoking making loud nocking noise
Sounds like big end bearing gone and oil would probably be coming from gear box and engine seam and falling on exhaust its sounds like a pretty stuffed motor but everything is fixable depending on how much coin it coast and if its worth it cya Neil
Jul 18, 2014 | 2002 Ford Windstar Cargo
Last night, the freezer door on my older GE Profile fridge got left slightly open. This morning, it was making a loud noise and some of the food inside was starting to thaw. I turned it off for awhile...
The door being left open would have caused frost to form around the evaporator fan motor and that would be the source of your noise.
If the lights are still working then it is probable in defrost, wait about 30-45 min and see if it turns back on. If not then you might have a different problem.
What is the model number for your fridge? The model number is normally in the fridge on the right hand side.
Mar 13, 2013 | Refrigerators
Engine making loud sound when attempting to start.
Diesel or Petrol?
Any warning lights on on the dash?
Oil pump working ok?
Check your timing belt?
Dec 04, 2012 | Cars & Trucks
My samsung fridge/freezer is only 3 years old, just started making loud noise, then when the fridge is opened sounds like the fan making a loud noise that goes down and stops. Then not long after that...
Compressors usually make a thrumming/humming noise, so yes, this sounds like the fan. It could be something touching the fan blades, like ice or a wire. If you can unplug the fridge and remove panels near the fan, you may discover the problem.
Jun 06, 2012 | Refrigerators
My fridge - model RS583HDP started making a noise in the fridge section a few days ago, like the fan was working quite loudly and every time you openned the fridge section, the fan slowed right down and...
try to lubricate or replace bushing of your evaporator fan maybe it has awear in tear that fan hard to rotate this can cause a noise and poor circulation of air cause of temp. rise
Feb 13, 2011 | Samsung Refrigerators
I have a Dell inspiron 1525...I have found that now, after a year and half the fan has become loud and noise. So noise, I wake up in the middle of the night, hearing my computer cooling b/c the fan is so...
you need to buy a new fan, your fan is about to give up the ghost. if you let the fan die while the pc is running, it might burn out the cpu.
fans are very cheap, like a few dollars, and do not always last forever.
Nov 06, 2010 | Dell (6F858) Cooling Fan
My whole house fan froze up last night..it hums
Call a professional it sounds like your squirrel cage fan has lost a bearing or broken a support component.
Jul 08, 2009 | Dryers
LG Electronic Window Air Conditioner Logo
562 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
