Question about NexxTech Portable Hi-Speed USB 2.0 Kit Hard Drive
Cannot access files
After using the external unit for backup for about a year - suddenly I get a "Please insert disk into drive" message. I cannot read my external at all - it shows as empty.
  • dee55 Aug 16, 2007
    It didn't help. I am still getting the insert disk message Thanks for the quick answer.
  • Anonymous Dec 27, 2007
    i have the nexxtech portable hi-speed usb hard drive kit. Vista no longer recognizes it. how can i get Vista to recognize so i can open. it says i have disc drives connected.
    Problem Solver:
  • 16 Answers
Try starting the pc with the unit plugged in. then after the pc is completely started and the desktop is set then directly restart it manually (not by cliking on restart) then allow to scandisk all the drives, do not remove the external unit. it will alos scan and may be the file system problem will be gone. and u will get ur data. if not success then tellme. i will give u another guarranteed suggestion,. ok.
Posted on Aug 16, 2007
  • Dhaval Patel
    Dhaval Patel Aug 18, 2007
    did u get scandisk after restarting
    did you external did scaned
    just try once more
    then
    do
    this
    download any data recovery soft from internet and recover your data back
    but timebeing do not copy paste any data on your hdd as it would overwrite uir previous data
    ok
    send me ur reply thx
SOURCE:
Given that defragmentation is not possible and wav file creation is not an option due to hdd full warning,I can't save songs. I'm looking at loosing years of irreplaceable work. Please help.
i suggest getting a flash drive for a quick transfer of files to that so you can clear up space or getting an external hard drive to use as mass storage theres also using an online backup such as onedrive dropbox etc
May 13, 2017 | Option Computers & Internet
Tip
How back up your files (data) before doing system restore
<p>1. Use of pre-installed backup tools. Many computers have a backup software installed when you buy (including Time Machine backup and restore for Mac or Windows). These tools are designed to transfer files to various media they create on the computer hard drive or external hard drive, you can prevent a total loss of data is performed. When you open the utility, follow the onscreen instructions to complete the backup. <br /> <p><br /> <p>2. Back up important files on a USB stick or Memory Stick. Insert the stick into a USB port on your computer. Drag the selected files to the disk icon on the desktop (Mac) or PC (Windows) will appear. Flash drives and memory sticks are very mobile and can be stored in small spaces such as basements. Although they generally do not have a capacity of more than a few gigabytes (GB), they are large enough to store your important files. <br /> <p><br /> <p>3. Enter an external hard drive. These external hard drives usually have a very large capacity and can therefore keep most or all files on a disk. Connect the external hard drive via a USB port. You can drag and drop files on your hard disk or use it as a means of backup using a backup utility installed. <br /> <p><br /> <p>4. Burn your important files on a CD-R or DVD-R. an entire hard disk backup can be many slices, so this option is ideal if you want large media files or documents for easy access later. Insert the CD into the CD-ROM and follow the instructions on the screen (for Windows and Mac) to back up and store files. <br /> <p><br /> <p>5. Upload files for storage in the cloud. Services in the Internet cloud storage (like Mozy and drop-down box) are great ways to backup files to the internet access from any Internet enabled device. Important files with sensitive information may only be attached to a back-up cloud services such as Mozy. Clouds, Drop box is ideal for backing up photos, videos and other files less sensitive.<br />
on Jun 21, 2011 | Computers & Internet
E:\ is not accessible The disk structure is
This is usually an external drive - if you are trying to run from a cd/dvd, make sure you are selecting the correct drive. If you are operating from a "jump" drive, also known as a "flash" drive, this is usually caused by removing the external drive while it is being used (when files are currenlty accessed) and the drive file has not been closed before removing or shutting down the computer. Unfortunately, this is unrecoverable at this point, and you will possibly need to format the drive (external, not internal hard drive) - first, however with the drive inserted, go to the "computer" file (under start menu) and right click on the drive - select "safely remove". This may then allow you to access the drive again. You may need to take it out of the port, then reinsert it so the computer will re-detect the files. If this does not work, you will then need to format the external drive.
Please let me know if you need further assistance.
carsandcomps,
Guru, Premium Expert @ Fixya.com
Jun 17, 2010 | Toshiba Satellite L300D-ST3501 Notebook
I have a Zip 250 disk that will not read. When I insert the disk in the external disk drive, it will spin and stop a few times and that's it. When I try to access the disk/drive letter via "My Computer",...
If the disk is unreadable this means that the format or the files extensions on it are not readable in the operation system you use..either are damaged or the disk itself is damaged or it wasn't finalized like it should ...If other disks inserted run ok than the disk it is damaged and it is nothing wrong with the drive itself..When it says to insert a disk this means that it is not seeing the disk at all and it sounds like a drive problem ..but if other disks are ok ..than it is just a damaged disk or in a format unreadable ..beware if it a cd unit ..will not read dvd-es..or if it a dvd kind will not read large dvd-es (dual layer) or blue-ray disks..
May 29, 2010 | Iomega ZIP 250 External ZIP Drive
Running Windows 7 Home premium. External drive Verbatim USB 250 Silver is recognized, but, needs to be reformatted. I've tried to format (NTSF) using tool in Disk Management. Format runs forever and...
Hello and thank you for using Fixya's services.
This problem happens quite a bit with Windows Vista. It seems that Windows Vista puts a hidden file in the backup; which locks the device.
Open the external device (Windows 7 is fine). Click on "view hidden folders and files." Delete any hidden files you may have in the external.
Go back to "my computer" and right click on the external hard drive letter. Choose properties and security tab. Make your user-name as a main user (administrator) and disable the read only.
Reboot the computer and see if this works.
Please let me know if you have any questions.
Nov 04, 2009 | Office Equipment & Supplies
Iomega External Hard Drive model #3173600. Following a
ok it's asking you to reinstall the cd that came with the ext hard drive to do this remove the hard drive frist after you power down you pc put your cd in after you power backup install the driver power down plug your hard drive back in window will do the rest for you Good Luck
Jul 18, 2009 | Computers & Internet
Maxtor external harddisk recognition problem by pc
Hi Maxtarm,
It sounds like either the drive or enclosure is failing rather quickly.
The first and cheaper solution is to take the drive to your local computer shop and have the techs there move the harddrive into a new enclosure and test it. If it works in the new enclosure, you're done, but please take my advise and never rely on a single copy of your files. Always keep your important files in 2 or more places, on your computers hard drive, external drive and a backup to CD's or DVD's you can store in a firesafe or friends home is a good idea.
Now assuming that change of enclosures doesn't work, you will need the help of a recovery pro to get your files back. If that is the case comment back here with your location (Country, state, city) and I will advise you on a reputable recovery provider in your location.
Hope this helps Fixya,
Chris
Jul 15, 2009 | Maxtor Computers & Internet
My usb was suddenly says used capacity 0 bytes,free 0 bytes,FILE SYSTEM raw.Cannot be formated.it says insert flash drive.give me the best solution.
Jun 05, 2009 | PNY USB SmartMedia Reader PC (SFRUSBWB)
My flash drive verbatim 8 gb store and go is not recognized
I looked into similar problems and if this works ill let you knw i downloaded Paragon Pation Manager and i plan to use this to create a 8gb partion on my flash drive i dont know if this will work but ill get back to you
Nov 05, 2008 | Verbatim STORE-N-GO (95312) 8 GB Hard...
NexxTech Portable Hi-Speed USB 2.0 Kit Hard Drive Logo
Top NexxTech Computers & Internet Experts
Steven Wander
Steven Wander
Alun Cox
Joe Goldman
Joe Goldman
Are you a NexxTech Computer and Internet Expert? Answer questions, earn points and help others
