Question about RCA VR622HF VHS VCR
RCA VR601AHF The timer is stuck on. The timer light flashes constantly and makes the vcr unusable. The power will come on but will not play, rewind etc or show on screen menu. Thanks for any help.
  • xxxxxxxxx xxxxxxxxx
    xxxxxxxxx xxxxxxxxx Dec 15, 2007
    I Have The Same Problem, It Flashes Constantly, But, It Play's Rewind's Etc., Just Letting ya know, Stere0123.
  • BLUEMYSTERAI Nov 16, 2008
    WHEN THE VCR IS PLUGGED IN THE TIMER LIGHT IS BLINKING AND THE VCR WON'T WORK. I TRIED TO UNPLUG IT AND SET IT UP AGAIN BUT NOTHING WORKS
I just had this same problem. I thought that the timer was stuck and was the reason why the VCR wouldn't play. I just moved and thought the unit got broken in the move. However, I think it was just not hooked up properly to the TV. I unplugged it, plugged it back in, and got it hooked up properly and it started working again (I tested the connection with a DVD player first). The flashing timer light went off as soon as I reset the clock. It seems odd that having it not hooked up properly should stop the VCR from playing, but that is what seemed to happen in my case. Hope this helps.
Posted on Sep 03, 2007
SOURCE:
I taped a TV show. But I can't fast forward to see the end part that I want to watch. It just advances to the end.
I'm not surprised that it advances on the end. The VCR doesn't know where the end of the taped programme is. You will have to search manually for it. Start at the end of the tape and rewind a few minutes worth of recording then press 'play' and see what you get. If not successful rewind further and try again, etc,etc. Alternatively you could press "play +rewind" which should allow you to watch the record on what is fast (=x2) rewind. It will help you if you know how long the show was and at what point the tape was when recording started.
Mar 26, 2015 | Televison & Video
How do I get a VCR movie to start
Press play . Are you sure it is a vcr and not a DVD. Make sure tape is rewind to beginning so it plays. IF. It is Dvd it should give you a menu if play. Or chapter selection etc
Mar 25, 2015 | Televison & Video
Panasonic PV-7400 VHS VCR seems to be stuck in Memory Rewind Off mode. I power on, it attempts to rewind (though there is no tape in there now) for about 20 seconds, then powers off. I've pulled
Most of these problems are caused by a faulty mode switch. If the mode switch has gone off of it's true position, then the electronics might well think it's in rewind mode even in the off position. Sometimes it's just the switch that is faulty, but sometimes damage to the mechanism has thrown off the switch.
Apr 14, 2013 | Televison & Video
I lost the remote control, how can rewind the hsv tape. Thanks.
There should be a rewind button on the front of the main unit (usually indicated by either REW or 2 arrows pointing to the left), this should be next to the fast forward (again indicated by either F-FWD or 2 arrows pointing to the right) as well as PLAY and STOP - for the VCR. The only thing you would need the remote for is to set the clock and/or perform setup for the DVD player as well as timer recording. Try a universal remote which will make fast forward, play, stop, record (to VHS) and rewind easier.
Apr 11, 2011 | JVC DR-MV7 DVD Recorder/VCR
VHS tape is stuck in the VCR. Tape will not eject, will not play or foward/rewind. The unit has been working just fine with no problems. The VHS tape has been inserted into the machine to record daily...
assuming you have power to the machine , i would suggest the ejection drive belt has stretched , 2 choices here , take it somewhere and get it fixed or unplug it from power supply and remove the top casing yourself and have a look.
Jan 29, 2018 | Toshiba SD-V291 DVD Player/VCR
Sony GV-D1000 Powers on, will play memory stik, but not tape
C:31:23 error code means problem is in Supply Reel section.
If you are tech person you might got the point.
Unit has mechanical problem in supply reel area and reel pulse is not being generated as supply reel table may be stuck due to back tension.
Let me know if you need further help.
Feb 11, 2009 | Sony GV-D1000 Mini DV VCR
Vcr won't play
having the same problem I would love to know myself!!!! PLEASE HELP
Mar 20, 2008 | RCA VR349 VHS VCR
Mitsubishi vcr HS-U770
More likley it's not the little white thingy but the belt that drives it. Take the bottom off and get that broken belt out and runn down to the VCR / Tv repair shop and see if they have a new belt
Mar 07, 2008 | Mitsubishi HS-U770 S-VHS VCR
Accessing the menu and timer recordings
Oh boy! Most late VCRs must have a functional remote to get to the advanced functions such as setting time, programming, etc. The front panel buttons only have stop/play/rewind/ffwd/eject and so forth. Either obtain an exact remote, or one of aftermarket universal remote boxes which have menu functions.
Nov 14, 2007 | Curtis CMV41001 VCR
RCA VR622HF VHS VCR Logo
565 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
