My truck has always started good hot or cold then the light came on to change fuel filter now it is real hard to start first time every day once it is started it starts fine the rest of the day even if it sits for 3 or 4 hours between starts 1992 7.3 diesel
SOURCE: hard starting in the morning
it sounds like 1 of two things either your starter relay is gone and you need a new one ,they arnt that expensive or its your hold in winding in the starter motor this is a bit more expensive but can be changed quite easily.
SOURCE: runs for 3-4 min then stalls, wont start until next day.
i would look at those items first by checking battery voltage at fuel pump if car stalls but pump is still getting voltage then i would pull fuel filter back out and check to see if installed correctly also blowing through filter to make sure its not clogged in rare occasions can be defective or if installed backwards if possible can colapse inside should have arrow pointing towards direction of engine if all is well check relay then crankshaft sensor
SOURCE: 1991 Mazda 626 DX dies suddenly after running for 10 minutes.
Hello, It sounds like an engine ignition control module gone out or a coil. They get hot and quit working after a short period of time, cool off then work again till they get hot.
Is the ignition system pointless electronic or does it have points? Are you getting any fire at all now to the cylinders? Does the tach in the vehicle show any RPM's during cranking? Do you have voltage at the positive side of the ignition coil? Does the coil meet the ohm ratings for that years vehicle ignition? Does the vehicle have oil in it so the oil pressure sensor allows the engine to run, this may not be an option on your particular vehicle? You can check most of this out with a volt/ohm meter. Check your voltages before starting the vehicle, during running and after it quits to see where the loss is. Just don't get near the center tap of the coil or you will get a rude awakening and/or serious injury. Good luck, RAC
SOURCE: B 2500 diesel pickup hard start from cold
Hey mate,
I have a Mazda B2200 from 1985, which has the same R2 diesel motor, and I had this same problem, which was exacerbated by the cold of winter....even here in a mild Melbourne.
Each time you turn the ignition on, the QSS (Quick Start System) powers up the glow plugs for about three seconds. This recycles again about three times, then.....nothing. The QSS reckons that you ought to have the bugger running by now!
In my desperation, I located the cable to the four glow plugs, and ran a second wire from the battery (+) via a push-button switch which I installed on the dash. This is my glow-plug BOOST circuit.
Now, when I want to start from c-c-c-cold, I push the button (with the ignition on) for about ten or fifteen seconds, which gives the glow plugs a goodly time to heat up the combustion chamber, and when I hit the starter, she usually fires up with a rattle, and a cloud of grey exhaust smoke.
BINGO!
(Of course, once the motor has warmed up, there is no need to use this BOOST circuit, for the combustion chambers are already hot enough to detonate the injected fuel.)
Have a go at it, as I know that it works!
John.
SOURCE: mazda protege 96 very hard to start when cold,
check the mas air flow sensor(is this the 6 cyl) the sensor has a problem with the nose piece inside not moving enough to tell the ecm the propper air flow for the cold start,also check throttle valve for dirt build up around it-if its a four cyl repost
