Question about Pentax Optio 33L Digital Camera
Camera not turning on
I've been having a proble turning on my camera since coming back from my vacations (thank god it didn't happen at that time!). Batteries are fine, memory card is in, all covers are closed but when I press on the ON/OFF button, the camera emits a "triple beep"-like sound and nothing happens, it does not turn on, nor does a error message appear on the screen. Any hints on what it might be...? The first time it happened was following a memory card change, I might have opened the memory card cover too fast while it was still turned on but to my knowledge, it didnt' happen that way, it suddenly happenend. thank you
  • Paul Barker Jan 05, 2008
    new batteries nothing on screen press on little clicking noise inside, tried forcing lens out, no help, lcd doesn't come on tried holding play while pressing on button. An electronic dead duck. Not impressed.
The Same thing just happened to mine said my card wasn't formatted, tried several card with no luck, the tell me too much money to have looked at $150 min they say buy a new camera. Always get extended warranty for 2-3 years the 49.95 is worth it in the long run.
Posted on Sep 08, 2007
My wildgame camera model S4 will not power back up, I've changed the batteries twice and checked them with a volt meter to make sure they are good. I've only had the camera for 1yr.
1) memory card slot/batter covert is open
2)batteries are loades in the wrong direction
3) insufficiente battery voltage
4) poor contact between camera and battery terminal
5) swtich is fault, measure continuity.
God bless you
Oct 17, 2012 | Wildgame Innovations S4 Digital Camera
Kodak M853 black screen
the Screen LCD is faulty. You must replace and dissasembly your camera, for fix it. you have 2 optione a) do it yourself or b) go to the repair shop for fix it.
God bless you
Jul 21, 2012 | Kodak EasyShare M853 Digital Camera
My camera turns on then turns right back off again?
Same thing happened to mine, and it had to be sent away for repairs.
May 07, 2017 | Kodak EASYSHARE M763 Digital Camera
Canon power button stuck
I have had this happen before and I put WD-40 on a Q-tip and rubbed it around the button. It took a while but it worked for me.
Feb 01, 2012 | Canon Powershot A2000 IS Digital Camera
Hello, I have a Lumix DMC-FS10, I have found that some of my photos have downloaded to thumbprint size which won't seem to go any bigger without distortion and some are normal I unfortunately deleted...
Actually, you still might be able to get those photos back, even though they've been erased. Try not to take any more pics until you've recovered your photos, take the card out of the camera. This is to reduce the chance of you overwriting some of your "lost" photos. There are many good freeware photo recovery software options that may help you recover your photos. This article reviews and outlines several of the better ones.
This sounds like the problem may have occurred because you might not have formatted the card in your camera as recommended by the manufacturer. If true, after you've recovered your photos, format the card in your camera using the camera's format feature. This will prevent this from happening again.
Sep 20, 2011 | Panasonic Lumix DMC-TZ1 Digital Camera
Green dot on scren
I'm having the same issue on my older JVC GZ-MG model. It seems to only happen in low light situations. I can't believe there is nothing on the web about this.
Nov 23, 2009 | JVC Everio GZ-MG630 Hard Drive Camcorder
My camera won't turn on. I charge it and the red charging light comes on. I have returned the camera for the same problem 3 times. bought it from WalMart. I was on my vacation the 1st time it happened, and...
Are you sure the battery was inserted properly? Try putting it in the way that looks backwards... the battery seriously looks like it's supposed to go in the wrong way. If you're looking inside and using the spring for a reference, DON'T. The spring is only there to push the battery out, not to attach to it.
Oct 20, 2009 | Vivitar ViviCam 8025 Digital Camera
LED screen
Try pressing the "DISP" button. Your camera might be set to use the view finder instead of the LCD screen. Also, your camera will automatically turn off the LCD screen after one minute, just any button other than OFF to restore. Also, check to see if the LCD screen is firmly pressed back into the camera; you should hear a slight click or snap noise when it is done correctly. Good luck.
Jun 12, 2007 | Canon PowerShot S3 IS Digital Camera
Pentax Optio 33L Digital Camera Logo
62 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
