Computers & Internet Logo
Anonymous Posted on May 28, 2013
Utorrent port blocked - Computers & Internet
Anonymous
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 10 Answers
  • Posted on Jul 04, 2013
Anonymous
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
10
Questions
Helped
4662
Points
35
Run a FULL SYSTEM SCAN for ALL of the follwing FOR ALL!!!
---ANTI-VIRUS
---SPYWARE
---MALWARE
Run a "Full System CLEANER"... to dump ALL COOKIES (privacy protections!).... defragment the Registry...... run a Total System Defrag
Simply reboot.....
enable https inspection, then try to block the respective sites
Hi, I'm having problems port forwarding my Thompson TG585 v8. Im trying to port forward for utorrent application but it does not seem to work, everytime i get an error saying "port is not...
- Please check if it's UDP or TCP. You might have selected TCP for port forwarding but Torrent also uses UDP. For some ports that's important to make both forwarding. One for TCP, the other for UDP.
- If this doesn't work, you need to go deeper. You need to have access to an external computer on internet (a friend) from which you can start a telnet. For instance :
telnet mypublicip 45682
On your side, you need to check what's coming on your network interface. Two options to achieve this :
- Either you book a linux live cd (kubuntu), and you run in a console :
sudo tcpdump -ni eth0
(eth0 is the first ethernet adapter of your workstation).
- Either you use wireshark on Windows, this should do the trick, but you cannot be sure that there is no other software blocking on your current installation.
Regards,
Cannot dowload load from utorrent
you need to open a port on your router to allow utorrent to work OR your ISP has blocked all bit torrent streams from your home
to open a port find out how to from here
www.portforward.com
Iv got a BT home hub 2 cant get conections for utorrent even though opened firewalls
There are ISPs that block utorrent. I found this explanation of how to do port forwarding on the BT home hub, though: http://portforward.com/english/routers/port_forwarding/BT/BTHomeHub/Utorrent.htm
So, all I can suggest is to open the ports on your home hub as suggested above and to connect your computer straight to your home hub rather than to your CWR-854 (unless you actually have no such router and just picked that to ask the question under).
It is possible that someone has decided that you should not use torrents (they slow down everyone because they actually have the nerve to use the internet) and they are associated with thieves. Not to mention that there are tons of legit uses for them,
This could be someone in your ISP or your house. So do you have access to everything? You can poke around with telnet - can you access the ports on the other systems that utorrent accesses to make itself part of the network of systems that are downloading and sharing the torrent?
But if one knows the ports it is easy to block torrent.
If you have multiple routers that do nat, the home hub has to forward to your router, not to your system. So if your router is 192.168.3.12 and your system is 192.168.5.6, the BT home hub has to forward to the port on your router, on 192.168.3.12 , and your router has to forward to your system on 192.168.5.6. If the home hub tries to forward directly to your system (if you have multiple routers, which you might have because of the way you asked your question) then it won't work since your router hides 192.168.5.6.
1helpful
How to port forward for microtorrent on belkin n1 vision
Here is a good walk-through how to set up utorrent on your router.
Enjoy!
PS: Make sure that utorrent is not blocked by your Windows firewall!
If you have any more questions, just come back here and leave a comment - I'm happy to help.
1helpful
Weird problem. IE works, but other internet-using programs don't
The firewall is turned on on you router and can be disabled by changing the firewall settings on your router. utorrent and online games have to use ports for incomming and outgoing data transfer and should be listed as exceptions on your router. go into utorrent options and check what port is being used and do the same for your brothers game if you want to keep the rest of the ports blocked from potential attacks.
When i try to download a movie on utorrent it says that the port is not open what do i do to download movies.
try to disable the security programs like norton, mcafee what ever you have on your computer and then check if it works. If it does, give access to utorrent as its a download software and firewalls always try to block downloads
Utorrent port.
you need to manually add it in the port forward section of your router interface. typically a range of 10 - 20 ports. make sure it matches the ports listed in the utorrent options page.
3answers
Utorrent downloads with WRT54GL?
Before we can forward ports for Utorrent, we need to figure out what ports Utorrent is using. Here is a brief walkthrough on how to do that. Go ahead and open up Utorrent.
Click Options in the menu at the top of your screen. In the list that drops down click Preferences.
Click Connections on the left hand side of the Utorrent program. You should now see the menu shown in the screenshot above. Make sure the Enable UPnP box is unchecked. The number in the Port Used for Incoming Connections box contains the port you need to forward. You can change the port number, if you want to. Please enter the port you chose into the box below.
Utorrent's Port for incoming connections To setup port forwarding on this router your computer needs to have a static ip address. Take a look at our Static IP Address guide to setup a static ip address. When you are finished setting up a static ip address, please come back to this page and enter the ip address you setup in the Static IP Address box below.
Do not skip this step! Please enter the static ip you want to forward to: 192.168.1.
Open a web browser like internet explorer or Netscape. Enter the ip address of your router in the address bar of your browser. In the picture above the address bar has http://www.google.com in it. Just replace all of that with the ip address of your router. By default the ip address should be set to 192.168.1.1.
You should see a box prompting you for your username and password. Enter your username and password now. By default the username is blank, and the password is admin. Click the Ok button to log in to your router.
Click the Security link near the top of the page.
Remove the checkmark from the Block Anonymous Internet Requests checkbox.
Click the Save Settings button near the bottom of the page.
Click the Applications & Gaming link near the top of the page.
You should now see a new menu. In this new menu, click Port Range Forward.
Port Range Application Start End Protocol IP Address Enable To Both 192.168.1. We will list a series of lines here that will show you exactly how to forward the ports you need to forward. Utorrent requires you to forward the ports you entered above. Go ahead and enter the settings shown above into the Port Range Forward menu.
When you're finished, click Save Settings near the bottom of the screen to save your changes.
And that's it! You're done!
Grand Canyon Tech
Grand Canyon Tech
