Question about NetGear DG834G Router
The range is not working!
We've had our re router for about 10 months, and it has worked fine. But for a few days now, the range of the re router has not been working as it did when we got it. On our laptops (even when we go right next to the re router), we can not get full signal. Thanks. Goodcheesy
  • Goodcheesy Aug 16, 2007
    the only electrical appliances near it are 2 T.Vs, and yes, it does use a virtical rear mounter antanna
  • 560 Answers
You can use repeater with your Netgear router.
Posted on Oct 15, 2012
    Problem Solver:
  • 17 Answers
Is there any electrical aplliances, does it use a vertical rear mounted antenna?
Posted on Aug 16, 2007
  • George Jordaan Aug 17, 2007
    is there any electrical aplliances very close to the antenna and is the wireless network LED burning on the display. if not log into the router (supposedly via HTML) and enable the Wi-Fi
SOURCE:
Hawking HW2R1 repeater doesn't get internet
first of all bring the repeater closer to your router (after upgrade you can return it to its original location)
Mar 25, 2017 | Hawking HW2R1 Dual Radio Smart Repeater
I've setup the router (edimax 3G-6200n)and all was working well for a couple of days. This morning however, only the power light is on. The LAN network cable is fine as i connected it directly to
If the only light you have on is the power light, it is most likely dead. You try unplugging the router then plugging it back in to see if this clears the issue. If it does, the issue will probably come back. Your best bet is to replace this router.
Apr 04, 2012 | Edimax Computers & Internet
What is F7 10 code on kenmore elite 790.4661 electric range
You may have a bad Electronic range control ERC, but if your not handy you may want a service person to look at it. If you are handy and can get to the control panel, check and clean the connections, after you disconnect the power. Use tuner cleaner or alcohol. There are diagrams of you range online. Are you having one error or two. Looks like you mention f7 and 10, or am I mistaken.
Dec 21, 2017 | Kenmore Kitchen Ranges
I am a novice with computers, but just had a Brighthouse "Lighting" modem installed. It goes straight to my RV042 router, which goes to the computer (and also a Mac Airport...better range than the modem)....
Check to See if u Cud reduce the traffic between Modem and Router
In Router u have a option MTU Size
try too Reduce it a Little and Observe
All the BEst
Oct 01, 2010 | Linksys RV042 VPN Router
I have a Whirlpool range hood model #RH4930XD81 approx. 10 years old. A few months ago, the light and vent fan just quit working. They were both working fine and just would not turn on one day. Any...
probably need new replacement parts......... new hoods these days start out at like 60 dollars,,, i would probably replace the unit with the age of it, because the parts needed for that will exceed prob 150 dollars
Feb 05, 2010 | Kitchen Ranges
Intermittent or slow internet connection
Go here and upgrade your Router's Firmware - you will need to choose your location on the site at top left hand corner of the screen
http://www.linksysbycisco.com/UK/en/support
Feb 27, 2009 | Linksys Wireless-G Broadband Router
Starting problem
Try the idle air control valve it is located near the throttle body it has a four wire plug and has two small hoses attached to it this is a small stepper motor that controls the amount of air on start up this part will cost about $200 from a popular auto parts store.
Dec 16, 2008 | 2000 Nissan Maxima
I cannot get the router to work.
I think there isn't.
try to do something that mught sound kinda stupied but it worked for me.
Try pressing again the the back of the device for a few seconds ( I guess u haven't done this but I ve doing default witht the router's interface) and than set all the values again
Nov 25, 2008 | Computers & Internet
Wireless connection keeps dropping after about a day.
I had the same problem (see Jan 09) but I found the solution:
I had trouble with the router resetting from time to time, that was fixed by upgrading to firmware 1.05. But I still had the wireless problem.
For me, disabling 'UPnP' (advanced->advanced network) and disabling turbo G mode (setup->wireless setting) did the trick.
Work great since then, both my laptop and my media center stays connected, going on one month now.
Hope it can helps other.
Nov 25, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
Range and power
open the router page go to the wireless settings & change the channel to channel 6 & reinstall the wireless network card in computer & it will work fine.
Jun 04, 2008 | NetGear RangeMax WPN824 Wireless Router...
NetGear DG834G Router Logo
29 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
