Question about Canon MultiPASS F80 All-In-One InkJet Printer
"check Printer press resume key"
I was away for a couple of weeks. While I was away, the Black ink ran out, and the memory filled. I changed the Black Ink and now it says "check Printer press resume key". I have tried pressing the resume key, unplugging the unit, shutting down and a couple of suggestions on a previous page. Can you help? Worked great before this happened. Rock5219
  • 1 more comment
  • rock5219 Aug 16, 2007
    There is no error code (##xxx). I tried to download the comprehensive manual, but got a "link no longer valid" message. I tried the power off, resume/power on, 2 x resume, then 4x resume, to reset ink tank. Did not get to any other mode to come up.
  • rock5219 Aug 17, 2007
    No matter what I do, everytime I push the "resume" button, the print head cycles, and then warning light continues to flash. If I try to use any feature from the menu, I get a hi/lo repeating sound. The manual does not show how to reset the used ink tank. I can only guess this is the problem, as everything else has failed. Rock
  • rock5219 Oct 25, 2007
    Still not working.  Help...
  • 1,006 Answers
Check this out and tell me it was helpfull???
Posted on Oct 26, 2007
  • arben pllana
    arben pllana Oct 26, 2007
    http://www.repairfaq.org/REPAIR/F_HPLase...
  • arben pllana
    And try this one :
    http://www.freelists.org/archives/pchelp...
    or this :
    It could be due to "waste tank full" alarm; you may need to reset the waste tank counter.
     Try:
    Resetting the Waste Ink Volume Counter
    1) Enter SERVICE MODE.---
    By pressing Menu-Copy-#
    2) Select TEST MODE.
    3) Select [8] PRINTER TEST in TEST MODE.
    4) Select 3. [EEPROM CLEAR].
    5) Select 0. [INK COUNT].
    6) Press the [OK] key.
    7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
    Skip step (6) since there is no [OK] key
    Sergeant:
  • 279 Answers
Try this to reset the used ink tank counters. I can't swear it works since I don't have one of these to test it on: 1) Enter SERVICE MODE by pressing menu-copy-scan-copy-copy 2) Select TEST MODE - off a menu I believe, not sure which choice it is on that menu 3) Select [8] PRINTER TEST in TEST MODE. 4) Select [3] EEPROM CLEAR I think this option is under test mode. If not, just look around the menus for it. 5) Select [0] INK COUNT 6) Press the [Set] key, or maybe it's just the [OK] key 7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key Let me know if that works.
Posted on Aug 31, 2007
  • 944 Answers
Which suggestions did you try? There is a white data cable that connects to the moving printhead - where the other end connects to the back wall apparently often comes loose in this model and pressing it firmly back on may solve your problem. Do you get any error code below the "Check printer, press resume key" message? should be ## then a 3 figure code. If you want a bit more info (WOG) check this link; http://www.fixyourownprinter.com/forums/inkjet/29437 Checking the waste ink tank also sounds worth it. Here is the link to the user manual if you need it; http://alpha03u.c-wss.com/inc/ApplServlet?SV=WWUCA900 download the "Comprehensive guide" and check; Page 90/91 and ensure ink cartridge is correctly installed and that the connection plates on the cartridge are totally clean and free of grease(soft dry cloth generally best). Do you have a memory card inserted? Check page 100 for details, make sure it was in correctly. remove it (page 31)completely and see if this makes a difference. Check page 72 and see if you can delete any messages from the memory - if you think you can't afford to delete them, see if you can copy the contents to the pc and then delete. Check page 114 for details of the error message. Do you get error messages on the PC? (page 117) Hope this helps, waiting on any info :)
Posted on Aug 16, 2007
  • Nigel Ridehalgh
    Nigel Ridehalgh Aug 17, 2007
    Sorry is Canon site being difficult. Working link is;
    http://www.usa.canon.com/consumer/contro...
    click "product software/manuals" and the link is at the bottom of the window that pops up.
How to reset canon s900
  1. Turn off the printer.
  2. Press and hold the RESUME button, then press and hold the POWER button.
  3. While still holding the POWER button, Release the RESUME button, then press and release the RESUME button two more times in succession.
  4. The printer mechanics will move momentarily. You are now in Service mode. Release the Power Button.
  5. Pressing the RESUME key will select a function; for example, pressing RESUME 4 times will select the clear waste ink counter function. The lamp will alternate color with each key press.
    1. Service/factory test printout, including ink sensor check
    2. EEPROM info printout
    3. EEPROM initialization
    4. Clear the waste-ink counter
    5. Printer model setting. (more selections beyond this- leave this alone)
  6. After selecting mode, press the POWER button to commit the change, and return to the top of the function selection menu. Pressing the POWER button again turns off the printer for a restart.
Nov 03, 2016 | Canon Office Equipment & Supplies
Canon MP830 message re: waste tank full. How do I get to it to empty it or replace it.
The waste ink tank refers to may be a small well, surrounded by a
rubber ring, that sits under the cartridge when it is parked.
Place a cotton tip swab ("Q-Tip") over the hole to wick out the ink inside.
Oct 07, 2008 | Office Equipment & Supplies
Tip
How to reset Canon S820 printer ?
on Mar 10, 2010 | Office Equipment & Supplies
My printer prints, but colors are all off. There
Release the RESUME button, then press and release the RESUME button two more times in succession. (youre still holding the POWER button during this). The printer mechanics will move momentarily.
1. service/factory test printout, including ink sensor check
If you have a defective printer head, your power lamp may flash during the service mode key-in, and info printouts may not work. In this case, clearing the waste-ink counter may not fix your problem.
Apr 04, 2010 | Canon i950 InkJet Photo Printer
My printer will no longer print black text
Apr 04, 2010 | Canon MP830 All-In-One Printer
Waste ink absorber is almost full
The waste-ink counter for the BJ F900, F890, F700, F500, S900, S820, S750 and S520 are all reset in the same manner.
Feb 13, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Black ink ran out and printed one photocopy without producing any black. Change the cartridge several times BUT still does samme thing - no printing in black. Colour is fine, just no black despite changing...
Canon IP 2000 / reset
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
All the best Pineworks
Feb 09, 2010 | Canon PIXMA iP2000 InkJet Printer
Check printer & alarm flashing.I cannot get it to reset.
Electric connection terminals scratched? Maybe short circuit. Use warranty from purchase for repair.
Sep 29, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
On cleaning the pads of canon printer
1: Power off printer
2: Hold Resume button then press and hold POWER, the beeper will sound once.
3: Hold POWER and release RESUME
4: Press RESUME twice
5: When the indicator lights steady, press RESUME three(3) times. The indicator should be orange.
6: Press Power to set data
Aug 19, 2008 | Canon BJC 3000 InkJet Printer
Problem with Canon MultiPASS F80
On the right side of the print cartridge carriage there are two small felt ink pads. When they fill with ink somehow the machine detects it. Mine started with the flashing light and check printer error code and then progressed to a nasty grinding sound everytime I hit resume or tried to reset the counter. I thought all was lost, but kept trying. I found two pads, one square and one rectangular. They aren't very spongy but they are full of ink. They are only about an inch across. I got them out without taking the printer apart and repeatedly soaked them in a little water until the water was clear, then I let them dry and replaced them in the little trays where they came from. I cleaned the plastic fins that were nearby and coated with ink with a Qtip and rubbing alcohol. And I removed the print head and cleaned the muck of ink on the connectors with a Qtip and rubbing alcohol. Much to my suprise, after all of this the damn thing worked fine again when I plugged it back in.
Apr 14, 2008 | Canon MultiPASS F80 All-In-One InkJet...
Canon MultiPASS F80 All-In-One InkJet Printer Logo
253 people viewed this question
Clive
Clive
old marine
old marine
