Question about Frigidaire GLRS264ZA Side by Side Refrigerator
Frigidaire frs26zsh ice dispenser problem
The icemaker makes ice, but will not dispense it. The spiral rod (auger?) turns, but the blade in front of the plastic housing looks as if it might be missing a clip that holds the blade tight against the housing. I have inserted a screw partway into blade beside rod, but it is not secure and it works off...is there a clamp or clip...or something that is missing? Can I glue or solder the blade to the housing?
  • stella1 Aug 16, 2007
    I'm not following...what should hook in front and back?--the auger? The blade is not secure against the plastic drum which moves the ice forward and down into a cup I hold on the door (the water works fine)...when I secure the blade, the ice dispenses. I tried a small phillips head screw, but it works loose...is there a type of clip or can I use, e.g. gorilla glue to secure the blade to the plastic drum?
  • akili Aug 13, 2008
    Ice will not dispense. Augur turns fine. Flap door opens fine but ice will not dispense.
    Thanks
  • 4 Answers
I have the same problem. I have tried super glue and JBWeld, but they only work for a short time. I'm going to try again tonight and see if there is another 'jerry rig' solution. I am not going to pay $150 for another assembly.
Posted on Jul 14, 2010
    Problem Solver:
  • 17 Answers
It should hook in on the front side of the dispenser towards the door first and then at the back as you would slide the tray in. Check to see if the grooves line up in the back where the motor sis to turn the wormgear. good luck
Posted on Aug 16, 2007
SOURCE:
Frigidaire frs6lf7fm. Ice maker dispenser, the auger won't turn (tested with ttay out). It makes ice and dumps it into the bin no problem. And the water side is fine.
[FIXED] Icemaker auger motor won't turn - ApplianceBlog
www.applianceblog.com/.../18196-FIXED-Icemaker-auger-motor-won-t...
Apr 16, 2010 - 9 posts - ‎2 authors Does the auger motor need to be re-set or something? I wonder if it shut itself down to prevent burnout (because it had been unable to turn the ... FIXED Auger won't turn to dispense ice.
Jun 1, 2014
Ice maker auger will not turn
Mar 17, 2013
FIXED Ice Auger won't turn
Sep 3, 2012
GE Icemaker: Makes Ice, Doesn't Dispense In Door?
Apr 19, 2005
More results from www.applianceblog.com
Oct 01, 2015 | Frigidaire Refrigerators
Ice aker ks, but does not dispense ice. fgidaire gallery, sde by side
Good Afternoon friend, thanks for your inquiry!
I understand that your icemaker is not dispensing ice in your Frigidaire refrigerator. I would recommend checking the dispenser chute, if there is a blockage of ice within the chute it would not dispense. When you press on the dispenser do you hear a noise? If you do that could be the auger trying to push the ice out, if you do not hear a noise it sounds like it be a potential problem with the dispenser or control panel. I would seek assistance from a technician to come out and properly diagnose your refrigerator. I hope this helps. -Matt
Sep 26, 2014 | Frigidaire Gallery GLHS38EGSB Side by Side...
Whirlpool side by side refrigerator
Could be blocked up in the shute. remove all ice from the freezer and check that the ice shute (leading to the dispenser outlet) is clear. Let the freezer create a batch of ice (normally about 4 to 5 hours) and see if it dispenses then. If not , it could be a failed auger motor. That is the main corkscrew looking drive which pulls the ice into the shute. Check the icemaker in the freezer, and look for a button on the side or underneath the icemaker. Most manufacturers put one there to test the icemaker. Press the icemaker ice dispenser button and see or hear if the auger is turning.
Aug 26, 2014 | Whirlpool ED5FHEXVS Side by Side...
Spring control rod in kenmore model 253.55693400, I think the spring is messed up not letting ice dispense from the door. The auger is turning every thing has power
See if you can run the ice dispenser while the door is open. The auger may be turning but not the "drive blade" that delivers the ice.
Oct 03, 2011 | Kenmore Side by Side Refrigerator
I have a GE Profile refrigerator, Model PFSS6PKWBSS, with icemaker on door. Water is collecting under Deli-draw and leaking down freezer door onto floor. How do I fix leak?
Hi
Try and access the ice dispenser assembly and check from where the water is leaking. You would need to disassemble the ice dispenser and ice maker to check this. The ice dispenser is located in the upper portion of the freezer compartment. This assembly stores ice made by the icemaker and dispenses ice on demand from the door dispenser target switch.
1. Remove the upper ice bucket tray.
2. Slide out the ice dispenser assembly.
3. Remove the ice cube solenoid linkage Phillips head screw and slide the linkage back.
4. Remove the ice crusher cover Phillips head screws (2) and remove the cover.
5. With a pair of pliers, twist off the backing plate tabs located on either side of the crusher.
6. With 2 small flat-blade screwdrivers, unlock the ice crusher locking tabs located at either side of the ice crusher.
7. Lift the ice crusher out of the bucket.
8. Remove the ice crusher back cover.
9. Remove the locking ring from the ice crusher auger.
10. Remove the plastic nut with a pair of pliers by turning it clockwise.
11. Remove the spacers and blades. The blades are numbered for reassembly.
Icemaker--
The icemaker is located in the upper rear of the freezer compartment and supplies ice to the dispenser tub.
1. Disconnect the icemaker cable connector.
2. Remove 1/4-in. icemaker mounting screws and slide out the icemaker.
This refrigerator is equipped with an Electronic Icemaker.
Hope this helps... Please post back if you need more information.
Daniel
May 01, 2011 | Refrigerators
Icemaker is making ice but the ice dispenser is not working
Check the ice storage container. The ice dispenser will not dispense ice until the first supply ice has dropped into the ice storage container.Remove excess ice from the back of the ice container. Make sure ice cubes are not jammed between the ice maker and the back of the ice container.
The auger won't engage or turn to dispense ice.Remove the ice bucket and with a hair dryer warm up the inside where the fork is that turns the auger in the bucket and try it and if this does not help then you will have to replace the auger motor ,, chances are the motor is just froze up .--------
If there is nothing jammed then try this./Remove the ice bin out.And then clean the ice bin.
Rotate the auger with your hand.If its hard then there is problem with auger motor.If the auger is not rotating fine then its faulty auger motor or the auger motor is frozen,if you notice ice getting collected there.
Take a hair dryer and blow hot air on the auger motor for few minutes.Take care you dont blow hot air continuously.
But if that is not helping then disconnect auger motor connecting wire wait for 2 minutes clean the connector and reconnect the connector back and see.If that is not helping at all.Then,replace the auger motor.
To see how auger motor looks.Please click the link below:---
http://www.appliancepartspros.com/part_details_lgimg.aspx?part_id=3965455&image=0
You can get required parts from sears part direct online site or from repairclinic.com site.
This will help. Thanks. Helpmech.
Feb 21, 2011 | Frigidaire FRS26H5AS Side by Side...
The dispenser auger turns but is not dispensing any ice. The auger turns freely and sends ice toward the front of the bin but nothing comes out. What can be done to fix it? Does the blade toward the front...
You have a cube of ice jammed between the rings of the auger...this stops anymore ice from moving out of the auger...
remove ALL of the ice from the tray and the auger and then let it refill... then it will work again...
heatman101
Aug 05, 2010 | Frigidaire FRS26ZSG
Frigidaire FRS26ZSH -ice & water dispenser panel lost power
I think you will need to unplug the pin plug under the cover at top or bottom hinge. Check the voltage and if OK leave unplugged until you can remove the dispenser and I will try to help you from the power source. Sounds like a short in the board and related to the light socket. The fuse only stopped the short from doing further damage, You may need to locate the short before replacing the fuse or board. I have looked over the wiring diagram. If you find the short without my help just be sure to replace the fuse with the correct size. The only things are the chute heater or something in that area of the board went to ground. Do you have a voltage meter? Contact me later when ready, Sea Breeze
Jan 20, 2010 | Frigidaire FRS3R5EMB Side by Side...
Icemaker only dispenses crushed ice
Your selector solenoid is not working. Next to the auger motor there is a selector. You will see a plastic peice in a hole to the left of the auger.....Try to move it up and down. If it won't move it is more than likely frozen in one spot. Try to defrost it. If that does not work then replace the solenoid.
Sep 05, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
FRIGIDAIRE SIDE BY SIDE ICE DISPENSER
Have same or similar problem. MY problem turns out to be that the Auger turns fine, but there is a little metal blade that attaches to the end of the auger and transfers the spin action into this auger "hopper" (for lack of a better term) which actually accepts the ice that has been moved from the back of the ice bucket by the metal auger and then dispenses the ice into the hopper which falls into the glass. the issue is one of crappy design. It turns out that this little blade has a rectangular opening in the middle that the rectangular end of the auger fits into. If this rectangle opening gets stripped (as mine has done, and ALL are likely to do) then the auger spins, the ice is moved forward but none are picked up by the hopper, and none (or very few) fall into the glass.
Everyone should check to see if this is the case. If so you may need to order a new blade, or a new auger, or a new refrigerator.
Good Luck!
Aug 10, 2007 | Frigidaire FSC23F7D Side by Side...
Frigidaire GLRS264ZA Side by Side Refrigerator Logo
468 people viewed this question
Top Frigidaire Refrigerators Experts
Steve Allison
Steve Allison
Sal De
Thomas F. Schneider
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
