Question about Encore ENP832-TX-PCSU PCMCIA Network Adapter
Encore cardbus pc card
Hi, i`ve an card and when i connect to hub, it don't turns on...why?
  • cinthya Aug 17, 2007
    Card type: ENP832-TX-PCSU
    SO: Win98 and WinXP
    I tried in two laptops. The card is detected but there is no internet...why?
    Problem Solver:
  • 17 Answers
More information, card type, OS etc
Posted on Aug 16, 2007
  • Anonymous Aug 17, 2007
    OK so you can detect the network but no connectivity?
SOURCE:
I/0 card parity interrupt at F000:E1AD. Type (S)hut off NMI, (R)eboot, other keys to continue
This error refers to an expansion card having an issue. If you've got any cardbus, wifi, bluetooth, etc cards take them out and see if that resolves the issue. More info here:
http://www.techsupportforum.com/forums/f217/i-o-card-parity-interrupt-at-f000-e1ad-417586.html
Jun 05, 2012 | Dell Inspiron™ E1505 PC Notebook
How to turn on wifi
hi
the T42 does not have WiFi, instead it facilitates internet connection via 16 BIT & 32 Bit PCMCIA slot to install a WiFi card , in order to go on the internet.
The ThinkPad uses the following adapters: v 360, 365X, 380, 600: 16-Bit PCMCIA v T20, T22, T23: 32-Bit CardBus and MiniPCI v T23: 32-Bit CardBus and MiniPCI Daughter Card v T30: 32-Bit CardBus and LAN on Planar Board (LOB) v T4x: 32-Bit CardBus and LAN on Planar Board (LOB). 16- and 32-Bit PC Card adapters are configured during ThinkPad initialization. Network Interface Controller data rates are: v For Token Ring: 4/16 MBps v For Ethernet: 10 Mbps...........16 bit PCMCIA 10/100 Mbps.......32 bit CardBus 10/100 Mbps.......MiniPCI and Daughter Card 10/100 Mbps.......T3x and T40 LOB 10/100/1000 Mbps..T42 LOB The MiniPCI Ethernet adapter is accessed behind a removable plate located on the bottom of the ThinkPad directly above the Model/Type S/N sticker. For T20 and T22, the MiniPCI adapter may be an Ethernet/Modem combination card. The Daughter Card (T23) is secured with two screws and is located next to the MiniPCI modem adapter.
please go to this link to read the manual -- it will explain the features for this ThinkPad of various series T42 model-type .
http://www-01.ibm.com/support/docview.wss?uid=isg2ffa39ae31a2f590e85256ced00828893&aid=1
please rate my service
Nov 22, 2010 | IBM ThinkPad T42 Notebook
How do I set up a d-link dub-h4 to my laptop I have a power connection, a connection on the rear of the hub-4 going to an adapter connecting to the ps/2 connector on the laptop. Do I need one of the...
The connection on the rear of the hub should go to a USB connection on the laptop, not a PS/2 connection. A PS/2 to USB adapter is used to connect a PS/2 keyboard or mouse to a USB connection.
Feb 23, 2010 | D-Link (DUB-H4) 4-Port USB Hub
Repairs of of my DC 7 5V/800mA
Replace the LAN cable from your HUB to your Computer. Also try if you have a spair computer to just incase to find out is it an issue with the cable HUB or netwrk card in your computer.
Jan 26, 2010 | Encore ENH708-MIN 8-Port 10Mbps Ethernet...
Cannot view my client in handycafe
Check if the LAN cables are connected properly, make sure that client PC's have handycafe client installed and connected to the hub/switch with the server PC.
In some cases wherein the server has two LAN Cards installed, make sure to choose the LAN Card which is connected to the hub/switch where the client PC's are also connected during the initial start-up of the Handycafe software.
Note: Check if the hub/switch or router (whichever you're using) does not have a problem.
Nov 05, 2009 | Computers & Internet
I cant connect to the internet through my wireless
I cant connect to the internet through my wireless but it sows connecton
Aug 17, 2009 | Encore IEEE 802.11b WiFi Wireless LAN...
Boost PCMCIA Wifi Card Range
em maybe you just need to change the pc card or honestly just change the pc for fast and efficient browsing.
Jan 21, 2009 | Encore IEEE 802.11b WiFi Wireless LAN...
Is there another port? Thinkpad T22 Notebook
There are effectively 2 ports on the USB controller chip, Though that particular model only is connected to one port.
If you need additional ports, you can get a small 4 port USB hub. Or get a PC Card with extra ports. Hub is less expensive.
Oct 31, 2008 | IBM ThinkPad T22 2647 Notebook
1934 installation problem
I have no magic solutions for this problem, and I?m guessing you?ve already tried what I?m going to suggest, but if not maybe you should try that: 1. are you using a laptop? The card you?re using might be a Cardbus, which usually isn?t supported by laptops because of BIOS settings. 2. It might also be a driver problem. Disconnect the card, remove it, remove the drivers. Restart the computer and reinstall the drivers. Turn the computer off. Reconnect the card and only then turn the computer on again. Wait a few minutes (sometimes it takes a few minutes for the computer to recognize new software). I don?t know if it would work, but it?s worth giving a shot.
Feb 22, 2006 | Artronix Technology Firewire 1394B...
Encore ENP832-TX-PCSU PCMCIA Network Adapter Logo
89 people viewed this question
Top Encore Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you an Encore Computer and Internet Expert? Answer questions, earn points and help others
