Question about Audix OM6 Professional Microphone
Stopped Working - no sound
I'll take it apart - see nothing obvious. do I have to replace a transformer or something?
  • toddba Aug 22, 2007
    All cables are perfect - I have 15 working mics - ribbons, dynamics, LDC and SDC's - I just haven't figured out how to fix or test a mic
  • 113 Answers
Change cable first
Posted on Aug 22, 2007
  • oscar herrera Aug 23, 2007
    repairing a mic is a step-at-a-time process based on ones experience,starting with cables is the first,then it gets a little technical.using a multitester,check diaphram,4-600ohm should be present with transformer disconnected,transformers are normally last ,they rarely go bad.
    hit me up for more info though.
It stopped working. i've replaced the trigger switch and still nothing. what should i try next
Philip, I would take it back apart and see if wire got pinched or maybe disconnected, if it ran for a few seconds, it should be something simple.
Feb 10, 2016 | Bosch Bulldog Extreme 1 in. Rotary Hammer...
I bought a Malibu 300W low voltage landscape transformer to replace a 200W unit that stopped working. It worked for 1 week, then stopped .. the reset **** doen't work. The LED works, I do see a...
I don't know if it burned out, but something is not right.
Malibu products come with 1-5 year warranty.
New product that stopped working should be exchanged for full replacement at place of purchase, except possibly the auction sites.
New Malibu product should work for many years.
Be sure to match bulb voltage with transformer voltage to avoid possible problems.
Mismatched bulb and transformer wattage should not affect a timer in short period such as 1 week.
Another thing to check is outlet polarity. Use circuit analyzer from home center to check outlet.
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Jul 20, 2011 | Intermatic Malibu 300W Power Pack...
It just stopped heating yesterday but the light
you say it has aloud hum to it? And everything works but no heat.Im going to give you a list of things it could be and you'll have to take microwave apart to do the work. Beforre you start get some small trays or pill bottles to put screws in. Make sure when you take a screw out you know where it goes back because all the screws may not be same length. First, You may have a blown fuse in the HV transformer primary circuit, The HV transformer is the largest thing you'll see when you take the cabinet of the frame.Second,bad connections for the magnetron filament the magnetron will have what looks like fins or louvers around it.look for bad wire connections. Third, could be a faulty thermal protector or fuse, More than likely its either going to be the HV transformer or the magnetron thats bad.
Sep 13, 2009 | GE XL1800 1100 Watts Microwave Oven
Malibu landscape lighting transformer problem
Testing ohms across A and B will read open circuit through transformer coil.
Testing DC voltage across terminals A and B should read 12 volts DC, and nothing less.
Transformer should make humming sound when working.
Test that receptacle has power and breaker is not tripped.
There are no repair parts for power packs, but they come with 5 year limited warranty.
For more information on Intermatic/Malibu power packs showing troubleshoot steps, replacement trippers, useful links, warranties and tips:
May 30, 2009 | Intermatic Malibu 300W Power Pack...
Humming sound and buring electrical smell
yes yes yes .you are absolutely right.its the coils in the motor burning.the motor needs replacement. Often the start relay for the motor sticks and makes the motor get too hot. This can cause the motor to over-heat and shut off on the built in safety sensor inside the motor. You may need to use a amp probe to test the motor properly, check model plate for proper amps.  If this is let go too long the motor windings can also be damaged ( they may look black instead of a nice copper color). The wires on the relay are also bad for burning off the wire terminals.   The wires at the motor should be checked to make sure they have not burned off or you can test the motor continuity with an ohm meter. See two newmotor wiring pictures.....here...and...here. The relay wires often burn off as well.
May 12, 2009 | Kenmore Washing Machines
No picture or sound just three low beeps
Hi guzzman2,
I have the same exact TV as you and it has the same problem. I took the whole tv apart and checked the obvious things i.e. fuse, loose board, etc. etc. Bottom line - it looks like the flyback transformer needs replacment This is what provides the picture tube with power/voltage, etc. The part itself is ~200.00 and the labor will be about $150.00 - $200.00. Thats what you would pay if its only the transformer. Usually when the transformer goes, it takes other components along with it. I am bringing my set to the recycling center since It's not worth fixing. Went to Costco and bought a 42" LCD tv for less than 900.00. Instead of spending upwards of $300.00-400.00 to fix a 13 yr old standard tv, go for the gusto and upgrade to High Defination TV with the appropriate Cable company box and you'll never regret it!!!!
What a wake up call to watch TV now!!!!!!!!! Good luck to you...
Sep 30, 2008 | Mitsubishi CS-35505 35" TV
Suspected blown fuse somewhere but no sign of it
Am sure that the internal transformer is gone, You would have powered your speaker with a step up/step down transformer, you need to see a technician around you that can help you out, you need to replace a 220V-230V transformer in the speaker since your country requires that.
Jowinson
Jun 20, 2008 | Logitech X-540 Computer Speakers
Beaters don't turn
You should try to replace the beater turners or try to fix the problem that causes the beater turners not to work.
May 01, 2008 | Sunbeam Heritage 2346 Stand Mixer
Harman Kardon AVR 40 no sound
Check the fuses - there may be one inside the box as well. May also be a bad transformer. You can get a multi-meter at Home Depot and lookup how to check the power at the transformer.
Oct 19, 2007 | Harman Kardon AVR 100
Audix OM6 Professional Microphone Logo
73 people viewed this question
Top Audix Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Audix Audio Player and Recorder Expert? Answer questions, earn points and help others
