Question about Canon CR-55 Pass-Through Scanner
Canon Cr-180 how do you get item to spray the date in on the back of items. I thought I needed a text file?
How can you get to the mirrors inside the machine to clean an ink build up? We are seeing think black lines on the items that are ran at the branches with these machines. Can you clean this off?
Posted on Dec 20, 2007
Amazon order
I'm not smiling .I ordered a item on amazon from genco Lockbourne in ohio . I received a item that wasn't what I thought , Tried to get in touch with lauran shaeffer , some type of manager . called 4 times and everyone is just blowing me off. Genco is a co. that's part of dell. here's the date I sent it from amazon (ihope) order # 104-4708112-3395401 . tracking # 1zx5656v0357243018 Date oct.1 5:34, 2014 . I hope you can help the item cost 107.00 I just want my money back . Amazon has always been straight with . HELP. EMAIL Edmond.twyman@yahoo.com ph# 856 397 3027 . Not very happy with genco
Jan 11, 2014 | Winter Sports
Scanner has been used for a few years, and is frequently pulling multiple items through at the same time. We have cleaned the rollers with alcohol wipes, and fed the waffle papers through to clean.
If this is a Canon CR-180 or 180II machine then the feed tires need to be replaced. Often if you are using the grey feed tires, the middle one will come loose from the platic hub and cause this problem no matter how much you tighten the tension wheel. The part numbers of the seperatrion roller assembly and the feed tire assembly are as follows.
MG1-3530-000 Seperation roller (has 3 tires)
MF1-4210-000 Feed roller (has 2 tires)
You can also replace the two in the hopper area, they are:
MF1-4352-000
MF1-4353-000
That is a common problem on older machines; hopefully that helps
Feb 24, 2011 | Canon CR-180
Auctions: I purchased an item and is was not exactly as desc...
With regard to this, you will need to file the item not described dispute so that you can get your money back.
Here's how to open an Item Significantly not as Described Case:
1. Go to your "My eBay" page.
2. Under "Account" (or "My Account"), select "Resolution Center."
3. Under "I bought an item," select "I received an item that does not match the seller's description."
4. Click "Continue."
5. Enter the item number or select from your recently won items using the "Find Item" button.
If you click "Find Item," you'll get a popup window. Simply select the item, then click "Continue."
6. Click "Continue."
7. In the "Describe the case" page, select the payment method you've used to pay for the item, select the payment date, then click "Continue."
8. Review the tips provided. Click "Continue," if you're sure you want to submit the case.
May 16, 2010 | eBay Auctions
Canoscan Lide 30 compatibility with Windows 7.
There are no official drivers for CanoScan Lide 30 for Windows XP, so your problem is obvious. I suggest you sending an e-mail at Canon including details about your scanner (date purchased, serial number in text form or scanned) asking them to develop driver set as this model is very trade and at shops since 2006 or 2007.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Feb 27, 2010 | Canon CanoScan LiDE 30 Flatbed Scanner
Macromedia dreamweaver to crate menu bar
  1. Load your index.html page as before. That is, doubleclick the file in the Files pane in the right column.
  2. Locate your existing navigation menu, which at this time merely consists of a series of links to your home page, About Us page, Contact Us page and the Site Map. Select them and delete them. We will be completely replacing them in this chapter.
    1. Make sure that the blinking text cursor is currently in the side bar. If it is not, click somewhere in the side bar. Now click "Insert | Spry | Spry Menu Bar" from the menu. That is, click the "Insert" menu, then the "Spry" item on the menu that appears, and finally on "Spry Menu Bar" on the submenu that appears.
    2. A dialog box will appear asking you whether you want a horizontal menu bar or a vertical one. Since we are placing the menu bar in the left column, we want a vertical menu bar. Select the "Vertical" option and click OK.
    3. A default menu bar will be inserted into your side bar. If you look at the Properties pane at the bottom of your Dreamweaver window, you will see that the text and links for menu items are displayed there.
    4. Select "Item 1" by clicking on it, if it is not already selected. In the "Text" box, replace the words "Item 1" with "Home" (without the quotes). Replace the default "Link" text of "#" with "index.html" (without the quotes).
    5. By default Dreamweaver created a submenu for your menu. We don't need one, so we will need to delete it. Select "Item 1.1". Directly above "Item 1.1" are two buttons "+" and "-". Click the "-" item to delete Item 1.1. Do the same for "Item 1.2" and "Item 1.3".
    6. Now do the same with the other items, replacing the text with the appropriate words for your site, and the links with the actual page names. If there are submenus, delete them as you did for Item 1. For your convenience, the replacement text and links are reproduced below from chapter 3. Note that Item 3 has a three-level menu system. Delete all submenus (item 3.1.1, 3.1.2, 3.1, 3.2, 3.3) - we won't need them.
      • Text: About Us, Link: aboutus.html
      • Text: Contact Us, Link: feedback.html
      • Text: Site Map, Link: sitemap.html
    7. Click "File | Save". A dialog box will pop up telling you that certain files have been added to your site, and that these files will need to be uploaded. Click "OK".
    8. Now upload the page to your website using "Site | Put" and check the results in your browser. Hover your mouse over your menu buttons, and you will see that they change colour.
    Customizing the Spry Framework's Menu Bar Widget While adding the Spry Framework's navigation menu bar to your web page is a simple procedure under Dreamweaver, customizing it is, however, another cup of tea. There is no built-in method to do so under Dreamweaver's user interface. You will have to do it manually.
    The fastest way to do this is to do it via Dreamweaver's "Code" view.
    Dreamweaver has two basic ways you can work on your website. So far, you have been creating your site using the "Design" view. The "Design" view allows you to work on your web page using the What-You-See-Is-What-You-Get (WYSIWYG) editor - that is, as you create your web page, you basically see the page as a visitor would when they visit your website.
    The "Design" view hides the real code, the HTML and CSS code, that Dreamweaver generates for your website. This code, the "raw" code, if you will, is the actual content that is uploaded (published) to your website. When your visitor loads your web page, the browser takes the "raw" code and displays it according to the instructions given in the "raw" code.
    To customize the Spry Framework's menu bar widget, you will be using Dreamweaver's facility for viewing this "raw" code for your website. Even if you find the menu bar widget satisfactory at the moment, you should still take the following steps to familiarize yourself with Dreamweaver's "Code" view. You will be using the Code view in a future chapter to insert your feedback form code.
    To switch to the "Code" view, click "View | Code" from the menu. Instead of the web page that you are accustomed to viewing, you will now see the "raw" HTML code for that page. If you scroll up and down the page, you should be able to see your content amidst other characters. These other characters, things like "<p>" and the like, are the formatting code that tells the browser how it should render your page.
    Centering the Menu Bar Scroll to the top of the index.html file in "Code" view. Locate the text "</head>" (without the quotes) somewhere near the top of the file. Place your cursor just before "</head>" on the same line. Hit ENTER (or RETURN) to insert a blank line. When you do this, the entire line with "</head>" should move downwards, creating a new blank line. Move the cursor to the blank line.
    Now copy the text from the box below and paste it into the blank line you just created in Dreamweaver. To copy the text, select all the text in the box with your mouse, click the right mouse button (or if you use Mac OS X, hold down the Control key on the keyboard and click the mouse), and select Copy from the menu that appears. To paste it into Dreamweaver, switch to the Dreamweaver window. Make sure that your text cursor is in the correct location (in the blank line above the word "</head>"). Select "Edit | Paste" from the menu. <style type="text/css">
    ul.MenuBarVertical
    margin: 0 auto ;
    width: 8em;
    </style>
Jan 22, 2009 | Macromedia Dreamweaver MX 2004
Need to Add Dates in Excel
Here is one way I just tried:
Say the date purchased is in A1.
You want the Est Life in A2.
In A2 type: =A1+(3*365)
That will add 3 years.
For 5 years: =A1+(5*365)
Try it out!
Note: You will need to format the cells to Custom>mm/dd/yyyy
Nov 21, 2008 | Microsoft Excel for PC
Cr-180 Won't Detect Checks
Embarassingly enough, a reboot took care of the issue! Duh.....
Apr 04, 2008 | Canon CR-55 Pass-Through Scanner
Text Message Can Not Be Sent
Empty files from deleted items folder and ensure that your phone internal memory is not full.This should help.Shalom!
Mar 25, 2008 | O2 Xda Trion Smartphone
Canon CR-55 Pass-Through Scanner Logo
427 people viewed this question
old marine
old marine
