Question about Maytag MSD2754G Side by Side Refrigerator
Dispenser not responding
Hi, I just purchased a used msd 2354 and the ice maker works fine making and dropping ice however the door dispenser for water and ice are not responding. There is no clicking or any noise coming from the unit. I cleaned the ice bucket and made sure there was nothing blocking ice. there is no water or ice dispensing. thanks in advance
    Problem Solver:
  • 8 Answers
On mzd2766 there is a solonoid type switch that goes bad. Could be your problem too.
Posted on Apr 30, 2009
Ice maker not dispensing, makes ice everything else works fine.
Open the ice storage box...ice will jam up not allowing the ice to drop down the shute.....
Mar 02, 2012 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker has stopped working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
689sshg
May 14, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker not working on Kenmore Model # 106.54563300 Water comes through water dispenser fine Water came pouring out through ice dispenser door so I flipped bar up to turn it off Removed front box held in...
First the arm has to be in the down position. It sounds like you said theres water in the ice maker. If thats the case then it should have frozed. The ice cannot drop unless the ice maker heater comes on. Then the ice maker scoops the ice and drops into the resoviour thingy. If you have ice in the ice maker tray but no ice in the bucket then the ice maker is defective.
Mar 25, 2010 | Kenmore Freezers
heatman101
sfhgsyw54
Mar 24, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water dispenser works, ice maker makes ice but doe not dispense
Remove the ice bucket/container from inside the freezer compartment. Examine underneath at the front of the container to see if ice cubes are lodged between the metal blades. If cubes are caught in this area, they will prevent ice from dropping into the glass/cup.
Feb 22, 2010 | KitchenAid Superba Architect KSCS25INSS...
Maytag MSD 2432GR Water not feeding into Ice Maker
one possible solution is that the ice maker water valve has failed (solenoid). I would try switching the wires on the water valves and see if water goes into the ice maker when you push the water dispenser button, if it does the valve is ok. If you go this far go ahead and fill the ice maker with water ( about half to two thirds full) switch wiring back as first found and see if maker will freeze and dump ice, if it does ok, if not the problem is probably in the ice maker.
Jul 06, 2008 | Maytag MSD2436GR Side by Side Refrigerator
The icemakers won't make ice if the temperature is not below a certain set point. Varies between manufacturers. Try making the temp colder.
Feb 01, 2008 | Hotpoint HSS25GFP Side by Side...
Ice Maker
I would be happy to help. When you say it stop dispensing, do you mean it didn't drop the ice into the bucket or it didn't dispense thru the door? Also, make sure the arm on the icemaker is completely down. Fridgidaire has had some problem with the arm not coming down all the way and leaving it in the off position. Let me know so I can help.
Nov 11, 2007 | Refrigerators
Maytag MSD2754G Side by Side Refrigerator Logo
250 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
