Question about Panasonic KX-TG2120W Phone
Phone keeps ringing
My phone keeps ringing without any incoming call or anything for that fellow said that it was do I unlock it!??!
0 characters
1 Points
How to get incoming calls to two handsets
The system should be configured so that the desired lines, whether CO or extensions, are set to "Appear and Ring" on each set.
Config... Terminals&sets... Show Set... (enter #)... Find...Line Access... Line Assignments... Show Line (enter #)... set to "Appear and Ring" on each set that needs to ring.
You can also have a line "Ring Only" without an appearance (dedicated button), in which case it will show as an intercom call.
Sep 25, 2014 | NorStar T7316E Telephone
Phones do not ring with incoming calls
Check make sure ringer is turned up,push speaker button then push volume button a volume thing should show up on the screen,keep pushing volume button and it will. Increase the volume.ty.
Feb 15, 2014 | Panasonic KX-TG2632 Twin Cordless Phone
Some 816 phones won't ring on incoming calls
To change the ringing on a prostar 816 you first need to be at a display set (doesn't matter what the extension number is).
with the handset down, enter #20 the screen should say MMC DISABLED
enter in 1 2 3 4 1 # (that enables programming)
enter in #62 the screen should say day ring assn
press the line you wish to program
press the buttons for the extensions that you wish to ring (the ones in the right next to the handset)
press # when finished with the line
repeat steps 2 through 5 for the remainder of the lines you wish to change
press # when finished.
Jun 05, 2010 | Samsung Prostar 816 Phone
Phone does not ring incoming calls it seems locked
Check if it is on vibrate mode.
May 04, 2009 | Phones
Phone flashes but no volume for 4 rings on incomming call
The phone has to be a member of an ICD group and have the ring set to immediate. Since this is a SYSTEM program, I don't think you can change it without the assistance of a programmer.
If you somehow have access, it's changed in programs 620-622. You need to know which group is assigned, usually group 1 put you can find that in 622. Members are set in 620 and the ring delays are in 621.
Apr 02, 2009 | Panasonic KX-T7633 Corded Phone
Comdial Executech 6414 won't ring
DX-80 Comdial After power outage only Phone # 1 rings, i turned off for 1 min but no luck, any ideas?
Feb 24, 2009 | Comdial Executech 6414 Corded Phone
My BT Verve 450 digital phone set won't ring out /incoming call
bt cordless phone i have pressed something and it has locked can anyone tell me how to unlock it
Dec 08, 2008 | Uniden Cordless Phone
KX-T7730, all the phones connect with operator ring at the same time when having an incoming phone
please i need your help,i use KX-T7730 in my office and of recent when incoming calls comes in all the phones in the office starts ringing and also i would like to know how i can lock and unlock the phone so as to prevent other users from accessing it.Thanks
Apr 10, 2008 | Panasonic KX-T7730 Corded Phone
Uniden 5.8Ghz phone.
You need to reset the main base unit. Unplug the power from the back of the base. While the power is disconnected, press and hold the delete key while reconnecting the power. Wait for a long beep tone. When the display shows 88 or P, press play button one time. If you have a phone without an answering machine, disconnect the power from the back of the base, press and hold find hs button while reconnecting power.
Jan 20, 2008 | Uniden Cordless Phone
Panasonic KX-TG2120W Phone Logo
18 people viewed this question
Top Panasonic Phones Experts
Are you a Panasonic Phone Expert? Answer questions, earn points and help others
