Question about Pine Technology GeForce Mx4000 (64 MB) AGP Graphic Card
AGP Card Problem (nVidia MX 4000 128MB)
I install the card on a MSI motherboard with a pentium D processor and 512 MB ram installed.It has an AGP slot, when i use the card it does give video during the boot sequence, but as the windows logo appears the screen goes balnk and the monitor says check signal cable. Can you guys help me ,Please
  • rohit2508 Aug 18, 2007
    Thanks A Lot Sandrew, U r gr8 !
    President:
  • 2,961 Answers
You will have to set the agp card as the primary graphics device in the bios, either press F2 or Del on boot up and in advanced cmos settings, look on the list for hardware or similair and you will see that the primary graphics controller will list as VGA, change this to agp and then save settings and exit, it should then boot as normal. The only other thing is if you have removed a graphics card previous to fitting this one and you have left the old drivers on your pc, this will cause conflict, so if this is so refit the old card and then uninstall the old drivers and then shut down the pc and refit the new one.
Posted on Aug 17, 2007
SOURCE:
Vga card
Look for a AGP x8 graphics card with 512mb memory. Or more.
Jun 18, 2013 | ASUS P4VP-MX Motherboard
What would be the best compatible 512 MB GPU(with shader 3 or 4) working with P4I45GV 3.00 /P4 2.4 GHZ/1 Gb ram ?
http://www.asrock.com/MB/overview.asp?Model=P4i45GV%20R5.0
Any of them Shubham.
If we are to discern by a few known statements;
1) It is believed in some 'geek communities', that using the same manufacturer of motherboard chipset, and graphics chipset; to be a good thing.
For example an AMD motherboard chipset 'plays well' with an AMD ATI graphics chipset;
Nvidia motherboard chipset 'plays well' with Nvidia graphics chipset.
Intel motherboard chipset with Intel graphics..............no wait,....... there is no Intel graphics chipset, unless it is -> Integrated Graphics.
[ Intel GMA ]
(Integrated Graphics is also said as OnBoard graphics. ON the motherBOARD)
2) DOES NOT MATTER what graphics memory type is used.
Motherboard can use DDR Sdram ram memory, and graphics card can use GDDR5.
Why?
Because the graphics card has it's own Processor, and Ram Memory.
Graphics Processing Unit, or GPU; is the Processor,
http://en.wikipedia.org/wiki/GPU
Graphics memory is the ram memory.
Operates independent of the system resources.
The graphics expansion slot on the P4I45GV (P4 i 45GV), is an AGP slot.
Accelerated Graphics Port,
http://en.wikipedia.org/wiki/AGP
It will use an AGP 4X, or AGP 8X graphics card.
Use an AGP 8X.
http://www.tigerdirect.com/applications/SearchTools/search.asp?keywords=agp+graphics+card+512mb
REMEMBER;
1) ALWAYS follow Anti-Static Precautions.
2) INSTALL the software for the graphics card F-I-R-S-T,
(Drivers and 'control panel')
THEN unplug the computer from power, follow Anti-Static Precautions, and Physically plug the graphics card into the motherboard, and install.
3) [email protected]@k at the system requirements (Minimum) for the graphics card.
Specifically the Power Supply requirements. You need a Power Supply with enough Wattage, to handle the graphics card.
[ Handles the graphics card, and -> Motherboard, Processor, Ram Memory, and peripherals; Internal and External.
{Harddrive/s, optical drive/s; Internal
Mouse, Keyboard, external harddrive, etc; External ]
For additional questions please post in a Comment.
Regards,
joecoolvette
Nov 17, 2012 | Computers & Internet
I have an ASRock Motherboard M 266A, 512 Mb of ram and Nvidia GeForce 4 MX 440 with AG P8X. Kindly could you tell me if I can upgrade my computer with a better videio card and what is the name or type? I...
nvidia 9600gt agp version 512kb vram.
if you get a card with 1gig of ram on it, you would have to have at least thqat much, 1gig, installed into your system ram as well.
Nov 23, 2010 | Asrock M266A Motherboard
AGP Card MSI MS-StarForce GeForce FX 5200 undetected.
for agp motherboards, you have to install agp mobo drivers, before you install the actual video card drivers.
May 25, 2010 | MSI MS-6734-10 (-6734-010) Motherboard
My motherboard is IntelD845PESV. i use 512 mb DDR 1 RAm & 64 mb Nvidia Geforce 2 Mx/Mx 400 AGP card. Now, i want to upgrate the AGP and RAM . In the intel site maximum RAM supported by this...
Look in the BIOS, under the video ram settings. What is the largest RAM it can handle? 128? 256? 512? This will give you an indication as the size of video RAM that you can have on your card.
Hope this helps.
Nov 09, 2009 | Intel D845PESV Motherboard
Need to increase the ram on the VGA Card
My friend you can add RAM on your VGA by purchasing another Higher Video card  RAM. you can buy 512mb (265 - 512 bit) VGA Card to increase your VGA RAM.
Jun 18, 2009 | ASUS P4P800-X Motherboard
Cant log on xp.
hi..if u want to run as good that VGA u need to set in the Bios as init fist display as AGP then find what AGP size appear on bios..if this all OK try to booting the system..thanks and Good Luck..^_^
May 11, 2009 | NVIDIA GeForce 5500 / 128MB DDR / AGP 8x /...
Hi i have a asus P4s533-mx and with a 3GHZ processor and with a geforce6600 (agp) and the games tend to freeze and i have to reboot my system?. any help please
It is the video card. Newer games are so graphic intensive that they freeze up the system if there is not enough video memory. You could try upgrading RAM but I had a problem running newer games until I installed a graphic card that had at least 512 mb video ram onboard. Hope this helps.
Jan 10, 2009 | ASUS P4S533-MX MB, DDR+SDR/ VGA/ Audio/...
Memory dump.
It dumps coz you havent enough of memoy, instal at least 512MB more and you will get rid of that problem
Good luck to you
Dec 30, 2008 | MSI KT2 Combo-L Motherboard
Need suggestion
there is an agp card for 512 but that is high as agp goes you will spend anywhere from $100.00 to $400.00 for the card depends on frame rate pixel pipelines stc
I like evga, msi, mid price range but good warranty
Oct 17, 2008 | Intel Motherboard
Open Questions:
See all Pine Technology GeForce Mx4000 (64 MB) AGP Graphic Questions
Pine Technology GeForce Mx4000 (64 MB) AGP Graphic Card Logo
250 people viewed this question
Top Pine Technology Computers & Internet Experts
EKASYS IT SERVICES
EKASYS IT SERVICES
Alun Cox
 Ian Kayhan
Ian Kayhan
Are you a Pine Technology Computer and Internet Expert? Answer questions, earn points and help others
