Question about Nokia N70 Cellular Phone
Nokia N70 Music verson
Mobile network will go off frequently and show only 3G though the location has complete network coverage?.. Also frequently voice disconnection during the conversation.
    Problem Solver:
  • 8 Answers
Try to remove your memory card then switch off your phone, because of to much data that have been in store to your phone cannot easily activate his 3G. the best thing do not insert memory card to your phone when communicate other people using your phone.
Posted on May 03, 2008
    Sniper:
  • 91 Answers
Remove the network switch and change it. or in case u dont have the network switch then join the first two points on the right hand side and continue the same wire with left hand first point and forth point
Posted on Aug 23, 2007
SOURCE:
My mobile has a special problem. The mobile shows a weak signal and sometimes zero signal at my home even though the other nokia mobile signals are very high at my home.(same network other nokia mobile...
Are they the same models?
The phone's capability to sustain a stable network coverage may vary even in model types.
While at your home,remove the phone's battery and simcard and fit them again.
Note how the phone's network signal registers.
It may start very high and then drop drasticaly to very low or no signal at all or sustain a constant signal reception.
If the reception's good in other areas,then your home area's network coverage may not be that good.
Hope this helps.Thanks!
Oct 31, 2011 | Nokia Cell Phones
I m new beginner in hardware field guide me how i check signal fault in any mobile guide me sir pl
Hi Buddy,
Signal has a wide range field or area in diagnosing a network problem,it depends the situation on what happen to the phone,weather it was watered damage,drop off the ground or suddenly lost network.
Let's start with the Software Problem
* check your network settings if set to DUAL mode,it means you've 2G or 3G signal,if this mode is far away from your area or out of coverage,you will experience signal dropping, If you are not using 3G signal,better switch to GSM mode and it will stick the signal along your area.
For Hardware Problem
* Base on source and latest issues about signal problem is by replacing 2n2 capacitor,before reheating or removing some main parts like PA (Power Amplifier) and other IC,better focus on this capacitors,Here is a illustration and have a look were it is located
* For no access,change the upper part.
* For no network coverage, change the lower part.
For the meantime,just stick with this solution before doing hardware modification,If you have some questions,don't hesitate to reply,i will give more ideas regarding signal problem.
Thank you for visiting FixYa.
Jul 24, 2011 | Nokia N70 Cellular Phone
How can i use my vidoe call in my mobile
first of all use a 3g network sim card and be in 3g coverage area then
go to setting
Network settings
change network mode sitting to 2g & 3g
then test the video call
Apr 18, 2011 | Nokia 6120 classic Cellular Phone
How do i turn my 3g on my galaxy s
3g service is activated when you enter a 3g network. 3g networks are in select cities, refer to your wireless carrier's website to see where the closest 3g area is to you.
Here are a few quick links to coverage maps by carrier:
Verizon: http://www.verizonwireless.com/wireless-coverage-area-map.shtml
AT&T: http://www.wireless.att.com/coverageviewer/#?type=voice
T-Mobile: http://coverage.t-mobile.com/default.aspx?MapType=Data
Sprint: http://coverage.sprint.com/IMPACT.jsp
Mar 02, 2011 | Cell Phones
Nokia N 70 Music edition IMEI number 351863016298354
This is a security master code for your mobile: 2461756705. I hope this helps.
peace.
Feb 28, 2011 | Nokia N70 Cellular Phone
I could't download youtube videos with my lg cookie plus 3g mobile
Although your handset is capable of 3G speeds. The speed itself and the coverage you are recieving is dependant on many things. You could be in a location where there is only 2G masts, in which case the youtube videos will show buffering and will more than likely time out, due to 2G not being adequate for streaming.
The 3G network in your location could be down or some of the BTS(sites) in your location could be working at a degraded capacity and in need of repair by your network. This is something you can find out by calling your network who will be able to give you information or inform there network and devices teams of possible problems in the area.
The 3G network in you area could also be very busy in your location and it can also come down to things as simple as environmental issues.
If your SIM care has not provisioned for 3G coverage or is not a 3G sim this will also stop you from recieving 3G speeds, all this information you can get from you network provider.
Nov 16, 2010 | Computers & Internet
N70 network problem
its shows 3g when there is no network coverage , its just an indication that the mobile is a 3g enabled mobile. if it continues there might be a possible hardware problem.
Jul 04, 2010 | Nokia N70 Cellular Phone
My mobile N70 failed to find network and show 3g in place of network tower
there may not be any problem at all ,
as 3g is notorious for sometimes bad and very patchy network coverage ,so it may be a network problem rather than your phone
i know a few people who have similar issues with all ranges off phones from nokia,sony erricson,samsung blackberries etc.
if problem persists ring 3g from a land line to find out about the network coverage and if they have known issues/problems
May 19, 2009 | Nokia N70 Cellular Phone
How to connect N70 to Video Call
hi
you have to activate the service from the company.
i hope this will work
Jan 03, 2009 | Nokia N70 Cellular Phone
Network problemin Sony Ericsson W380i where as the same SIM card in NOkia works fine
It is better to replace your phone with new one as you have bought recently. contact your retailer.
Oct 29, 2008 | Sony Ericsson W380i Cellular Phone
Nokia N70 Cellular Phone Logo
124 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
