Question about Dell E173FP 17" LCD Monitor
Display is extremely large
I purchased my Dell monitor a year ago and from the very beginning, some websites displayed differently than on other computers. The problem is that the images and fonts are much much larger than they should be. I have tried changing the size of the text to the smallest to no avail. I called Dell 3 times about this problem and each time they told me there was nothing wrong. I work on several different computers (one at my place of work) and they all display the familiar websites I frequent the same (normal)way. Also, on certain websites, such as Yahoo home page, the lines and outlines are missing on my Dell screen.
  • 661 Answers
This sounds like your resolution is set too low, right click on your desktop and select properties Choose the settings tab from the window that appears, then you should be able to see a slider that tells you your screen resolution. This is most likely set to 640 x 480, the setting you want should be in the region of 1024 x 768 If you are unable to change this setting, you need to check that your display adapter drivers are installed properly in "Device Manager"
Posted on Aug 17, 2007
SOURCE:
Laptop LCD monitor (needs advance help) I have a Dell m5010 laptop that started to display small vertical lines from that bottom left corner going up to the top right corner. I plugged the laptop up to...
Try a different resolution in the monitor to see if that helps. You can do this by right clicking on the desktop and changing the resolution within the screen properties. If that does not make a difference, try searching for updated display drivers either through the laptop manufacturers website or its possible you have a bad controller board for the LCD screen.
Nov 25, 2014 | Computers & Internet
My Dell E173fp monitor display doesn't work with my macbook
The fine print says it should work. Real life might be different. Do you have a genius bar, found at Apple stores, anywhere close? If so, make an appointment and let them make the connection for you. The genius bar is a free service and I've never found anything that they haven't been able to fix...and fix it quickly...if it's fixable.
Apr 17, 2017 | Dell E173FP 17" LCD Monitor
A red line appeared vertically, is this a hardware problem?
I would go back where it was purchased and press the issue, since it is so close to the warranty time they may make exception, because the alternative is replacing your monitor. There is a large printed circuit board on the back of the LCD that processes the video and colour images that has become defective and is part of the LCD display.
Apr 24, 2012 | Samsung Syncmaster 2033SW Monitor
Hi I have HP dv6767tx laptop which i purchased in april 2008 But 1 year ago, all of a sudden a bright strip around 1 to 2 inches in thickness appeared on the extreme left of the lcd screen. Affected...
very sorry to tell you that the lcd has gone bad because your laptop shows exact symptoms of this case.
As per what some HP costumers have told me HP takes this as a physical damage and does not give them a warranty even if it is in the warranty cover
Finally you will need to get it replaced
This is the most expensive fix after a motherboard and may cost you $180 or 8000-9000 INR
Jul 26, 2011 | HP Computers & Internet
I have an old (5 years) DELL PC with a CRT monitor. Of late the display has on the screen appears to be vibrating a little. This is causing eyestrain. The brightness, clarity & colours of the display...
The monitor is probably faulty. To determine if the monitor or the video card is faulty, connect a different monitor to your DELL. If the image is OK on the other monitor then the other CRT monitor is faulty. Repairs to the CRT monitor may not be a cost effective solution, I suggest you buy a LCD monitor.
Feb 05, 2010 | Dell Dimension 3100 PC Desktop
Dell E153FP monitor won't display any video from system (Dell GX260). My e173FP monitor works fine. E153FP powers up, runs Self Test Feature Test fine, menus all seem OK. Tried Factory Reset... still no...
You probably have tried this, but make sure monitor is set to correct display... i.e., Analog or Digital
Also, try starting in safe mode and verify Monitor is able to handle the display settings resolution
I’m happy to help further over the phone at https://www.6ya.com/expert/steve_52488d61fac93877
Apr 10, 2017 | Dell E153FP 15" LCD Monitor
Dell 2405FPW LCD Severe Flickring
The symptom you describe is typical of a thermal problem in the display. It might be in the LCD panel itself, in which case the only repair is to replace the display. It could also be in a component on the main board, and spray component cooler can be used to selectively chill parts to see if it has any effect. Even then, though, it's usually large-scale integrated circuits on these board that have go bad. Even if you can find a source for the part, changing it normally requires tools and techniques beyond almost every shop. Even the manufacturers "repair" these by simply replacing the entire board.
Sad to say, if this isn't covered by some kind of repair warranty, replacement might be your only option.
Dec 17, 2008 | Dell UltraSharp 2405FPW 24" Flat Panel LCD...
Dell Vostro 1710 display problem
Hello My Dell Vostro Laptop Display Not Working Correctly it showing Dim but in other desktop when i connect to the Laptop Of Mine it showing Correctly With No Dim Problems? How can I fix the Problem?
Nov 19, 2008 | Dell Vostro 1500 Notebook
Display is upside down
AN EASIEST WAY IS HOLD THE CTRL AND ALT KEYS,AND CLICK THE "UP" KEY
Jun 02, 2008 | Dell E173FP 17" LCD Flat Panel Monitor
Dell 17inch LCD Display - Blank
Hi, My name is Todd and I'm a customer advocate at Dell's corporate headquarters. My team helps customers via blogs, forums, and other tech sites online. You said the monitor is 2 years old. Do you have the original order number still? Depending on how you purchased the monitor it may have up to a 3 year manufacturer warranty and I may be able to replace it if it is within that warranty period. Please email me at Customer_Advocate@Dell.com if you can locate the order number and I'll be glad to see if its still under the manufacturer warranty. Include my first name (Todd) in the subject line of the email so it can quickly be routed through to me, and include the order or customer number if you have it. Thank you, Todd Customer Advocate Dell, Inc. http://direct2dell.com/one2one/archive/2006/11/19/3648.aspx
Apr 25, 2007 | Dell E173FP 17" LCD Monitor
Dell E173FP 17" LCD Monitor Logo
59 people viewed this question
Clive
Clive
Alun Cox
