Question about Dell OPTIPLEX GX110/200 PIII-866MHz 256MB 20GB (PCPIII866DELL) PC Desktop
Non working of mouse
When I starts the computer the will not move.So I go to device manager and take properties of mouse and fix the problem. then it works. again I restart or start the same problem will be there.The change made is not permanantally saved.
    Problem Solver:
  • 9 Answers
Get microsoft standard mouse driver download and install....
Posted on Aug 16, 2007
SOURCE:
Can I set my Pryon computer wake up by moving the mouse?
Normally that is controlled by the Operating System, though most non-mobile PC's have the ability to allow/restrict 'wake-up' devices as well.
to check if your OS is set that way : (for windows 7 )
Click the round Start button,
Right-click [computer] then click on "manage"
When the 'Computer Management' window opens, click on Device Manager
Next locate the Mouse section and click on it to expand it.
Right-click on the mouse device listed and click on 'properties'
you will see a 'check-box' that provides the ability to allow the device to 'wake-up' the PC. If it is NOT checked, then that is likely why it is not working, and you will need to click on it to 'check-it'.
Oct 13, 2014 | Computers & Internet
When i start my computer it works well but after few minuits the mouse strucks but the key board works properly what is the problem?
make sure the lead has a secure seating if applicable or the usb device
you might have to uninstall the mouse and its drivers then restart your computer then reinstall the mouse and its drivers
click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver
click start control panel mouse you should see 4 tabs buttons pointers pointer options and hardware under hardware you have options to troubleshoot also you can select properties under driver you will have the options update driver rollback driver or uninstall in xp
click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver in
make sure the battery is good ((has full charge))also you might test the usb device for the mouse is inserted correctly into the usb port (if applicable)
Windows 7
hope this helps
Jun 18, 2011 | Televison & Video
While booty up computer screen freezes and mouse is not working. If you options to go to safe mode but mouse or arrow signs do not work, nothing on the key board works
try blowing out all of the dust from your keyboard using a fine air blower from an air compressor making VERY sure there is no MOISTURE in the lines.
dust causes static which causes lots of problems with a computer and its parts
or if this does not fix the problem
click start control panel administration tools computer management device manager scroll to keyboard you might see a yellow question mark ? right click to update driver
or you might have uninstall the keyboard then restart your computer then reinstall it and its drivers
click start control panel keyboard hardware then properties you hould see driver details and have options to,update driver,roll back driver,uninstall
if your computer came with a motherboard disc the drivers could be on it
diconnect the keyboard then reconnect it then reinstall the driver
hope this helps
Windows 7
hope this helps
May 16, 2011 | Computers & Internet
V470 logitech bluetooth mouse has orange light instead of blue and won't connect computer says it working properly
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you have options to troubleshoot also you can select properties under driver you will have the options update driver,rollback driver or uninstall in xp
Windows 7
hope this helps
May 04, 2011 | Computers & Internet
My wireless mouse is not working the red light at the bottom of the mouse blinks
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot also you can select properties under driver you will have the options update driver,rollback driver or uninstall and under hardware you can troubleshoot
in xp
make sure the battery is good (has full charge)also you might test the usb device for the mouse is inserted correctly into the usb port (if applicable)
Windows 7
hope this helps
Apr 14, 2011 | Computers & Internet
My mouse on the laptop is locked it wont move
click start control panel administrive tools computer management device manager scroll to mice and pointing devices + to expand right click you will the options to update drivers software, disable, uninstall scan for hard ware changes and properties select properties you will see more tabs,generaldriver,details,and power management.
select the driver tab you will have similiar options driver details,update driver,disable and to uninstall
you might have to uninstall the mouse and its drivers then reinstall them
in xp
hope this helps
Jan 13, 2011 | Computers & Internet
My logitech mouse wont move
You need to install the driver for your logitech mouse to work.
If your mouse is not recognized then follow the following steps,
To work around this issue, try one of the solutions below:
  1. Unplug the USB device. It is possible that the connection is not secure and has become loose. This is one of the most common reasons for an error in detecting a USB device.
  2. Use the Device Manager to scan for new and recently installed hardware. From the start menu, select the 'Run' option. In the pop up box, type in Devmgmt.msc and then click 'Ok'. From the 'Action' Mmnu, click 'scan for hardware changes'. This will make Windows recognize any new devices that are installed. Now, close all device managers and control panels. Now see if your computer will read the USB device.
If that doesn't work, here is another option you can try:
Disable power management of the USB hub. To disable the power management on the USB hub, follow these steps:
  • Click Start, and then click Run.
  • Type devmgmt.msc in the Open box, and then click OK.
  • Expand the Universal Serial Bus controllers' node, and then follow these steps for each USB Root Hub that is listed:
  • Right-click the USB Root Hub and then click Properties.
  • Click the Power Management tab.
  • Click to clear the Allow the computer to turn off this device to save power check box, and then click OK.
Jun 03, 2009 | Logitech Marble Mouse Trackball
Mouse wont work
check your device manager and see if there is a problem there
to get there go to
start/control panel/performance maintance/system/hardware/device manager/mice. click the + on mice then right mouse properties and make sure the device is working properly and that it is enabled. then go to update driver and see if it will update
good luck
May 20, 2009 | Dell E228WFP Monitor
Message saying alps pointing devive has stopped working, can still move mouse pointer but cant use the scroll function
A possible fix for the Alps problem Your Alps pointer problem is probably driver related. To fix it:
1. Open Windows Explorer
2. Right click on Computer & choose properties
3. Open Device Manager (Admin password may be required)
4. Under Mice & other pointing devices, right click Alps pointing-device & choose Update driver software
5. Choose Search automatically & it will download and install the latest signed driver from the windows repositories & hopefully that will fix that problem.
Jun 14, 2008 | Computers & Internet
Mouse freezes
I had the same problem. The following solution from 3M support fixed it. We Normally see this problem on laptop computers running Windows XP. There is a power management setting in the Device Manager, which controls the USB Root Hub. Often this setting is selected to "allow the computer to turn off this device to save power". When control of the mouse is needed again, the computer is unable to turn the device back on. To remove this power management feature follow the instructions below. 1. Right click on the "My Computer" Icon on your Windows Desktop 2. Select "Properties" from the Menu 3. Click on the "Hardware" tab in the system properties window 4. Click on the "Device Manager" button 5. Click on the (+) plus sign next to "Universal Serial Bus Controller" in the Device Manager 6. Locate the "USB Root Hub" (Note: there may be more than one, and you will need to change all of them), double-click on the "USB Root Hub" to access the properties windows for that device. 7. Click on the "Power Management" tab 8. Remove the checkmark from the box containing the following option "Allow the computer to turn off this device to save power" 9. Click "ok" 10. Close the Device Manager and all other open Windows Test the Mouse to be sure that the new settings are working. You should now be able to leave the mouse unused without it being turned off by the operation system.
Aug 08, 2006 | 3M LX400 Mouse
Open Questions:
See all Dell OPTIPLEX GX110/200 PIII-866MHz 256MB 20GB Questions
Dell OPTIPLEX GX110/200 PIII-866MHz 256MB 20GB (PCPIII866DELL) PC Desktop Logo
55 people viewed this question
Ekse
Clive
Clive
