Question about Uniden TCX905 Cordless Expansion Handset
Phone message on display
I have 2 of these phones. One works fine but the other says Midels vary place handset on base for registration and refer to manuel Well I dont have the manuel so what could this possibly mean?
Go to Uniden.com for manual for your base model (pdf format), and you can read the instructions for registration.
Posted on Oct 27, 2007
There is a message "Searching" on the phone, How do I get it back to working.
You might try to de-register the handset and re-register
it to the base. Be sure the handset's battery is well
charged, a weak battery can impede the registration.
( I ) To de-register the errant handset:
1. Press and hold the [END] and [ # ] keys at the same time until the screen displays
"System Reset, Deregister Handset"
2. press [select]
3. scroll to "Base Unavailable"
4. press [select]
5. display says "Not Registered"
( II ) To register the handset to the base:
1. open the base display's [menu]
2. scroll to "Register Accy."
3. press [select]
4. on the handset, press and hold [ # ] until
the handset display says "Registering"
5. In ~30 seconds, handset display will say
"Registration Complete" or
"Registration Failed".
This is described on page 22 of the manual.
A free copy of the User's Manual can be obtained
at www.manualslib.com .
Jan 15, 2016 | Uniden D16883 Phone
I cant dial out it says register HS i am not familiar with the procedure.
When you reset a handset (or if you buy a new one1, that handset displays a Handset Not Registered message. If you see this message on a handset, you need to register it to a base before you can use it.
Registering a handset
Does the handset fit in the base cradle?
Yes
No
Place the handset in the base.
The display should say Handset Registering.
1. On the base, open the menu and select Register Handset. The display should say Handset Registering.
2. On the handset you want to register, press and hold # until the handset display says Handset Registering (about 2 seconds).
In about 30 seconds, the handset display should say Registration Complete. Press TALK ( )/FLASh and make sure you get a dial tone. page29image32024
27
If...
Try...
- you don't hear a dial tone- the display says Registration Failed
Making sure the handset is fully charged, then start over at step 1.
To register a handset to a different base, see the section "Expanding Your phone" in the user's guide for the other base.
Mar 18, 2014 | Uniden DECT 6.0 Cordless Phone ID
E4 - Erros My uniden phone model TRU 9485 - 4WX after outage power, now on LCD screen appear E4 and it didn't respond to any button when i press. I read some help which they say press 3 button...
Hello
Connect the phone line and power UP the base unit. Place the handset on base to get charged. It must reset automatically when you place the handset on base to charge. If not; resetting both handset and base unit is necessary.
Resetting the Handset
You may need to reset your handset in the following instances:
You lose a handset and purchase a new one. When you try and register to your existing base you get registration
failure.
You are unable to register any handsets to the base.
You had a base which needed to be exchanged by the manufacturer. When you register your existing handsets
to the base, the handsets say #3 and #4, but you only have 2 handsets.
When you are instructed to by the one of the manufacturer's call center representatives.
To reset, do the following:
Press and hold [ ] and [#] for more than 5 seconds. Select DEREGISTER HS.
WHICH HANDSET? appears. Select the handset that you want to de-register, and press the OK soft key.
DEREGISTER HS appears. Select YES, and press the OK soft key.
ARE YOU SURE? appears. Select YES, and press the OK soft key. You will hear a confirmation tone. The
handset will clear its registration information from the base, and then delete its own base information.
MODELS VARY! PLACE HANDSET ON THE BASE FOR REGISTRATION OR REFER TO OWNER'S MANUAL. To
re-register the handset to the base (see page 25).
If the handset cannot contact the base, it will display OUT OF RANGE. Make sure the handset is in range of the
base and the base is connected to power.
Note: It is also possible to reset the handset back to its original factory settings. All changes including Caller ID information
will be erased. For more information on resetting the handset back to factory settings and when you need to
do this, see www.uniden.com or call our Customer Service Hotline. See back cover page for contact information.
Resetting the Handset without the Base
If your original base is not available for some reason (for example, it is lost or somehow incapacitated), you can still
reset the handset and use it with another base.
Move the cursor to select BASE UNAVAILABLE and then press the OK soft key.
BASE UNAVAILABLE appears.
Move the cursor to select YES, and then press the OK soft key. ARE YOU SURE?
appears.
Move the cursor to select YES, and then press the OK soft key. You will hear a confirmation tone. The handset
will delete its own base information without trying to contact the base. When the base information is deleted,
the handset displays MODELS VARY! PLACE HANDSET ON THE BASE FOR REGISTRATION OR REFER
TO OWNER'S MANUAL. Register the handset to the new base (see page 25). of its user manaul.
OK.
Sep 12, 2011 | Uniden TRU9485 Cordless Phone
I have uniden cordless phone model dxa15588-2, how do I register handset on base?
1-Press the hangup key (represented by a red phone) and the "#" key at the same time for at least five seconds.
2-Select "Deregister hs." Choose the handset and press the "Select" key (which also shows an envelope for messages).
3- Choose "Yes" to confirm deregistration. The phone clears its registration information from the base and deletes the link from its memory. The message "Handset not registered -- place handset on base to register. See owner's manual for help" now shows on the display. If you are out of range of the base, "Out of range" shows.
4-Place the handset in the base charging cradle. The phone automatically selects a new security code from those stored in the base.
5-Make sure your phone is working again after "Registration Complete" shows on the display
Hope this will Help. Thank you for using Fixya !!!
Nov 17, 2010 | Uniden Cordless Phone
I have a uniden TRU9488 preregistered handset from factory, which for years no problem, but stupid me thought "what is this register" and hid register, and now my handset won't work. followed...
What happened is you have deregistered your handset from the tru9488 base. To correct this, you must register that handset with the base. See https://www.manualslib.com/manual/185023/Uniden-Tru9488.html?page=24 for short and sweet instructions for doing this, reproduced below:.
Registering.TCX905.Accessory.Handsets,.or.Other.Compatible.Handsets If.you.purchase.an.accessory.handset,.you.need.to.register.the.handset.before.use..Only.one.handset.can.be.reg-
istered.at.a.time..Handsets.supplied.with.the.phone.are.registered.to.the.base.by.the.factory..When.charged,.pre-
registered.handsets.display.a.handset.ID.number..Handsets.that.have.not.been.registered.display.MODELS.VARY!.
PLACE.HANDSET.ON.THE.BASE.FOR.REGISTRATION.OR.REFER.TO.OWNER'S.MANUAL..(If.an.accessory.
handset.has.ever.been.registered.to.a.base,.you.must.reset.the.handset.before.you.can.register.it.to.a.new.base..
See.Resetting.the.Handsets.on.page.24.)
When.you.register.an.extra.handset.to.the.base,.the.handset.ID.will.be.assigned.
M o d e l s v a r y !
P l a c e H a n d s e t
o n t h e b a s e f o r
1)
Before.registering.the.TCX905.or.other.extra.handset,.the.battery.pack.MUST.be.charged.for.5-20.hours.
2)
With.the.base.in.standby,.press.the.MENU.soft.key.
3)
Move.the.cursor.to.select.REGISTER.HANDSET..Press.the.OK.soft.key.
4)
On.the.handset,.press.and.hold.[#].until.you.hear.a.beep.
5)
While.the.handset.is.registering,.HANDSET.REGISTERING.will.appear.in.the.dis-
play...
When.REGISTRATION.COMPLETE..is.displayed;.the.handset.has.been.registered.to.the.base...
If.REGISTRATION.FAILED..appears,.please.try.these.steps.again.
Aug 10, 2017 | Uniden TRU9488 Phone
Setting up my outgoing message: just purchased Uniden cordless DECT 1580. Manual says select command 8. How do I find Command 8? thanks, joan
please follow the instruction to register the handset to base
To register a DCX150 accessory handset:
1. Charge the handset completely.
2.Place the handset in the base cradle for about thirty seconds. Handset Registering will appear in the LCD.
3.When the handset has registered to the base, the LCD will display Registration complete then show the handset ID number.
If the display shows Registration failed, repeat the process again.
To register a DCX200 or DCX300 accessory handset:
1.Charge the handset completely.
2.Disconnect the base AC adapter. Then press and hold find while you reconnect the adapter. Keep holding find until the charge LED starts to blink.
3.On the handset, press and hold # until the handset beeps and displays Handset Registering.
4.When the handset has registered to the base, the LCD will display Registration complete then show the handset
ID number.
Thanx
Jul 21, 2010 | Uniden Cordless Phone
Can not rec a dial tone, phone states no link to base move closer
If “No link to base. Move closer to base, try again.” is displayed
even when using the handset near the base unit, the handset may have lost communication with the base unit. You need to re-register the handset to the base unit.
• Make sure the base unit is not being used.
• Have both handsets and base unit nearby during registration.
• Follow steps 1–3 listed below. You have about 1 minute to complete them.
• Confirm the extension number of the handset which has lost the communication by placing the handset on the base unit or charger.
If you re-register the handset using the other handset’s extension number, the other handset will not function.
• If the handset beeps 3 times and “Error!!” is displayed, an error occurred. Try again from step 1.
• You can stop registration by pressing [OFF] on the handset, and pressing [LOCATOR/INTERCOM] on the base unit.
1 Base unit: Press and hold [LOCATOR/INTERCOM] until a beep sounds.
• The CHARGE indicator flashes.
2 Base unit: Press the extension number [1] (handset symbol 1 ) or [2] (handset symbol 2) of the
handset which has lost the communication.
3 Handset: Press and hold [FLASH/CALL WAIT] until “Handset Registering” is displayed.
• When registration is complete, a beep sounds from the handset and the display shows the number.
• Wait for 20 seconds after registration is complete while the handset establishes communication with the base unit.
Feb 23, 2010 | Panasonic KX-TG2357 Cordless Phone
My phone says no link to base but I am right beside it.
Sounds like the antenna on the base station is not receiving, or the cordless handset is not transmitting -OR- the sets have never been registered to the base station (please look up registering to base station, if the set has never been registered)
Did the cordless set work before?
The base station or the handset may just have a hick up, I would un-plug the base station and leave it un-plugged... now get all the cordless set(s), and take out the batteries from the cordless set(s). Wait for about 15 seconds for all the power to drain out of the sets, then re-install the batteries.
Once all the cordless sets are back up and working, plug in the base station and wait for about 1 minute.
This forces the base station to re-establish and link between the base station and the cordless sets.
Good luck
May 11, 2009 | Panasonic KX-TGA101S Cordless Handset
Not registered
hello there i think this is because you need to register the second handset with the base here are the instructions
REGISTRATION
Registration links the base to a cordless handset. Once a handset is
registered it can use the base’s phone connection. A cordless handset will
not operate until it is registered to the base. During the registration
process, keep the handset near the base.
1. Press the flash/program button on the base until LINK HANDSET shows
in the display. 2NO is the default setting.
2. Press the 1 number key or press the MESSAGES/CID (or) button
on the base to scroll to 1YES.
3. Press flash/program to confirm handset is linked to the base. WAITING
HANDSET REGISTRATION shows in the display.
4. Press the flash/program button on the handset until LINK BASE? shows
5. Press 1 on the handset keypad or cid/vol (or) button on the
handset to scroll to 1YES.confirmation tone when the handset is successfully linked to the base.
6. Press flash/program on the handset again to confirm. You will hear a long
please leave rating if you find this usefull hope this helps thanx for using fixya!!
Jan 26, 2009 | GE 27958GE1 Cordless Phone
Doesn't anyone have an answer or some help? Please!!!!
Uniden TRU8885-2 Cordless Phone > User Guide E X P A N D I N G Y O U R P H O N E w w w . u n i d e n . c o m Register the Handset to the Base If you purchase an extra handset, you need to register the handset to the base before use. Only one handset can be registered at a time. The handset ID for the supplied handset(s) was assigned at the factory, which has #1 or #2 in the display (#2 for models that have two handsets in packaging). When you register additional handset to the base, the handset ID will be assigned. 1) Before registering the extra handset, the battery pack must be charged for 15-20 hours. 2) Place the extra handset in the main base unit to begin registration. 3) While the handset is registering, Handset Registering will appear in the LCD. When Registration Complete is displayed, the handset has been registered to the base. If Registration Failed appears, please try these steps again. Extra Handset Extra Handset Charger Charger Main Base Extra Handset + Main Base Charge the handset for 15-20 hours. Place the extra handset in the main base to register. 1 2 3 4 ?An extra handset can be registered when the main base is in standby mode. ?Standby Mode - The handset is not in use and talk/flash has not been pressed.
Jun 26, 2006 | Uniden TRU8885-2 Cordless Phone
Uniden TCX905 Cordless Expansion Handset Logo
125 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
