Question about Kenmore Elite HE4 Electric Dryer
Dryer isn't turning
The button lights and timer light up when selecting dryer mode. When I select start there is a click at the door but it doesn't turn the dryer drum.
    Genius:
  • 1,153 Answers
This could be one or two things, it could be the safety switch located in door that activates the turning of the dryer. Or it could be a belt that turns the drum the motor could be turning inside and belt is broken.
Posted on Sep 06, 2007
SOURCE:
Kenmore Elite Heavy Duty King size capacity Quiet Pak 1 dryer doesn't turn on
Check to see if the door switch is working. When you push and release it, it should click. If not, it will need to be replaced.
If the switch is good, then the only other component that would cause that problem is the thermal fuse. If you could post your model number I could direct you to the part you need.
Oct 15, 2012 | Kenmore Dryers
My Dryer is a Maytag MGD5570, just under 4 years old. The dryer has power (light is on), but when I push the Start Button, nothing happens. I checked the Thermal Fuse with a continuity tester and it is not...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Feb 03, 2011 | Maytag Dryers
Zanussi TCE 7276W Condensor Dryer - no red lights but won't go!
Has the condenser been cleaned lately if it is not put back in correctly then sometimes the micro switch on the door does not click in,check this door where the condenser sits.
Hope this helps.
Mar 25, 2010 | Dryers
Whirlpool Calypso dryer GEW9868KL2
It is one or two things. Motor start switch or the motor itself.
Aug 11, 2009 | Whirlpool GEW9868K Electric Dryer
Dryer won't start after I push the Start button
If it is whirlpool--Make sure it has power. Then:Check the door switch. A little lever sticking down through top rightof door opening. If it is not there you will need new doorswitch(sometimes the little lever breaks off). If it is there and doesnot click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
May 26, 2009 | Whirlpool Dryers
Doesn't stop
The problem is probably the plunger switch that you press to start the dryer. If you select the OFF position and then move the dial to a cycle, does it start running without you having to press the start button? If so, that switch is your problem.
If you disconnect the dryer and remove the rear panel, you can unplug the switch and repair it yourself (the contacts probably just need to be adjusted) or you can replace it. Depending on the dryer you might be able to get the part number from the inside cover of the rear panel.
Apr 17, 2008 | KitchenAid KEYS750LQ Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
90 people viewed this question
Top Kenmore Dryers Experts
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
