Question about LG KG800 Cellular Phone
Bluetooth Paired Up.
How do I get my Bluetooth to Paired Up when the device has been detected by the phone? Codes are all accepted by phone and bluetooth but not connected. ST
  • 3 Answers
First turn on bluetooth and goto bluetooth settings and goto authentication and turnoff it.then bluetooth is connected
Posted on Aug 25, 2007
6ya staff
SOURCE:
Bluetooth cant detect device
when transferring between any Bluetooth device the way it works is very similar. so what it most likely is, is that the laptop isn't paired with the phone, so scan with the laptop until you find your device then select it, you will then be prompted on the phone to accept the pairing.
once you have accepted the new Bluetooth device should pop up under devices and printers
Jan 09, 2014 | ASUS N50Vn-C3S 15.4-Inch Notebook PC
How to connect bluetooth headset to my nokia c5-03 phone
Hi Madhav,
Thank you for your question at Fixya,
The solution to your problem is as follows :-
  • The blue tooth connection depends on the fact as to whether or not the bluetooth handsfree that you have is compatible with your phone or not , a good idea would be to check it before you buy one.
  • Now if you want to connect your bluetooth handsfree to your mobile , you need to first make sure that your phone's bluetooth connection has been switch on and then it's not hidden and it should be in shown to all mode as this is a nokia phone.
  • When you switch on the bluetooth connection in your phone , then you need to switch on your bluetooth handsfree and then keep it on.
  • Then again you need to go back in the bluetooth option and then select search for paired devices option or new paired device option , then the phone will search for available bluetooth connections.
  • If it detects your bluetooth , please accept that connection and then it will ask you for a pass code , which you have to enter as 0000 and then press ok.
  • That's it! you will have your phone successfully connected to your bluetooth handsfree.
Hope that helps ...:) In case you have any queries, feel free to contact me.
Sep 19, 2011 | Motorola Mobility Bluetooth Headset, Mini...
I have my bluetooth on and have tried to receive files via bluetooth from other phones and from pc and i can pair with other device but not receive files.It says paired but not connected.Is there something...
Sometimes this happens because either you or the other person changes the pairing keys or remove your mobile from his paired list.
It can be solved by unpairing and then pairing again wwith the other device.
Go to settings in your wildfire, Wireless and network, bluetooth. Long press on the device name and select unpair. Also remove your wildfire from the other device's paired list. Then scan for bluetooth devices and pair again. This should solve this problem.
Also, when some device sends you a file via Bluetooth, there is a notification asking permission to receive file. Make sure you click on it and select accept.
May 31, 2011 | HTC Wildfire Cell Phone
Connect to phone, procedure to connect to phone (bluetooth)
To Quick Pair this headset with a phone:
1. Turn on the phone, and enable bluetooth on the phone.(See specifics your your particular handset)
2. With the Plantronics turned off, press the call button for 4sec until the light flashes blue.
3. Let go of the button, the Plantronics will be in pairing mode, flashing red and blue.
4. On your phone, goto the bluetooth menu and select to ADD A DEVICE, or SEARCH/DETECT.
5. On the Phone select the "220Plantronics" device that is listed.
*Assuming your headset was already in pairing mode when you told the phone to detect it.
*If it took you over 30-60sec to do the process and you dont see the device, turn off the headset,
and restart from step 2.
6.The Passkey is 0000 when the phone asks for it, the headset will flahs blue when it is fully paired.
7. Once paired, you will only need to turn on the headset to reconnect, assuming your phone has bluetooth turned on and you have not cleared of disabled the headsets it is paired to.
Mar 01, 2011 | Plantronics Explorer 220 Bluetooth Headset...
When i bluetooth a person then it connects and they send me songs and it says reject or acceppt i accept it and it denys it why is that
It usually happens to Motorola K1 once the K1 is already paired up with another Bluetooth device, or if the connecting phone uses a different Bluetooth PIN code.
Make sure that your phone is not paired with another Bluetooth device (i.e. another phone or Bluetooth headset). Then try to use 1234 or 0000 as your Bluetooth PIN code.
If same problem occur, make sure that the two devices are within the Bluetooth wireless range (10 meters for Class 2).
If that did not resolve the problem, then there's a problem with the Bluetooth program in your phone. Contact the manufacturer and have them re-program the phone.
Thank you and good luck!
May 07, 2010 | Motorola Mobility MOTOKRZR K1 Cellular...
I am trying to pair a Blackberry 8900 to the HS830 Bluetooth device. I know the passcode is 0000. But the Blackberrry is not detecting the HS830 at all. It detects other Bluetooth items, but not this one....
Put the headset in PAIRING mode, if it has been paired with another phone, it will not accept a new pairing or another phone until you put it in pairing mode again. Press the button until the LED gets steadily ON, search the headset and pair it with the new phone. It only accepts one paired phone at a time.
Nov 04, 2009 | Motorola Mobility HS850 Consumer Headset
I cant get my iphone to detect bluetooth devices. some devices detect it but are unable to pair with the iphone 3g
Most Bluetooth devices can connect only to one device. Make sure that it is not paired with any other device. Then again, if that doesn't work then, probably the Bluetooth device is non-compatible.
Oct 28, 2009 | Apple iPhone 3G
How can i reactivate my blueant blue tooth on my motorola ic902?
Try following the below instructions, if you haven't already tried them..
First Time Pairing to your Bluetooth Mobile Phone
When you turn ON your Supertooth Light for the first time, it will automatically go into Pairing mode ready to be found by devices in Bluetooth searches. This will be the case until you have successfully paired a phone. If you have already paired a
phone, please go to the next section.
1. Power ON your Supertooth Light. The Bluetooth Indicator (3) will turn a blinking
red/blue, The kit is now in pairing mode.
2. Go to Point 3 in the next section, “Pairing to your Bluetooth Mobile phone”
Pair the SUPERTOOTH LIGHT to your Bluetooth mobile phone to create a “Pairing”
link, or audio connection between the two. This has to be only done once when first connecting each new phone.
1. From OFF, Press and Hold the Accept Button (1).
2. While holding the Accept Button (1), switch the kit on (Press-and-release the
Microphone Shaft (5)).
3. The Bluetooth Indicator (3) will turn a blinking red/blue, when you see
this, release the Accept Button (1). The kit is now in pairing mode.
4. While the kit is in pairing mode, access the Bluetooth menu of your phone. Turn on the Bluetooth function then execute a Bluetooth search, or discover. (See your phone’s manual for specific instructions.)
5. When the phone displays the list of Bluetooth devices, select ST LIGHT.
6. When the phone asks for the password, enter 0000 and press Ok.
7. Set the ST LIGHT as a trusted/authorized device, if this is option in your phone.
Important Note: The kit is now paired. Most phones automatically connect to the
kit after pairing. With some phones you need to connect manually after pairing.
Go back to Bluetooth > Paired devices > highlight ST LIGHT > press
Options > then press Connect.
When connected you may see the Bluetooth Symbol on your phone change
slightly, either inverting in color or changing to a headset or car symbol. The kit
is now ready to use.
Repeat steps 1 -7 above for each new phone you want to use with the
Supertooth Light.
This was copied from the user manual, which you may or may not have already.. Here's a link to a .pdf file of the manual which you can also save to your computer:
http://www.blueantwireless.com/downloads/supertooth_light/supertooth_light_manual.pdf
Hope this helps :)
Season's Greetings!
Chris (ziraffa)
Dec 22, 2008 | Blueant Supertooth Light Bluetooth Speaker...
Just bought a iPhone 3G and i have a BlueAnt Supertooth light and the iPhone isn't discovering it...help?
Supertooth Light.
Hope this helps :)
Season's Greetings!
Chris (ziraffa)
Dec 15, 2008 | Blueant Supertooth Light Bluetooth Speaker...
LG KG800 Cellular Phone Logo
418 people viewed this question
Top LG Cell Phones Experts
William Norris
William Norris
George Etukudo
George Etukudo
Sheldon Dedek
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
