Question about Onkyo TX-SR804 7.1 Channels Receiver
Onkyo upconversion problem
I have the above receiver and i dont know how to configure the compnent to hdmi upconversion. This is due to not getting a manual and the online one is confusign as heck. Im tryign to convert component to hdmi, and im stuck with the settings, any help would be greatly appreciated. thanks.
  • Anonymous Nov 26, 2007
    plugged in a blu ray disc machine through HDMI and all im getting is pink and purple tints with the picture. Hooked up directly to tv and no problems. Seems like picture is having problems getting through reciever?
  • toriless Mar 01, 2009
    I think it only upconverts VIDEO to HDMI but not audio. It only passes out HDMI audio inputs to the HDMI audio output. What a RIP-OFF !! Look at the bottom of page 25 of the manual. For audio it does ONLY HDMI to HDMI and Coaxial or optical to optical out or analog to analog out. It seperated into three output groups unlike video which can can be upconverted. By the way, it doe NOT downconvert video from digital inputs to analog output except for the headphones and speakers. If you have a analog device connected to will need use BOTH analog and digital inputs. I have both an analog and digital TV. It will take not output my HDMI video imputs to analog set. Only to the HDMI but then it will ONLY pass HDMI audio NOT co-axial or optical. It SHOULD send digital optical audio and digital co-axial audio to HDMI but does NOT. You will need TWO cables and a compatible digital TV. Mine digital TV only has optical audio OUT not optical audio IN. I'd need to run a secondary analog input from the DVD player to the Onkyo and another ANALOG one from the the TV IF I wanted to use the TV speakers since ti will not pass on either the DVD players digital optical audio output nor the DVD players digital co-axial audio via HDMI. It will ONLY do so IF the DVD is also being inputted via HDMI.
This may be due to a limitation of the Faroudja DCDi chip used in the Onkyo receivers. See the Onkyo FAQ: http://www.us.onkyo.com/faqs_detail.cfm?detail=1&id=268
Posted on Dec 31, 2007
I have a dvd player connected via component and I'm having the same problems. Manual via the On Screen Menu - Set the DVD input to "---" and the signal will be upconverted and sent via the HDMI out. This doesn't work for me so I might have other problems but if you haven't tried it, give it a shot.
Posted on Sep 28, 2007
SOURCE:
With Cable connected to the rx-465 input, I'm not getting HDMI output to a Samsung plasma TV. With DVD HDMI input I get HDMI output to the TV. Any suggestions on what I'm missing. Thanks, Greg
is the cable connection hdmi? is the unit capable of upconversion to hdmi, if you use a component connection? probably not. if it is capable of upconversion, check your input menu settings
Nov 03, 2009 | Yamaha RX-V463 Receiver
Onkyo SR606 video upconversion problem.
Pressed and held cable/sat button on front of unit until "Attenuate" came up. Changed setting from 0 to 2
Oct 19, 2009 | Onkyo TX-SR606 Receiver
Connecting a wii to an Onkyo TX-SR607 7.2
I am experiencing issues like this although with a VCR connected with analog video. I added a BluRay DVD player and all of a sudden I lost my video upconversion from my VCR. I am going to try to reset the receiver to see if this fixes the problem. If not, I don't think it is the receiver issue, I think it may be the fact that enorder for video to pass through HDMI, allot of criteria needs to be met. Certain Handshakes need to happen, especially with the HDCP issues. Most likely I will connect a separate video cable to my Plasma and use a secondary input on the Plasma for the VCR signal. You may want to purchase the Component Video adapter for the wii system as this will provide you with at least 480p and your receiver should not have an issue passing the signal over the HDMI output. Good luck and give me an update.
Jun 06, 2009 | Onkyo TX-SR606 Receiver
Issues Displaying picture from HDMI upconversion
I've posted this other places. Hope it helps.
My HT-S6100 had a similar problem with my DVD player and some times with my Cable/DVR box. The signal wasn't getting received at the TV. So, first I changed the input jacks my DVD and Cable box are plugged into on the receiver (e.g. from HDMI 1 & HDMI 3 to HDMI 2 & HDMI 4). Second, I reprogrammed the Input Assignments to match (e.g. HDMI in 2&4). Third, I deleted any Input Assignments that weren't applicable. For instance, I'm only using HDMI connections, but there were Digital and Component Input Assignments programmed in. When I say I deleted them, I actually set them to "----" (just scroll through the options and you'll find this.) Finally, I turn on my video/audio sources (PS3 in your case) and let them load/warm up before I turn on my Onkyo receiver. It seems to be working. Good luck.
May 22, 2009 | Onkyo HT-S5100 Theater System
HDMI connection with Panasonic DMP-BD35K Blu-Ray Disc Player
Try hooking the Panasonic up straight to the tv without going through the receiver. If it displays a picture its obviously not the blu-ray player. May also be a problem with the HDMI cable itself. Hope this helps.
Jan 04, 2009 | Onkyo TX-SR506 Receiver
Ps3 and onkyo receiver
Hello.
I have a similar setup and am having problems of my own, but i've got it somewhat working at the moment.
I have the TV connected via HDMI to the receivers HDMI output port.
I have the PS3 connected via HDMI to the receivers HDMI input port 1.
I went on the receiver and followed the instructions in the manual to setup the DVD function on the receiver (i chose to call my ps3 a dvd) to use HDMI-1. I can't remember the button combination as i'm not at my hosue right now, but it was in the HDMI section of the manual (page 44 on my manual). Essentially I had to tell the receiver to enable HDMI for the DVD function rather than being defaulted to "No". At that point, with the default ps3 setup, I was able to get video to pass through.
Next, i went into the video options on the ps3 and changed it to 1080p (since my tv supports that).
Where I"m having my problem is that the sound from the ps3 outputs directly to the TV and doesn't output on my receiver for some reason.
How I've rigged that to work is to take the HDMI to RCA cable that came with my PS3 and i plugged in the Red and White wires on the back of the receiver in the DVD section of inputs. At that point the sound comes through the receiver.
What I don't know how to do and would really like to know is how to get the sound to output on my receiver via HDMI only and not with the extra cable.
Anyway, if i'm making sense above and you follow that, you should be up and running (but maybe not in an optimal configuration).
Let me know if you ahve any questions.
Also, if anyone knows the solution to my issue, i'm all ears.
Thanks.
Nov 09, 2008 | Onkyo TX-SR803 Receiver
Receivers
If it is me and I am spending that kind of money, it is going to be sick, os here is sick. 7.1 dolby surround and 1080P HDMI, 135W per channel, and right now if you go to FRYS.com, it is normally $500.00 bt for right now it is only $449.00. But if you put this in, be prepared to buy a PS/3 as your next investment (Th best way to get Blu-RaY at an affordable price, plus many other features) and an upconvert DVD layer, which is only about $100.00 or less today. Then you better get ready to hear from your neighbors and the cops, because they are going to think a war has broken out in your place. Enjoy, I play movies that the sound is just so realistic, I hate to leave the house anymore. Also, remember, speaker placement is key, so know the optimal environment for your system and if you need one, I may be able to hook you up with a system room tuning DVD for next to nothing. This will allow you to setup your system and place your speakers optimally for your environment. good Luck.
Onkyo TX-SR606B
7.1 A/V Receiver with HDMI Up-Scalling
Onkyo USA:
FRYS.com #: 5586420
The Progression of Affordable High-Def Home Theater Continues with Full HD Integration and Video Upscaling As part of the second generation of Onkyo high-definition-capable receivers, the TX-SR606 is at the forefront of affordable home theater. The key is to have the most capable version of HDMI. The TX-SR606 provides high-definition video and audio processing for four source components—another first for Onkyo at this level. From Blu-ray Disc players to gaming consoles and cable/satellite boxes, you have everything in the digital realm covered. Apart from 1080p video, the TX-SR606 can upscale all video signals to 1080i, regardless of the connection, for output via HDMI. Onkyo's own RIHD (Remote Interactive over HDMI) also gives you inter-operability with the displays and playback components from other leading brands. And with an expanded version of Audyssey's room correction technology, the TX-SR606 maintains the fullness of surround sound audio quality at low volume levels. The TX-SR606 offers all-round excellence rarely seen at this levelSpecial Features
  • HDMI v1.3a Repeater (4 inputs, 1080P compatible)
  • HDMI Video Upconversion
  • 1080i Upscaling powered by Faroudja DCDi Edge
  • TrueHD, DTS-HD Decoding
Amplifier
  • # Channels 7
  • Power (8ohms 20-20kHz 0.08%) /Ch 90W
  • Power (8ohms 1kHz 0.7%) /Ch 105W
  • Continuous 6ohms Rated
  • High Instantaneous Current Capability 36A
  • Amplifier Frequency Response 5Hz-100kHz
  • S/N Ratio (LINE IN) 106dB
  • All Discrete Circuitry
  • Absolute Ground Plate
  • Optimum Gain Volume
  • Non-Scaling Configuration
  • Bi-amp Capability For Front
Processing
  • DOLBY Decoder DD Plus, TrueHD
  • DTS Decoder DTS-HD Master Audio
  • Direct Mode
  • Music Optimizer
  • Audyssey Dynamic EQ
  • 192K/24 Bit DACs
  • DSP Type / QTY 32 BIT
  • Adjustable Crossover 40/50/60/80/100/120/150/200Hz
  • Independent Crossover
  • AV Sync
  • Accurate Speaker Distance Setting
  • Multi-Band Speaker EQ 5 Band
Connectivity
  • Audio In/Out 7 / 2
  • Digital Audio IN (OPT/COAX) 2 / 2
  • Composite In/Out 5 / 1
  • S-Video In/Out 4 / 1
  • Front-Panel A/V L / R / V
  • Component Video / Bandwidth 2 in / 1 out / 50MHz
  • HDMI In/Out 4 / 1
  • HDMI Version V1.3a Repeater
  • HDMI Bandwidth 1080p
  • HDMI Deep Color Capable (36bit)
  • Analog to HDMI Upconversion
  • 480i to 480p Processing (DCDi Edge)
  • 1080i Upscaling
  • Multi-Channel Input 7.1
  • Surround Pre-Outs SUB
  • Powered Zone2
  • Zone 2 Line Out
  • iPod Ready (DS-A2x, DS-A2, DS-A1)
  • SIRIUS Radio Ready
Integration Access
  • Onkyo-RI System Control
Miscellaneous
  • Pre-Programmed Remote
  • Glossy Black finished Remote
  • Simple Remote to change input & mode
  • Color-Coded Speaker Terminals
  • Auto Speaker Calibration W/Mic. (Audyssey 2EQ)
  • On Screen Display Out
  • Permanent Memory Storage
  • Solid Aluminum Front
  • Warranty 2 YEARS
Oct 13, 2008 | Audio Players & Recorders
Denon AVR 887 Upconversion With Wii
I have this hookup and it's working almost perfectly:
Wii --component--> Avr-887 --HDMI--> Sharp LCD TV
Sometimes the pictures don't show up during start up, but I figured it was (probably) due to Sharp's HDMI handshake issue, so I turned the TV off and then on, everything works.
Mar 20, 2008 | Denon AVR-887
No video throught HDMI output
press set up go option number 1 then go hdmi monitor and input yes. then press set up again
Dec 11, 2007 | Onkyo TX-SR605 Receiver
Onkyo TX-SR804 7.1 Channels Receiver Logo
663 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Ted28
Level 1 Expert
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
