Question about WYSE S10 (90210501) Network Terminal
Freezing up When we are on these units they just freeze up. There is no resetting using the g key because it will not turn on or off. The only way the unfreeze the unit is to unplug it and then when replugged it goes straight to the orange light...not shut down or anything. I have returned about 8 of these units to the manufacturer to be fixed. I would really like to know if there is another way to reset them without the down time since I am in a school environment. we are running windows server in case that is necc. to know.
    Problem Solver:
  • 9 Answers
Buy a difrent brand
Posted on May 20, 2008
SOURCE:
I have noticed my heat pump is freezing up on the outside unit, we have had freezing rain and snow the last 2 days but I have never noticed ice accumulation on the outside of the unit, it also seems like...
In freezing weather the heat pump efficiency drops. The freezing is normal. The equipment has a board and sensor to defrost your heat pump. Now this system can fail but freezing rain and snow get pulled into the unit get pulled into the unit coil and freeze blocking airflow. You can defrost the unit by turning it to cooling. This is what the defrost board does automatically.
Dec 27, 2012 | Goodman Heating & Cooling
Where is the reset button on a french door lg refrigerator
Press the "Express Freezing" key and the "Colder" key of the Freezer Temp function at the same time and hold for 3 seconds. The refrigeratoricon1.png will enter Test Mode 1. Test Mode 1 allows diagnostic operation of the compressor and freezer fan, stepping damper open, defrosting heater off and display LEDs all on.
Press the "Express Freezing" key and the "Colder" key of the Freezer Temp function at the same time while in Test Mode 1 and hold for 3 seconds. The refrigerator will enter Test Mode 2. Test Mode 2 allows diagnostic operation of the compressor and freezer fan, stepping damper close and defrosting heatericon1.png off.
Press the "Express Freezing" key and the "Colder" key of the Freezer Temp function at the same time while in Test Mode 2 and hold for 3 seconds. The refrigerator will enter Test Mode 3. Test Mode 3 allows diagnostic operation of the compressor and freezer fan off, stepping damper close and defrosting heater on.
Press the "Express Freezing" key and the "Colder" key of the Freezer Temp function at the same time while in Test Mode 3 and hold for 3 seconds. The refrigerator will reset to the state prior to entering test mode.
Unplug the refrigerator from the wall outlet, then plug it back in to reset the appliance after coming out of test mode.
There is no reset button.
Nov 01, 2012 | LG LFX25978ST 33 " Wide Ultra Capacity...
The screen is frozen and I can not get it to turn off
If you cannot get your unit to turn off it may be locked in the on position. Please follow the steps below to perform a soft reset on the device:
  1. Slide and hold the power key to the on position for 15 seconds
Once the screen goes blank you will be able to turn the unit back on and continue using the unit normally. To prevent the unit from freezing or locking up in the future, please ensure that your unit has the latest version of system software. Please see the following article for update instructions:
How do I update the software on my Garmin device?
Sep 23, 2010 | Garmin nuvi 265 Car GPS Receiver
GPS operation freeze up
Upgrading the system software of your GPSMAP 545s will most likely fix your freezing up problem.
I hope that helps.
May 31, 2009 | Garmin GPSMAP 545s GPS Receiver
Neither Roof Air Works
Yes and no .. Freezing temps should not affect your A/C at all ... BUT .. there is a freeze control box, its called a control unit to prevent itself from freezing up and burning out, take down the lower cover and you will see it. Your problem is more likely to be more central since neither are working Thermostat or even the control box's in genera, even could be a freon problem if the cold weather was really bad and you could have a leak on your lines, check it out and see what you got!
Dec 31, 2008 | Dometic Rooftop RV Air Conditioner
Nokia N95 8GB - Freezing up.
Hi greystar,
All I can say is a HARD RESET will solve your problems(and eventually all your problems)!
First backup the important stuff like the contacts, messages, apps, etc. using the Nokia Content Copier available from the Nokia PC Suite.
Then switch off your phone.
Now, press and hold the ' * - Star', '3', & 'Call - The Green key that you use to recieve a call' together and switch on your phone. Keep the above mentioned keys pressed till you see the "Select Region" screen.
Hope that helped! :-)
Regards,
Sam
Nov 30, 2008 | Nokia N95 Cellular Phone
Carrier 40MVC A/C Flahing LED
there is problem with the unit. the 2 flash codes indicates a problem.
i am just not sure what it is.
it could be a low voltage alarm,
a high voltage alarm
freezing evaporator alarm.
not cooling alarm.
reset it by un pluging the unit for 1 minute then plug it back and run it. observe if the compressor would start.
if it start, check if it is cooling,
if it starts to cool, check the coil of the evaporator if it is freezing..
you could trace from there what is wrong with the unit.
pls keep me posted..
kindly use the ask me button,
tnx 4 using fixya,
drcool
Sep 06, 2008 | Heating & Cooling
Freezing on start up
I have had a aproblem with my digiwalker Mio, which also was freezing up. The only way to sort it is a HARD RESET. The problem in my case appears to be due to the start up program initiating GPS/Tom Tom at the same time. good luck
Aug 28, 2007 | Mitac Mio 168 Pocket PC
Magellan 700 "freezing"
okyboky, Once you turn on your unit, the Magellan splash screen or animation is produced from the flash memory. To my experience anything past that is dependent on the hard drive. So, your unit is freezing up as soon as the user menu is displayed without any response to pressing keys or touch screen right? Have you tried (at the user menu) pressing "-" key and the repeat button (on top of unit) to enter the "secret" menu? if you can do that, then select reset user data. That seems to fix numerous problems. If you absolutely can't get past that screen, or get any type of sign of intelligence from it then your hard drive is either corrupt/damaged or you could just have a cable not secured. If the above doesn't work, and you don't plan on sending it in for repairs, then open it up and make sure the cable from the Hard drive to the main board (large board) are fastened. Of course, being grounded would be helpful in this situation and also be careful when you first open up the unit as the RF cable needs to be unplugged before seperating the two sides (front/back). Good luck and let me know how it turns out. -Daniel
Mar 19, 2007 | Magellan RoadMate 700 GPS Receiver
WYSE S10 (90210501) Network Terminal Logo
1,441 people viewed this question
Top WYSE Computers & Internet Experts
Ekse
Archie Ferrarini
Archie Ferrarini
Are you a WYSE Computer and Internet Expert? Answer questions, earn points and help others
