Question about HP Officejet Pro L7780 All-In-One InkJet Printer
Initial wireless activation freezes unit
I've had 3 L7780 units and each has the same issue. HP acknowledges they know of it but can offer no solution beyond "try a different unit". Upon inputting the WEP password for a wireless network the printer states it is active on the network but instantly freezes and has to actually be reset by pushes the 6 and # key while unplugging and then reinserting the power cord. You can't even turn it off or unplug it to break the freeze. HP says it has something to do with the Linksys wireless router. Any clues? I know it won't hold a manually input IP address. It constantly resets to all zeros.
  • 1 more comment
  • Beth Krantz Aug 16, 2007
    I solved it! This only occurs when the wireless router is Linksys. there is a Firmware patch on the Linksys site that has to be downloaded to be compatable. Then you have to go back to the printer properties and assign a TCP/IP port with the network's IP address. VOILA!
    ... and if that stops the freezing but doesn't bring the printer online, just uninstall and reinstall the printer software and THAT should completely eliminate the issue.
  • pksc Oct 25, 2008
    I have a D-Link wireless router and I have the same problem. Just got the printer today, install was going fine until I connected it to my wireless network and now it has completely frozen. Turning it on and off by unplugging the power over 20 times has not fixed it. Help please!
  • Anonymous Jan 14, 2009
    i feel like baby shaking whoever from hp designed this hunk
    of ****
    Problem Solver:
  • 7 Answers
There is a solution posted here. https://youtu.be/_0dKC_Hoa08 Essentially update the firmware to R2011. The firmware update does not show up on the HP support site for Win 7,8 or 10 but you can download and install the firmware using a different version of windows.
Posted on Oct 01, 2017
After finding out the hard reset code I have simply plugged my printer into my D-Link router via ethernet cable, problem solved using this workaround. Obviously this doesn't resolve the actual problem which is using wireless to connect the printer, but this solution works for me since both printer and router devices are next to each other in my office.
Posted on Jan 09, 2009
1. The wireless configuration cannot be used with any security protocol, or it will always freeze. It might be possible with MAC address filtering, but haven't tried it.
2. You need either a cross-over cable, wired hub, or wired router. In my case, I used an old Linksys wired router which gave out DHCP addresses.
3. Un-plug the HP L7780. Un-plug your wireless router.
4. With no wireless AP on, plug in the printer. Patch it to the wired hub so it gets an address. Patch your laptop/computer to the same router and get another wired address. Alternately, you could use a hub or cross-over cable and assign the L7780 an IP and subnet mask thru the front panel such as 192.168.1.101/255.255.255.0 and assign you computer a similar IP--192.168.1.102/255.255.255.0. If a hub, plug each into hub, if a cross cable is used, connect computer and printer directly.
5. Open your browser to the printe's IP, ex. 192.168.1.101 and the embedded web applet will appear.
Go to the networking tab and click on "Wireless networking" and assign the IP, subnet mask, gateway, and DNS server (on home network, same as the gateway) of your preferred wireless network.
6. Click "apply" or submit; click thru any warnings about not being able to connect.
7. Disconnet devices from wired hub or cable and plug in your wireless AP. In my case, the L7780 did not retain the IP I assigned, but did acquire a new DHCP address from the AP.
8. Print out config sheet, open a browser, go to the assigned IP and change the settings to the ones you want.
Jeff Pearson
jpouteast@gmail.com
A+, Network+, and MCP
I just started having this problem today after I upgraded my old Linksys router to a WRT54GS.
Posted on Nov 06, 2008
This is not just a Linksys issue, I am having the same problem with a new wireless router from Rukus. I have attempted to connect with various security setting, including none, and the printer freezes after it connects to the router. The printer works fine when I try to connect it to my DLink wireless router.
Posted on Nov 13, 2007
Beth, Any details on what firmware version worked for you. Have a WRT54GS V7 -- and having same darn issue!! - Jen
Posted on Aug 21, 2007
Thanks, Beth. I am only on my 2nd L7780 unit but am struggling with the exact same problem. Which Firmware patch did you download from the Linksys website? Thanks, Sharon
Posted on Dec 14, 2007
Partial print on incoming fax
Check your incoming line and settings or try to reinstall the drivers. Also, check the user manual for HP Officejet Pro L7780
Jun 25, 2013 | HP Officejet Pro L7780 All-In-One InkJet...
I need to know the steps to replace the carriage belt for a hp all in one L7780 printer
Sorry to say that if you are not a tech guy, it is not suggestible to do this major work. even you want to do.. Remove carriages and print heads, remove back,lift adf unit remove side covers,ADF unit, foramtter, mechanism carriage rail,carrige assm..Ohh these many you have remove...
Sep 11, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
I've got one single 12000 btu ac unit and one double 24000 btu unit and three wall units controled by 3 remote controls.Recently one of the remotes stoped to work.I've changed the batteries(were...
Taking apart the hand held remote won't serve any real purpose as none of the parts inside are replaceable. Since you have 3 different units, with 3 different hand held remote. I'm wondering, if perhaps, you're using the wrong remote on that one unit. As each one has a different remote code.
In addition, I have learned from experience, that if the display screen on the hand held works, the problem is not in the hand held. Now, that's not to say, Operator Error can't play a role in it. But, most times, it's the receiver in the unit,that may be causing the problem. Or the hand held is to far away or something is blocking the signal in between.
Almost every appliance we sell, has a radio frequency remote control. The most problems we incur is with weak or dead batteries or operator error. The problem with batteries is that you don't now how long they sat in a warehouse, before making to a retail outlet and then how long they sat on the shelves there, before they were sold. They may have enough power to activate the handheld remote, but not enough to transmit a strong signal. So, check the strength of the new batteries you installed.
Hope this helps and thanks for choosing FixYa.
Jul 29, 2011 | LG LS-K1830CL Cool Mini Split Air...
Purchased new laptop with Windows 7 operating system (last May). I am totally frustrated as I am unsuccessful in downloading the driver for HP Officejet Pro L7780 all-in-One Ink Jet Printer. Could you...
To Download:
1 Go to hp.com 2 Click on Support and Drivers 3 Enter your product name or number, in this case just type in HP Officejet Pro L7780 4 Hit go 5 Choose your operating system 6 Hit Next 7 Click on the link that says Driver - Product Installation Software 8 Save it to your desktop
You can also download the CD from the website. Same page.
Feb 07, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
HP L7780 error on printing.
Uninstall completely all of the software that came with unit and then reinstall it.
And HP customer service sucks - they will only help you out during the warranty period of their product.
Mar 22, 2017 | HP Officejet Pro L7780 All-In-One InkJet...
I also have HP 6310xi all in one printer with power reset message
1. Please make sure that the power adapter is working properly. Also connect the unit to a different power outlet and verify.
If the issue persists, please perform the following steps:
Step 1: Power Reset:
1. Disconnect the unit from the computer. Verify that the unit is switched ‘on’. Unplug the power cord from the back of the unit.
2. Wait 30 seconds.
3. Plug-in only the ‘power cord’.
4. Repeat steps 2-4 two more times.
5. On the third time after plugging the unit into power, reconnect the connection port from the all-in-one to your computer.
If the issue persists, perform the following steps:
1. Take the cartridges out of the unit. Unplug the power cord from the unit.
2. Press and hold # and 3 buttons together while plugging in the power cord back to the unit.
3. Turn on the unit and insert the cartridges.
This will solve the problem...
Jun 23, 2009 | HP Officejet 6310 All-In-One InkJet...
The issue with the DV2000, 6000 and 9000 not booting, no display, no sound, no wireless is well known to HP- check their website. Call them and make them fix your computer. If they argue, firmly direct...
http://www.fixya.com/support/p509081-hp_hp_pavilion_dv9000z_17_notebook/manual-32842. Read it but finally I would recommend that you ask the manufacturer to replace your set with a different one and pay the difference. This series has lots of problems which will never get totally solved.....sodeep
Mar 19, 2009 | HP Pavilion dv9000z Notebook
Upon start up it just says error:0x886a789e
1. Follow the steps below to power cycle your all-in-one:
1. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the connection port.
2. Wait 30 seconds.
3. Plug in the power only.
4. Repeat steps 1-3 two more times.
2. Perform a partial-full reset on the unit.
Press and hold # and 3 on the keypad and then plug the power cable of the All-in-One.
If the issue still persists
3. Peform NVM RAM reset on the unit :
Press and hold OK and Cancel while plugging in the power cord.
This should resolve the issue. If still persists, please contact HP Technical support for further assistance
Nov 02, 2007 | HP OfficeJet 7410 All-In-One InkJet...
HP L7780 always reports empty magenta cartridge
Hi, The issue can be resolved by just shaking the ink cartridge slightly by holding the nob closed so that the ink mixes and then insert the cartridge back in the printer this should fix the issue... You can also power cycle the unit by unplugging the power chord and replugging it back by keeping the printer turn on and make sure that the all the cartridges are out while powercycling the unit, This will fix the issue check ..
Sep 05, 2007 | HP Officejet Pro L7780 All-In-One InkJet...
HP Officejet Pro L7780 All-In-One InkJet Printer Logo
664 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
