Question about Creative Labs ZEN SLEEK MP3 Player
My creative will not show the song title and in stead says "select music to play"
And my rhapsody account wont recognize my player.
    President:
  • 4,402 Answers
Go to my computer > click on hardware tab >
click on device manager button > in the is next screen on the bottom should have>>universal serial bus controllers
(write these down just in case it cant find them)
right click on them and uninstall
reboot let windows reinstall them
Also told Microsoft hotfix causes this problem try uninstalling the last hotfix
Posted on Feb 04, 2008
SOURCE:
I can't drag and drop music from my library to the sansa clip. I have downloaded songs using Rhapsody and I can see where my device is but it wont allow me to drag my songs to it... I have purchased the...
Account Status
You need to connect to Rhapsody once every 30 days to continue playing your subscription tracks. When you reconnect, the 30 day license is renewed. The indicator will change from full circle to a quarter cycle as the days pass, and you will be warned when your tracks are about to expire.
Rate This Song
1. In playback mode, press the Submenu button.
2. Select Rate This Song.
3. Press |<< or >>| to change the rating (Negative to 5 Stars)
4. Select Negative to ban this track from playing again.
Purchase
2. Select Purchase This Song.
3. When you connect the player to Rhapsody To Go, the track will be added to your Purchase Bin. You can decide if you would like to purchase it at your leisure.
Add To Library
2. Select Add Track to Library
3. A confirmation message, "Song has been added to your Library". Your song will now be a part of your device Library.
Artist Info
To display the artist information, press the center button 2 times when the song is playing back.
Account Info
1. From the Main Menu, select Settings.
2. Select Account Info.
Feb 26, 2010 | SanDisk Sansa Clip MP3 Player
Deleting songs.
Your DB might be corrupt. Folow the delete procedure one more time:
Delete Music Files
1) Connect your Sansa to the computer.
2) Select Open device to view files using Windows Explorer on initial
connection.
3) Select the place where you want to delete music files from
4) Highlight and delete the music file/s or folder from My Computer\Sansa
e200\...\MUSIC
folder. (You can also select from a variety of music
software programs to transfer/synchronize your files).
If that fails, go ahead and update the firmware - it will delete everything, and allow you to start over from scratch among other things.
-Tha Mp3 Doctor
Feb 16, 2009 | SanDisk Sansa E280 MP3 Player
How do i synchronize my subscribtion
I'm not sure what's the subscription service to which you are subscribed. However I've given you the steps below. Try whatever suits for you.
This error typically occurs when the DRM licensed files have expired.
SOLUTION 1 - Songs ripped from an audio CD
If the songs were ripped from a CD using Windows Media Player, modify the Rip Music settings
SOLUTION 2 - Songs downloaded from music subscription service
If the songs were downloaded from a music subscription service (e.g., Napster, Rhapsody, Best Buy music store, etc.), follow these steps:
1. Make sure that your account subscription is updated and active.
2. Put the device in MTP mode and connect to the computer, then log in to your music subscription account.
3. Renew the licenses of your tracks
For Rhapsody:
On the Rhapsody console, right-click on your device and select License
1. Check the date & time on your PC & on your mp3 player. They should be one and the same. 2. You need to synchronize your device with rhapsody once in every 30 days. It's a must. Failing to do so, you will not be able to play music in your mp3 player. Here are a few a steps to synchronize your device with rhapsody: 1.Open Rhapsody / Best Buy Digital Music Store and sign in 2.Connect your mp3 player to the computer 3.Go to My Account --> Update Track Licenses 4.Transfer a track to your device 5.Disconnect your device and enjoy music on the go!
3. Here is a link to get the Sansa Firmware updater to update the firmware for your device automatically: http://www.sandisk.com/Retail/Default.aspx?CatID=1376
4. Click on this links if you are asked to synchronize your device with rhapsody? http://reclisten.custhelp.com/cgi-bin/reclisten.cfg/php/enduser/std_adp.php?p_faqid=6606&tabName=tab3
For others:
Contact music subscriber for instructions on how to renew as they vary.
SOLUTION 3 - Rename the Windows DRM folder
NOTE:  The Windows DRM (Digital Rights Management) folder contains licenses for secure media files such as your subscription tracks.
STEP 1 - Edit the folder options of the PC to show the hidden files
Windows XP:
1. Double-click My Computer
2. On the Menu bar, click Tools > Folder Options, and then click the View tab.
3. Under Hidden files and Folder, click to select Show hidden files and folders
4. Under Hidden files and Folder, click to clear Hide protected operating system files (Recommended) check box.
5. Click Apply, and then OK
Windows Vista:
1. Double-click Computer
2. Click the Organize button at the upper left corner.
3. Click Folder and Search options.
4. Click the View tab and select Show hidden files and folders
5. Click to clear the Hide protected operating system files check box.
6. Click Apply, and then OK
STEP 2 - Rename the DRM folder
1. Double-click My Computer > C: > Documents and Settings > All Users
2. Right-click the DRM folder and select Rename
3. Rename this as OLDDRM
4. Run the subscription service program you are using and renew the licenses to recreate the DRM folder with new licenses.
STEP 3 - Synchronize your device once more on MTP mode
SOLUTION 4 -  Format the player under Windows Media Player
Jan 30, 2009 | SanDisk Sansa e250 MP3 Player
How do I transfer music into the MP3 Player from rhapsody list?
First, read your manual.
Second, find the name of the folder that the Rhapsody songs are stored in, and copy them or move them to the "My Music" folder on your computer. If you are handy with computers, instead of moving the Rhapsody songs to the My Music folder, go into Windows Media Player instead - click the arrow underneath the Library tab, and select "More Options" --> Library --> Monitor Folders --> Add the Rhapsody folder to your list of folders.
Third, make sure you have Windows Media Player installed on your computer, since that is the program you will be using to transfer the songs. Click on the Library tab, and make sure that the songs show up on your computer. Once you see them, click on the Sync tab and start dragging the songs (no more than 10 songs in one sitting) to the window that says "Drag files here to synchronize..."). Click Start Sync.
Warning: Some GoGear models recognize Rhapsody songs and others do not. If you have Rhapsody's Mp3-Only service, then you are in the clear no matter what model of GoGear you have. If you have one of Rhapsody's other subscriptions, you may be in trouble. If your Go Gear is truly an SA6045, it will recognize DRM-protected Rhapsody songs, so you will be OK. If you have an SA3025 or one of the newer models, you will only be able to successfully transfer songs by signing up for Rhapsody's Mp3-Only service.
-Tha Mp3 Doctor
Dec 27, 2008 | Philips GOGEAR SA6045 MP3 Player
Cant play songs off my playlist
AAAaaaahhhhhh...
You can thank Microsoft for creating Digital Rights Management.
Okay...I'm assuming this is an MP3 that you loaded using the Rhapsody-to-go or other music service that allows for subscription music.
What the MP3 player is telling you is that because you have subscription music and not purchased music, the DRM allows you to only play the song or songs 30-90 days after download. To continue to listen to the songs, you will need to open your Media Manager software (Best Buy Digital Music Service, Rhapsody, WMP11, Media Monkey, etc) connect your MP3 player to the PC, identify the MP3 player through the media manager and tell it to re-authorize your tracks. Once its finished you'll be able to play your songs for another 30-90 days. You will need to repeat this re-authorizing to continue to play the tracks.
Apr 20, 2008 | Insignia Kix MP3 Player
Playing mp3 songs on the ps3 --- 80gb
Whether you are hooking up your device through a USB cable or removable memory (SD card/Flash drive) the PS3 should recognize and play the titles. Here are a few steps to help you along.
1. Hook up device to your PS3
2. Select PS3 media icon where files files should be located
3. Press triangle button on controller
4. Sub menu will show up on side of screen
5. Select the 'display all' option
6. Files should now be accessable/loadable/playable
Playing files directly from the Mp3 player or loading them on the hard drive are both do-able and both methods should work.
Jan 13, 2008 | Sony Playstation 3 (PS3) Console
Wont regonize music
Reason could be because if you are no longer an "active' customer, the mp3 player can't go out and download the "permissions/rights" needed to play the song. As opposed to the songs you rip because you are using the cd for that, which means the songs are yours. At least thats my opinion.
Jan 02, 2008 | SanDisk Sansa e250 MP3 Player
Synchronize to continue your music subscription
Do you have an account with Rhapsody? The preloaded music is part of the Rhapsody subscription service. If you dont have an account, you will receive that message until you delete the preloaded music, or subscribe to the Rhapsody Service. Best of Luck.
Sep 11, 2007 | SanDisk Sansa e250 MP3 Player
Help
Hi tater. Hmmm. The product category you selected is for a Standard E260. But if your player is an E250R (Rhapsody player), here's a set of procedures that might help you. Deleting songs from your E250R can be done in 2 ways: By using Windows Media Player 10 or 11, or by browsing the player through Windows Explorer. Before you delete files, though, it's important to know that your player comes in 2 modes: "Rhapsody" and "PlaysForSure". The reason why is that music files saved in one mode would not be seen in the other mode, and vice versa. Therefore, if you can't find the music files in your player, switch to the other mode. Here's how to do it: Use the "Menu" button to navigate the player as follows: Menu > Settings > Mode > This will give you the option of: "Rhapsody" and "PlaysForSure". Here's how to delete your songs: (1) By Using WIndows Media Player: > Plug your Sansa to your computer and open your Windows Media Player. > If your Windows Media Player is version 10, then click on the "Sync" tab and you should see your player ("E250R") on the right pane along with its folders, named "Data" and "Media" or "Music". Expand the "Media" folder and you'll see the "Music" folder containing your songs. Right-click on a song and select "Remove" to delete them. > If your Windows Media Player is version 11, then either click on the "Sync" or "Library" tab and you'll see your player listed on the left pane. The music files will be displayed on the center window. Right-click on a song and select "Delete" to delete the songs. (2) By browsing the player in Windows Explorer Note: the folders containing the music files on your player are "Hidden" and you would need to set your Windows Explorer to show "Hidden Files and Folders". Open your Explorer, select "Tools" on the top menu, select "Folder Options", select the "View" tab and enable the "Show Hidden Files and Folders" radio button. > Plug your Sansa to your computer and open your Windows Explorer > If your player is in "PlaysForSure" mode, then your player will be recognized as a "Portable Media Device". Double left-click on your Sansa E250R and you'll see 2 sub-folders named "Data" and "Media". Open the "Media" folder and you'll find sub-folders normally named after the Artist. Your songs are located on those Artist folders. Delete them by using the keyboard "Delete" key or right-click the file and select "Delete" > If your player is in "Rhapsody" mode, then your player will be recognized as a "Removable Drive" with a drive letter. Double left-click on your Sansa E250R and you'll see the following sub-folders: "Albums", "Music", "Photo", "Pictures", "Playlist", etc. Your songs can be found in the "Music" sub-folder. Delete them by using the keyboard "Delete" key or right-click the file and select "Delete" I hope this procedure helps. A bit lengthy but, hey, it worked for me (lol).
Apr 27, 2007 | SanDisk Sansa e260 MP3 Player
Sansa e260r mp3 player with rhapsody
it means that either your music files have been corrupted or that you only had a specific amount of plays for that song because it was only a trial, so if you redownload them and pay for them then they should, work. For the song difficulties with LimeWire, I am stumped on that, but if I figure it out, you'll be the first to know! Your online bud, Maxwell
Jan 03, 2007 | SanDisk Sansa e250 MP3 Player
Creative Labs ZEN SLEEK MP3 Player Logo
Top Creative Labs Audio Players & Recorders Experts
Ekse
Marvin
Marvin
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
