posted by heidijodell on Aug 16, 2007
When I turn on my camera to take a picture, the zoom lens keeps zooming in and out without me doing anything, and after a minute or so, I it says "please turn camera off and then on again", and when I turn it off and then on again, it just does the same thing.
Best Solution
posted on Oct 12, 2007
Try, turning the camera on and taking the batteries out without turning the camera off. This will simulate a force reset. Turn the dial on the camera to "playback" mode and put the batteries back in. Turn the camera back on. This should put the camera in playback mode and by default put the telescoping lens in a resting position. Turn the camera between "shoot" and "playback" mode if turning it on in "playback" mode doesn't work right away. Another more risky strategy is waiting until the lens zooms in and taking the batteries out at the instant it's retracted the most and manually pushing the lens back to it's resting position. Sometimes the plastic gearing skips is the camera is turned on inside of the case and you need to "reset" the gears.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Panasonic Lumix DMC-LZ7 Digital
Email this problem
Email this problem
Can you Help with these Digital Cameras problems?
Panasonic Lumix DMC-LZ7 Digital Camera
Lumix DMC-LZ7 turns off
Everytime I turn the camera on... Answer This...
Accessing files on SD card
When I transfer pictures from... Answer This...
The flash will not work
I have forced the flash and... Answer This...
The shutter does not close
My younger bro used an ordinary... Answer This...
Want to take multiple picture...
Hi. I have a 3 year old ad a... Answer This...
Repair Service
Find Digital Camera Repairman Near You:
