Whirlpool AD70USS Dehumidifier
Problem for Whirlpool AD70USS Dehumidifier
My whirlpool dehumidifier freezes up !! whats the problem?
By gailriffle on Mar 20, 2009
I have had this for a couple of years and one dealer looked at it andsaid it needed free-on but he wasnt buying any to add --and dont use it below 50-60 degrees----well I use it in my heated basement and it worked for 2 years and now it just freezes up --personally I dont think he diagnosed the problem or he is wacky!! I paid him 20 bucks too!! stupid me!! he was suppose to be one of their dealers to take it to---figure that and when I called whirlpool cause its again been sitting here for 5 months not in use they told me wll get a second opinion--so the 2 year warranty is up but if it is anything inside the housing its under warranty for 5 years----Model AD 70USS0
Comments:
Mar 21, 2009
- I dropped off the dehumidifier yesterday for repair so I will have to see what he comes up with. Your comment makes sense and even the dealer I dropped it off to said that probably was the problem --thankas
Same Problem
May 25, 2009
-   My whirlpool dehumidifier freezes up -   Guest
Best Solution
posted on Mar 21, 2009
Helpful)
odin223
Rank: Guru
Rating: 94%, 209 votes
Your dealer who looked at it was almost certainly right in his diagnosis. "Freon" was originally a trade name for a limited range of refrigerant gases (the stuff that's pumped around in the pipes of dehumidifiers, refrigerators, freezers and most other coolers), but the name is often used colloquially to refer to any refrigerant gas.
When it's manufactured, each machine is filled with a measured quantity of refrigerant gas. This can leak out slowly over time, and freezing up is the common sign that this has happened. Most refrigerator engineers should be able to refill your machine and check for leaks at the same time.
Was this helpful?
Yes
No
5 people thought this was helpful
Popular Solutions for Whirlpool AD70USS Dehumidifier
Questions and Unsolved Problems for Whirlpool AD70USS Dehumidifier
Do you recommend Whirlpool AD70USS Dehumidifier?
Answer
Answer
micromark dehumidifier 53534 how do i get the top end of the body/case apart? removed all screws... (More)
Answer
Fan Runs but Compressor cycles on and off and does not dehumidify at all the bucket is bone dry
Answer
Humidifier is tripping the circut breaker when it is plugged in. I have taken the housing apart and... (More)
Answer
I have a whirlpool deumidifier Modle# ad25dsso or ad25bsso I could not make the 5th letter out... (More)
Answer
I recently noticed the bucket filling with water, even though I have a hose attached. Turns out the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dehumidifiers Experts
Top Air Conditioner Repairmen
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
