Question about Hotpoint First Edition FEW12 Front Load Washer
Washing machine probs
When we do a hot wash it does not heat up the water.we have a cold fill machine
    Novelist:
    Champion:
  • 244 Answers
Right you have 2 parts for heating the water you have the heater element you can test this simply by undoing the wires making sure to wright down order they go in get an old wire with a plug on the end attach each colour in the order you took the proper wires of plug it in if the element is working then you will feel the heat and see it glow if it doesnt then its a faulty element if it does then it will be your thermostats both element and thermostats are located at the front behind the front panel this needs taking off
Posted on Aug 16, 2007
5 Suggested Answers
SOURCE:
onthejob5130
  • 640 Answers
SOURCE: Washing machine
check your inlet vavle...check that fill hoses are on proper
Posted on Dec 27, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: wont fill with hot water
3 things to check.. Make sure that you are getting hot water upply. Check your water inlet valve. IF both are ok then check the switch to make sure that it is sending power to the water inlet valve to let it open. These parts can be found behind the knobs after you remove the cover
Posted on Feb 11, 2009
jsrock516
  • 5911 Answers
SOURCE: our washing machine will not fill cold water. the
You may have a defective cold water solenoid on the water inlet valve. There is a separate solenoid for hot and for cold. So, if you've confirmed the inlet screens are clear, more than likely you will need to replace the valve. If this is a Kenmore top loader, the following link explains how to replace a water inlet valve:
http://www.fixya.com/support/r600647-replacing_water_inlet_valve_kenmore
This is a very simple and inexpensive repair. The average cost is about $30-$35. A replacement can be purchased at any of the following websites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
If you need further assistance, please post back with your complete model number (located under the wash lid along the tub rim), so that I may be able to provide you with better service. I hope this helps you.
Posted on Oct 12, 2009
  • 1218 Answers
SOURCE: My Maytag, Model A882 series
Good day,
This is usually caused by the dual water valve on the back of the machine failing.
It supplies both cold and hot water to the machine.
In your case, it appears the cold water side of the valve has failed.
It is a none repairable item, and you will need to replace the valve which is available at any decent sized appliance parts house.
However, before replacing the valve, make sure the cold water from the faucet is turned on, and with that hose removed, make sure cold water will come out of the hose if you turn the cold water valve on.
Posted on Sep 23, 2010
No Full Hot Water wash
the hot selection only tells the machine to turn on the house hot water to the machine
if you have it on warm , then both taps will be working
if you want a really hot water wash , there will be an element in the tub to bring it to temp
naturally an energy saver will not waste money heating hot water
Sep 15, 2017 | Washing Machines
Cold Fill Washing Machine Does Not Get Hot
Do y7ou have 2 hoses at the back of the machine one for cold water and one connected to the hot water tap of the house. If not then you have a cold water in only. If you have 2 hoses have you connected the hoses into the machine correctly Have you checked to see if your machine has a heating element under the bowl for heating the water. As an appliance shop to verify if you have by the model number of the machine. otherwise you have a cold washing machine and unless you can plumb hot water to it that is all you will have.
May 29, 2013 | Siemens Washing Machines
When connecting the machine to the taps, do you need to connect the machine to hot from the geyser or the washing machine makes the water to be hot
I think you will find that all washers are able to heat water. If they are hot and cold fill, they use the heater if the hot water supplied is not hot enough for the particular wash. If they are cold fill only then they need the heater for all non-cold washes.
If you purchase the washer you are thinking of and it is cold fill only, it will have only one inlet hose, the cold water one and it is a straight forward installation- hose from washer screw into cold supply tap.
If it is hot and cold fill you have a choice- either go to the expense of plumbing hot water to it OR purchase a 'Y' 'tap' adapter. The adapter screws onto the cold supply (by the 'bottom' of the Y) and the hot and cold hoses which go to the washer are screwed into the (top) 2 ends of the 'Y'. The washer opens its hot valve, gets the only water supply which is cold through what it thinks is the hot hose and heats it up accordingly. When it wants cold it opens its cold valve and gets the cold water through what it thinks is its cold hose- which it is!
I hope this clarifies the situation for you and if it has please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jun 17, 2011 | Washing Machines
Which is hot & cold inlet connection
If you want to connect up a washing machine that uses hot and cold water but you only have a cold water supply (such as in a basement or garage) you can use a Y Piece connector to connect the hot and cold fill hoses to a single cold water supply (external link to 4Washerhelp spares).
The washing machine will then work OK. Simply screw the Y-Piece onto the tap, and then screw the hot and cold fill hoses to the Y-piece and connect the other end of the fill hoses to the washing machine. (You may also be able to buy this part from a DIY store like B&Q)
If you don't connect a water supply to the hot valve (and simply connect the cold water hose to the cold valve leaving the hot valve with nothing connected to it) then some wash programs may not work as some programmes only fill with hot water. However, some washing machines will work OK with only the cold fill hose connected. You can always try it and see. The worse that will happen is the washer could either stick on the odd wash programme or may abort on some. If you do this though it's possible for water to drip out of the hot valve on some machines during fill. It's best to use a y-piece if possible.
The fact that you have connected cold water to the hot valve is irrelevant, the washing machine will not know any different and will just heat the water up to the correct temperature. The washing machine may use slightly more electricity but if it's less than 10 years old it shouldn't be significant unless you use a lot of 60 or 90 degree washes. On 40 degree washes, manufacturers argue it's more efficient to fill with cold water only and slowly heat up the water to 40 degrees.
Apr 30, 2011 | Washing Machines
I am about to buy this model machine but before i do i need to know-does this machine heat up the water itself? or do i have to have a supply of hot water going into the machine in order for it to be hot...
John C
Apr 18, 2011 | Washing Machines
Does this machine have a heating, if not how is it supposed to do a 90 degree wash ?
You don't actually mention what make and model but all machines have heaters. If it has both hot and cold fill it will heat the water if it is not hot enough, or mix with cold if it is too hot. If it is cold fill only it has to heat the water anyway ;-0)
If you do not think it is heating sufficiently the heating element could be malfunctioning.
Cheers,
John C
Mar 03, 2011 | Washing Machines
Whirlpool auto load not filling with water to wash, but will go to rinse cycle
There are 2 inlet valves 1 for hot water and 1 for cold. Sounds like your hot water valve is either faulty or the hot water valve to it is off. The machine normally fills with hot water as it doesn't have a heating element to heat the water and fills with the cold water to rinse
Feb 24, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Is the indecit wm12x washng amchne a hot or cold water fill?
Hi from retired Englishman in SW France @ 13:45 Tues afternoon.
You can easily check by looking at the back where the water pipe or pipes need to be connected. If there is only one inlet then it is a cold fill and the machine will heat the water up itself.
If there are two inlets the hot is normally marked RED and the cold BLUE.
When the hot water is not hot enough for the particular wash, the machine will heat it in the same way as it would heat just cold water. If, however, the hot water is too hot, it will mix in some cold!
Cheers,
John C
Feb 08, 2011 | Miele Washing Machines
Cold water fill does it heat to temputure requied?
If your washing machine has inlets for both hot and cold water, you should connect both if possible. If you can only connect cold water, the washing machine will still work and heat to the required temperature, but it will need to heat the water in the machine, so the wash cycles will take longer and it will use more energy.
If connecting a hot and cold fill washing machine with cold water only, you will need to connect a Y-Piece for it to work:
The tail of the "Y" attaches to the cold water valve on your pipework. You then attach both hot and cold water hoses to the branches of the "Y" and connect both hot and cold water hoses to your washing machine.
Please post back if you need further assistance.
Regards,
BElectric
Nov 25, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Washing machine
HOT WATER VALVE IS FAULTY
Nov 29, 2006 | Indesit W 123 Front Load Washer
Hotpoint First Edition FEW12 Front Load Washer Logo
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
