Question about GTCO CalComp Drawing Board III 34180 Graphic Tablet
Digitizing problem while digitizing the cursor is blinking on the display monitor . but the tablet moments shows in monitor only particular area . if i move beside that area when we move that tablet it hangs in that same area, eventhough if we along the drawing board digitizing board
SOURCE: GTCO CalComp Drawing Board III
First conform that serial port is selected as NONE on digitizer manager while you running the lectra tablet utilities. If you try this already please check your cable connectivity any one of the line may be missing connection. It may work but you can't able to run lectra tablet utilities.
Posted on Sep 17, 2011
0 characters
1 Points
Tablet pen's cursor skips around in 3 places?
The cursor skipping in three places is apparently caused by the connectors inside the tablet getting dirty or corroded.
Fortunately, you can easily fix this problem yourself! All you need to do is unscrew the back of your tablet, unplug the connectors and clean them with a q-tip dipped in alcohol.
There is a video on YouTube that shows you step-by-step how to do it(it's easy!).
It's called: Howto fix dead areas on any graphics tablet and it's posted by riodroid.
Here's a link to it:
Hope this helps!
May 14, 2013 | Adesso CyberTablet 12000
GTCO Calcomp 30
You may have an open line in the grid of the tablet and the Quikruler cannot set a point.
Try setting the menu in a different location and check out the grid lines by moving the cursor over the area that won't take a ref point.
Feb 20, 2012 | GTCO Calcomp 30"x36" QuikRuler & Roll-Up...
Is it possible to remove features from a tablet?
I have the bamboo fun pen also. I am currently running Windows Vista 64bit home and have the same problem. I fixed mine by going into the control options > Tablet PC Settings > Other > Go to Pen and Input Devices > Settings (Under Pen Options) Then I clicked at the top Where it states "Enable press and hold for Right-clicking". I disabled that and my pen works with no holding for the right click. I can make scratch marks all day! Hope this helps you too.
Dec 25, 2009 | Wacom Bamboo Fun 8.5" x 5.3" USB Tablet...
Double-Cursor to Obsolete
Is this driver certified for Vista? If it worked partially before and fails completely now, roll back to the previous driver. Compatibility is the key.
Aug 03, 2009 | Adesso (CYBERTABLET12000) Graphic Tablet
How do you put the pen in "Mouse mode" on a Genius?
Please follow those steps:
  • Select "Preferences" under the "Options" menu .
  • Under the Digitizer Input section select for input "Digitizer only" and click OK
  • Now configure the menu and screen area and save configuration
  • Select "Preferences" under the "Options" menu and set in the digitizer input section input back to "Digitizer/Mouse"
Jul 24, 2009 | Wacom Bamboo Fun 8.5" x 5.3" USB Tablet...
Cursor not aligned with monitor
I'm not familiar with the utility software that comes with the bamboo, myself, but I am using the Intuos3, just a bigger version.
Have a look at Start>Programs>Wacom>Tablet Properties
In here you will find all sorts of seetings and customisable features.
Your looking for 'Tablet' then 'Mapping' and maybe set for 'Full Screen' - I'm guessing it's set on portion.
Let us know if this helps - if not, we'll delve deeper
**.The best way to acknowledge contribution is to rate it's relevance.**
Feb 02, 2009 | Wacom Bamboo Fun Medium (CTE650S)
Duel Monitor Cintiq Problem... pen affecting wrong monitor
under the calibrate tab in the wacom tablet properties window there is a drop down window with a list of monitors. Change that to the Cintiq
Jan 19, 2009 | Wacom Cintiq 15X Graphic Tablet
Using dual monitors
that is usually how graphics tablets are set, sometimes they have function buttons that you can use to toggle between screens in a multi screen setup (remember that graphics tablets are not the same as touchpad.....
it is also possible to set your screens up as one desktop... this with a recallibration of your tablet could give you access to the whole screen area.
Aug 31, 2008 | Manhattan Graphics 8 x 6 (174459)
Cursor control at the right side of the tablet is out of control
u gotta call me and **** my left nut U ******* COKC MUNCHER
Dec 05, 2007 | Ace Hardware Flair II GT-504 (GT504)
Why does my tablet suddenly start to randomly click and drag?
Sometimes the tablet (especially ones with buttons at the top such as Cut, Copy, Paste etc) reacts to pressure and not the tablet itself. Make sure theres nothing over them, that might help.
Aug 20, 2006 | Aiptek HyperPen 12000U (HYPERPEN12000U)...
GTCO CalComp Drawing Board III 34180 Graphic Tablet Logo
32 people viewed this question
Top GTCO Graphics Tablets Experts
Gareth Cockram
Gareth Cockram
Are you a GTCO Graphics Tablet Expert? Answer questions, earn points and help others
