Related Tags:
This problem should be removed because:
Problem with Samsung HC-R4755W 47 in. HDTV Television
Burnt resistors in convergance circuit
I need the values of the following resistors: rz169, rz170, rz171, rz172. These resistors don't show up on the service manual.
Solutions (1)
Fungryman, I'm tackling a convergence problem myself and replaced IC's. no help. I'm moving on to the convergence fuses and then resistors. I found this site which gave me the values of each from a kit they sell. Hopethis helps.www.tvrepairkits.com/order-now.html
Toshiba 57H82 resistor value???
I replaced the STKs due to a convergence issue but got too close to one of the surface mount resistors and burnt it off. It was R7891 and I...
I am looking for an
I am looking for an Atec av370w service manual. I have a burnt out resistor r501 and cannot tell what value it is as the marking are not...
How do I locate resistor values?
We are trying to replace convergence ics on a relative's Hitachi 57SWX20B projection tv. We just need to resistor values. Does anyone...
I have a Hitachi 46F500 that I replaced the
I have a Hitachi 46F500 that I replaced the convergance IC's in. Now I have resistor issues. Red grid is bent, not square. I removed...
Add Your Solution
TV screen looks fuzzy, this started after we had a
TV screen looks fuzzy, this started after we had a storm, it was working fine prior to that. I check out back lamps and...
The tv wont recognize the
The tv wont recognize the cable input. I just bought this used like a week ago, and since i've been trying to use...
i have a samsung model hc-r4755w rear projection
i have a samsung model hc-r4755w rear projection tv the picture has developed an orange tint does anyone no the cause of...
Samsung HCR4755W given to us
Samsung HCR4755W given to us second hand. Worked well until the other day when I could not get it to power on. Not...
Related Topics
Fix-O-Meter
90
90 people viewed this problem
- 0 people are following this problem. Be the first!
Top Samsung Projection Television Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
