Question about Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range
Jenn aire oven no power.
I have power to the burners. I have no power to the oven and no reading on the oven clock. It worked yesterday.
  • trepod Apr 18, 2009
    We have the same problem, Our burners work but our oven is not working. When we press the buttons they are locked. THere is no reading on the display. Unable to use our ovens.
    Problem Solver:
  • 5 Answers
Go to jenn air web site -find your stove model number and find user & care guide that should help you
Posted on Mar 22, 2009
SOURCE:
F1E1 error happened repeatedly, jenn air says cut
F1 - E1
EEPROM checksum error
1.
Disconnect power for at least 30 seconds.
2. Re-apply power and observe for
at least one minute.
3. If code re-appears, replace control board (also
called ERC or clock).
Note: Applies to all F1-E...
codes except F1-E3.
Read more: http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Jenn
Air Range / Stove / Oven Fault Codes#ixzz19GMNtS3r
Dec 24, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
My jennair burners ,fan and oven light work but
Replace the clock first(electric control) then test the oven it could be that it's why the oven does not work.
Jan 13, 2010 | Jenn-Air JES9860 Electric Kitchen Range
The touch pad on my Jenn Air Model JES9800BAF does not work. The clock does not display either. All four burners operate normally.
All burners work fine, clock display is blank, if the oven isn't working either, your display / control board is shorted out
Nov 13, 2009 | Jenn-Air JES9800BA Electric Range
Kitchen range random chatter noise
could be clock motor or fan motor keeps running.
Jan 24, 2009 | Jenn-Air SCE30600 Slide-In Electric...
Jenn Air Range SVD48600W (Circa 1998?)
ja_question.gif Why are the oven indicator lights flashing? Answer: When power is first supplied to the appliance, a flashing time will appear on the display.
If a flashing time appears at any other time, a power failure has occurred. Press Cancel, and reset the clock if needed.
When the oven is not in use, the display shows the time of day.
If the indicator lights keep flashing after you have tried to reset the controls, then you may need to contact service person.
This is from the Jenn-Air website.
Mar 17, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-Air JES9860 burners and oven stopped working problem with display
sounds like you lost power to your stove. if you can't reset the clock, it needs to be replaced. in otherwords, the power outtage shorted out the clock.
have a technician replace it.
Jan 14, 2008 | Jenn-Air JES9860 Electric Kitchen Range
Jenn-air slide in range/convection
I put a $.12 capacitor on the display board and the display came back. capacitor in position c3, part from mouser electronics, #746-uvy1v680med
Dec 19, 2007 | Kitchen Ranges
its not a loose wire. jenn-air is famous for having to replace the display board. once you replace it it will be fine
Nov 28, 2007 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range Logo
367 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Thomas F. Schneider
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
