Question about HP LaserJet IIIp Printer
55 error service
Good day the printer warms up and shows 55 error service. the roll device that makes the paper enter works on continue . since i do not have the manual you could help with solution or tell me where to fond the manual on internet thank you
    Scholar:
  • 31 Answers
The 55 error doesn't boil down to one specific problem and most information will tell you the following: 55 ERROR (Internal Communication Problem) 1. Replace DC Controller PCA. 2. Replace Formatter PCA. 3. Replace both at same time. So sounds alot like the main board is starting into a nose dive, but seeing as that particular printer is on the older side, you might be able to find the part on the cheaper side, check out e-bay, they have some HPIII part around. Good luck.
Posted on Aug 29, 2007
SOURCE:
I changed the Label Roll in my Zebra QL 220 Plus. After I turn on the printer it prints labels continuously and on the screen it shows "Extended Two Key". How do I get rid of this problem?
Extended two key means one of the buttons by the LCD are sticking and not releasing, you use the two key sequence to print a device configuration but if you hold in the buttons for too long r they are sticking that's when you get the extended two key error.
Nov 18, 2014 | Zebra QL 220 Plus Label Printer
Loading roll paper printhead path type 1
Switch on & observe the carriage behavior for hitting right ot left frames. Clean encoder with dry cloth to avoid ink marks on it & also check for damages.. if found replace it, check..
Enter in to service mode, scroll to carriage test, enter. Check for the result, if its failed, replace it..
Entering in service mode: Power off the printer by using through front panel power switch. Hold the color key switch on the printer using power switch mounted on front panel.Wait till "initializing" appears release the button, you can observe "service test" on panel scroll to carriage test> enter.
I hope you can solve the issue..
Dec 28, 2012 | HP DesignJet 1050c plus InkJet Printer
What is 55.A Printer Error and what can I do to fix it
Dear Client! Please match the size of paper with Tray size and then print it.
Feb 10, 2012 | HP LaserJet 4050 Printer
Ink ribbon or paper roll error. the in ribbon is broken, or the paper roll is jammed. Clear the problem. I put new roll and ink cartridge in and still showing error
Happend twice to me. What sometimes happens is that the paper roll was not changed at the time the ink was. Therefore the paper roll was allowed to remain in the printer until the very last sheet. On the last sheet there is a sticker that says paper out. (stupid idea) This sticker makes the last sheet of paper too thick to fit through the last paper guide / feed. Because of this, the ink film breaks and that specific error message is displayed until that last piece of 4x6 is pulled from the paper feed. Clear that out, and all is good.. Change the paper every time u change the ink.
Jan 16, 2011 | Sony SnapLab UP-CR10L Digital Photo...
HP all in one printer 6110 Computer says printer is out of paper, but printer doesnk't show any error messages. I have unplugged it and re- set it. It does have paper! I can copy a page from the top...
Make sure you inserting the paper not deep inside just insert and stop it when you feel any resistance .and try to print something. If it is print then well otherwise you have to show it service center.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Feb 22, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Reload Paper constantly shows up
This printer is very finicky about paper loading. I see this error most commonly when using auto-cut roll paper. If the paper edge is not cut perfectly straight, and it is not inserted into the printer perfectly strait, it will give you an error. When it does this, you can simply load the paper and press "cut" instead of "pause" when it says "press pause" and it will cut the paper straight. You can also set it to "Roll Paper Manual Cut" and load the paper, then set it back to "Roll Paper Auto Cut."
Jun 30, 2009 | Epson Stylus Pro 10000 InkJet Printer
Hp 6110xi error message 'paper too narrow' caught in infinite loo
please check out the following Hp website link.... it gives a resolution for ur problem with pictures....
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=bpu00804
thank you good luck
Jun 06, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Brother HL-2040 laser printer
Make sure to clean all the rollers you can see and make sure to check the paper sensor, and clean all rollers and paper paths with some Isopropyl Alcohol (AKA rubbing alcohol)
Sep 04, 2008 | Brother HL-2040 Laser Printer
2410 Malunction
This problem always hits after a power interruption. On another site I read the solution is to open the back and roll or move the paper wheels back and forth a few times. This worked for me.
Apr 21, 2008 | HP Photosmart 2410 All-In-One InkJet...
Epson u220b printer
service for that unit - call the manufacturers tech line and they'll give u service center nfo - it it's still under 2 years - repair will be free of charge
Apr 08, 2008 | Epson TM-U220 Matrix Printer
Open Questions:
See all HP LaserJet IIIp Printer Questions
HP LaserJet IIIp Printer Logo
276 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
