Posted on Mar 20, 2009
Not reading cds
I cleand the CD player & it'll play for a short period, then it'll start skipping, then will continue to spin with no sound.
Anonymous
Level 1:
  • Contributor 20 Answers
  • Posted on Mar 20, 2009
Anonymous
Contributor
Level 1:
Answers
20
Questions
Helped
10266
Points
58
If you cleaned the lazer eye and it still has audio dropouts then you need to replace the lazer module.
1helpful
2answers
Hi ..I have Pionner PD-M701 CD Chanager .the player works so fine and recognize all cds in the trays but the issue is in the reading .
hi Sam.
you could try this.
Clean the CD if it skips or the player can't read it. Use a clean lint-free cotton cloth and make sure the CD is not scratched. Use a lens-cleaning CD in the player. If you can access the lens without opening the case, clean it with a cotton swab and lens cleaner.
Why does a CD player skip? They don't scratch as easily as vinyl LPs, but I've damaged half a dozen CDs over the years. If a CD is skipping, first give it good clean using a CD wipe or mild soap and water. Dry carefully with a lint-free cloth in a straight line from the centre to the edge. Rubbing in circles can cause more damage.
.or try this link for more info.
cd player skips Google Search
The cd player goes into a "skipping" "playing really fast" mode occasionally. Esp. 3rd track, 1st cd. Always has.
It's having trouble reading the CDs. The thing that reads it could be dirty. But try a different cd. The CD player is getting old and if there is even a small scratch it will be hard to read it. A new CD player would be the way to go
KD-HDR40 will not play any CDs, only displays a "CD reading" message.
Sounds like CD mechanism failure. Did some sticker or anything went inside? Any way, need service.
CDs skip
Hello
Ok, it sound to me that the laser lens which actually reads the cd's has some dirt particles on it.
There is a very cheap method of solving this problem.
Just go to any cd shop and buy yourself a decent laser lens cleaner disc, follow the instructions and you should be set.
Kind regards
Andrea
2answers
One more Time CD Jukebox Skipping
The fault is one or the other unit unless you have some sort of physical drag on the CD. There is a problem playing copy CDs too. Some work some dont.
Denon cd player skipping on some track/cds
This could be a possible worn laser pick-up problem.
Regards.
http://www.audiovisualservices.info/
1helpful
Numark CD MIX2 right deck skipping, sounding scratchy
Did you by any chance buy it from a b stock retailer?...send it back...also reduce your burn speed when recording cds
CDs wont play
archo69..big chance your laser is on its way out..it also can be the bottom lense is dirty to ,but this requires your stereo to be removed .dismantled and cleaned manually
In-Dash car cd player
It sounds as if you've covered about as much as you can do without pulling it out and taking to the repair shop. Something you should definitely do if all this skipping is taking place whilst the car is stationary. A lot of earlier car CD players wouldn't accept the burn it yourself type disks and perhaps the factory CD was damaged. Try a few more factory CDs before you do anything else. Just because a disk plays on the Computer or cd Player in the house doesn't mean it will behave itself in the car. If you've has the unit for a while you could have the smear of grease they put on the worm drive gummed up with dust and this is stopping the disk carriage from moving freely. Or perhaps the heads are out of alignment due to constant vibration from rough roads. Either of these problems would mean a removal and either a clean or the repair shop. BMW
 Grubhead
Grubhead
SmartAviator
SmartAviator
