Question about iLO MP3 Player
Starts to turn on, then powers right back off
My Ilo 1GB player will start to come up, it will say loading, and then just shut off. If I keep pressing the on button over and over, I can sometimes get it to go, but when it goes to switch songs or podcasts, it shuts off again. Very frustrating!!
I had the same problem and had to return it and got another. I'm know having more problems,,, going to return and get $$ back. Good luck
Posted on Aug 25, 2007
SOURCE:
Flash error ,back up data and format the player
it keeps saying format the player and back up the dta
Sep 04, 2008 | iLO (2 GB) MP3 Player
Craig mp3 1gb player cmp580d
this is a no brainer.....first thing I did was set up (formatted) the player with the disk drive utility supplied with mp3 player. Next you add in your MP3 songs. Turn on your player and with the mode button...go to MSC it will be highlighted black....then press in mode button to enter folder. Songs shouls be seen....and press power button to start.
May 15, 2008 | Audio Players & Recorders
Wat do i do if my ilo mp3 light shuts on and off but the ilo title is still on?
Reset, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
Apr 13, 2008 | iLO MP3 Player
My ilo wont load my songs
1) Disconnect from computer, turn it off, hold in volume + button and reconnect it to your computer - continue holding volume + until the Found Hardware Wizard comes up.
2)
REFORMAT FOR WINDOWS MEDIA PLAYER - Erases Everything: Connect your iLo player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "ILO 2GB" (wording may vary slightly), and then select "Format." - this should erase everything, and give you a fresh start.
Feb 11, 2008 | iLO (2 GB) MP3 Player
Random Shut Off and On
This is the worst mp3 player ever invented - i have to tell you this up front. There is no driver, the company does not support the product anymore - I would return it now while you still can.
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Nov 30, 2007 | iLO (2 GB) MP3 Player
Problem loading songs
Switch to mtp or auto mode
Nov 25, 2007 | iLO (2 GB) MP3 Player
Ilo mp3 player s/n 0770100321415 1gb with sd card slot
Sep 12, 2007 | iLO (2 GB) MP3 Player
Ilo mp3 player
On the top of the 1GB one, there's a switch to turn it from "locked" to "unlocked". This is to keep from accidentally hitting a button while listening to it.
Aug 31, 2007 | iLO (2 GB) MP3 Player
I was wondering if i could contact ilo for problems with my ilo mp3 player
I am planig to register NGO For civil rights need contact
Jun 20, 2007 | iLO MP3 Player
Starting over and over again
This very thing happened to me, it will say ILO searching updating and sorting, and it will say this over and over and over. I found out that there is a certain file called an XML DOCUMENT and it is named "WMPINFO" and i found this on my computer and copied it to my ilo 1gb mp3 player and for me it fixed my problem and i could listen to my music again. Aparently this is the file to make it run or something, if you need this file I can email it to you my email is [email protected] When you open the XML DOCUMENT with XML EDITOR it will read: -
Apr 14, 2007 | iLO MP3 Player
24 people viewed this question
Top iLO Audio Players & Recorders Experts
Ekse
Siul Oyaratgam
Inky Fingers
Inky Fingers
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
