Question about Hoover Floormate H3000 Upright Wet/Dry Vacuum
Hoover floormate problem
I can kind of wash my floor but the water has a hard time dispensing onto the floor, and when I go to dump the water, there is none. Only dust and hardly any of my water has been used. HELP!!
  • 4 more comments
  • Anonymous Jan 09, 2008
    the same problem
  • Anonymous Jan 28, 2008
    When I depress the trigger to release solution, either nothing comes out or just a trickle which is not enough to clean the floor. It vacuums up liquid fine.
  • Anonymous Feb 29, 2008
    play with the buuton in tank that dispenses solution
  • bhubbs4580 Aug 16, 2008
    My wife complains that very little of the cleaning product is dispensed. I've gone through the entire machine, and all parts are OK mechanically, but just doesn't dispense much of the solution. How can I increase the flow?
  • momurl Aug 23, 2008
    I have the same problem with m Floormate. When I pull the handle to allow the cleaner to dispense, nothing comes out. Where do I need to check the system to make sure there are no clogs?
  • Brian Ripberger
    Brian Ripberger Aug 23, 2014
    Ours quit working all together, Hoover sells junk we had this less than 6 months and the spray stopped working after 3 uses.
  • 8 Answers
I found a solution posted by someone elsewhere on this website. Try doing a search for Hoover Floormate H3000... The posted solution is as follows:
Remove the liquid dispenser and set it aside. Locate the plastic "plunger" piece in the machine that is surrounded by a black rubber circle (the one on my machine is blue/grey in color...). Place a small drop of hot glue on top of this plastic "plunger" piece and let it dry. Replace the liquid dispenser and test the machine. This solved my problem and my machine dispenses liquid properly again!
I really appreciate the original poster who posted this simple solution.
Posted on Aug 29, 2008
    Problem Solver:
  • 3 Answers
The problem with the H3000 not dispensing water may be a subject of a free recall repair. Check an authorized dealer.
As for not picking anything up, see my "No Vacuum" post here:
http://www.fixya.com/support/t329235-no_vacuum
Posted on Jan 03, 2008
SOURCE:
How do I Replace reservoir and tubing assembly on a hoover floor mate?
Hello, this is Ava with Think Crucial.
You may check the online manual for Hoover Floormate in this link: Hoover FloorMATE Hard Floor Cleaner Owner Manual Also, you may call Hoover for assistance which is 800-944-9200
You can order replacement filters for your Hoover Floormate directly to us. You can check the filters in this link: http://www.thinkcrucial.com/search?type=product&q=hoover+floormate
As a special offer here is an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
Ava B.
Think Crucial Customer Care
Oct 13, 2016 | Hoover Vacuums
New hoover floormate deluxe does not seem to be cleaning tile floor
Take it to your local Hoover warranty station. You have a one year warranty. These new machines are giving some trouble.
Feb 19, 2015 | Hoover FloorMate Deluxe Hard Floor Cleaner
How to fix clog on hoover floormate fh40010?
I was having the same issue with my NEW just out of box Hoover FH40010. First run on the floor was great then the water/cleaner stopped dispensing!!! I found that when is assembled it out of the box I did not have the handle "plugged-in" properly!! I reattached it to where there is NO gap in the handle when pushed firmly into place and locked in the base. WATER SOLUTION NOW WORKS PERFECTLY!!!
Nov 30, 2012 | Hoover FloorMate Hard Floor Cleaner -...
My hoover floormate will not dispense water
make sure check valve in the solution tank moves up freely. check that the sprayer tips are not cloged.
May 15, 2010 | Hoover Floormate H3000 Upright Wet/Dry...
Cleaning solution will not dispense
After sitting for a period of time, some of the solution may have dried in the inner walls of the feed tube from the solution tank. What I would suggest is to empty the solution tank and then fill it with hot tap water, put it back on the Floormate, and hold the solution "feed lever" on until it starts dripping water. The hot water will hopefully disolve the dried solution and allow it to flow again.
I hope this helps! :)
Sep 22, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover FloorMate won't pick water up
Check for the filter in place and it also requires a filter lid for proper suction or it will not work
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Jan 23, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Won't dispense cleaning solution
I had this same problem. There is a solution posted elsewhere on this website. Search for Hoover Floormate H3000.
The following solution is the one I tried: Remove the fluid dispensing tank and put a small dab of hot glue on the tip of the blue/greyish "plunger" piece that is located in the middle of the black rubber circle. Let the hot glue dry (this forms an extension to the plunger piece...) and replace the fluid tank.
I did this and my machine is working properly again! Whoever posted this solution was very helpful!
Aug 24, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
I used my Hoover FloorMate, SpinScrub Hard Floor Cleaner for the first time today. My intent was to clean the grout in my kitchen/family room floor. Since the water was dirty I know it cleaned the grout...
The Hoover model 800 has seperate brush assembly to do grout. The 500 model (yours) has only the one hight brushes so other means must be taken to do grout. I have a 500 and all tile floors and I'm bumbed too.
Kirk Thompson
San Juan,PR
Aug 14, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover 3010 FloorMate Plus not dispensing liquid
With the tank off, can you see if the rod in the handle is hitting the spot where the tank sits on, if not then there is a problem in the handle. If it is, then the reservior asm may be bad, it is what the tank sits on.
Jun 14, 2008 | Hoover H3030 FloorMate SpinScrub 500...
Hoover floormate plus model #H3010
It seems to be a common problem with this series of floormate... some home quickfixes (a hassle, i kno) but put downward pressure while using the solution.... Check your warranty that came with it, and how long you purchased the floormate... Alot of vaccuums come with 30-90 warranties, I'd recommend having it checked out. That, or if u bought it recent enough,take it back... like i said, these models are unfortunately known to have this problem... Some people have ones that operate normally, but alot do not. >.<
Jan 09, 2008 | Hoover H3030 FloorMate SpinScrub 500...
Hoover Floormate H3000 Upright Wet/Dry Vacuum Logo
1,281 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Kirk Thompson
Level 1 Expert
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
