Question about NEC PlasmaSync 42MP3 42 in. Television
NEC plasma TV problem
One and a half inch black vertical line on my NEC PlasmaSync 42 MP3. Possible display panel failure (From what people say on the Internet). Warranty expired. Contacted NEC support but the want £300 just to take it for repair without giving any estimate and I am not sure if I should just throw it in the bin and buy a new one.
  • 3 more comments
  • vinylbudgie Nov 06, 2007
    Mine now has 3 of these lines. NEC told me the whole panel will likely need replacing...
  • Anonymous Dec 10, 2007
    I have the same problem, i find the problem and i think it´s not possivel to repair . Only exchange the flat painel plasma .
    It is a small component pasted on flat cable that goes to the plasma and enters the glass.
    I am sorry to see something as simple without repair.
    If someone can replace that component say me [email protected]
    It is very easy to find the probelema but repair it .....
  • Anonymous Sep 25, 2008
    I have some discoloration in the middle of the screen. Also the unit turns off randomly by it's self.
  • Anonymous Nov 22, 2008
    Hi there,my 42 inch NEC plasma was switched off accidently at the mains!!and now it will not come on,the screen flickers and then shuts down.I think i saw a black line vertically from about 11/2 inches in from the left hand side before this happened!!Any Ideas???
    cheers...Chris...
  • Anonymous Jan 24, 2009
    I was playing with the functions controling the horizontal and vertical size of the picture in set up mode and shortly thereafter my screen has about a 2 inch vertical black line with a thin line of color next to the black almost in the middle of the TV screen.... I'm calling NEC on Moday, but don't have a good feeling..It is after all 7 years old... Not to mention my brand new 50' plasma was $800...I'd bet the repair on this is going to be brutal..
SOURCE:
  • 244 Answers
SOURCE: Horizontal lines on NEC plasma
Intermittent horizontal deflection
Resoldered the pins of horizontal deflection transformer
Picture is horizontally narrowed and deformed
Capacitor C2913 (390nF, 250V) on the deflector PCB had lost capacity
Geometric distortion, Pillow, and picture enlarged horizontaly
The problem was a short from GND to pin 11 inside IC301 (TDA8350Q). This pin is the output of amplifier for geometric correction signal. Replace IC301
Posted on Nov 26, 2007
SOURCE: Problem with NEC PlasmaSync 42MP1 42 inch - goes to standby w/no picture
Has anyone figured this issue out? Im really hurting without a tv,
Posted on Nov 18, 2008
SOURCE: NEC PlasmaSync 42MP2 TV Stand required
I need help to find a tabletop stand for my NEC
Posted on Apr 05, 2010
pabloloco
  • 2335 Answers
SOURCE: NEC PX-42VM3A 42" Power problem
I have read that this has been fixed with little more than a hard reset. This means just unplug your set for 10 minutes or so and let all the power seep out of the boards and capacitors, then plug it back it.
If that didn't fix it, your unit needs servicing. If you are handy here are some troubleshooting steps:
Check the fuse at Y-Sustainer pcb.
If blown do not replace. Look instead at scan converter boards. They are connected between y-sus & plugs from display (left side with face down, back open). Look for signs of 'burning' at upper and lower long boards. If any imperfections are found, replace all three boards: Y-sus, up & low scan.
If fuse was okay, check power supply for bloated capacitors (big board in middle of set).
I hope that helps.
Posted on Apr 19, 2010
budmrtn
  • 11361 Answers
SOURCE: My NEC 42 Inch plasma tv has sound but no picture.
Model number?
Please inspect the power supply, y-sustain, and Z-sustain boards for blown fuses, caps, blown parts first.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Please leave rating if it helps.
Posted on Jan 21, 2011
Black vertical line on tv.
defective vertical ic,....no supply...devective yoke.
Jul 01, 2010 | NEC PlasmaSync 42MP3 42 in. Television
My nec 42 in plasma tv has a black line coming from the bottom of the tv to the top can this be fix
double check that there is no interverance from the lead (try adiverent lead iv not check or get somwhone to check the internal connections that they are not lose or dirty other wise proceser board us
May 20, 2010 | NEC PlasmaSync 42MP2 42 in. Television
Black line in the middle of the screen
check for vertical ic it is faulty, replace and try again
May 23, 2009 | NEC PlasmaSync PX-61XM1A 61 in. Television
Thin red line in middle of screen on nec 42 inch plasma monitor
I had the same problem -red, vertical bars along the right side of my Samsung 42" Plasma- and this is what fixed it: Removed unterminated cable.
I had hooked up an HD video camera to the set about two weeks ago. While I disconnected the camera I left the other end of the connector cable plugged into the T.V.. As I've since learned from friends who work in television, this is what's called an "unterminated cable" -meaning one end is unconnected. It can lead to problems with electrical interference and appears to have been the problem in this case; When I disconnected this cable from the T.V. the red bars went away.
So, check your cables. Make sure everything is properly connected and get rid of anything that might be picking up interference.
Dec 27, 2008 | NEC PlasmaSync 42PD3 42" Monitor
Nec plasma tv 42MP4
these plasma vertical black lines are notorious. there's a video of a fix on this plasma tv repair site. good luck!
Jul 29, 2008 | Samsung PPM42S3 42 in. Plasma Television
Jun 21, 2008 | NEC PlasmaSync 42MP1 42 in. Television
NEC 42mpi plasma tv not working
Check the +170 volt  test point on the power board (not the power filter board, the one that the plug comes into) but the one to the right of that board. It has a 5v test point (TP +5v) , a +170 and a +70. I've found that the +170 transformer goes bad, and won't allow you to adjust the voltage using the pot screw.
Dec 29, 2007 | NEC PlasmaSync 42MP1 42 in. Television
A Plasma TV
Sorry forgot to say ours is an NEC plasma PX42vp4g/s
Nov 18, 2007 | NEC PlasmaSync 61MP1 61 in. Television
Nec plasmasync 4200w 3 vertical lines one yellow two purple
Sorry to tell you, it is not a scratch, but a bad cable connection from the driver IC's, connecting up the plasma screen to the drive board, or the drive IC for that section of the screen is defective. It is not a repair a user can do as there are no user replaceable parts inside this set. Your going to have to call NEC or an experienced Plasma repair shop.
Oct 07, 2006 | NEC PlasmaSync PX-42VM2A Television
NEC PlasmaSync 42MP3 42 in. Television Logo
919 people viewed this question
Top NEC Televison & Video Experts
Ekse
Kyle Steven OHare
Kyle Steven OHare
Are you a NEC Televison and Video Expert? Answer questions, earn points and help others
