Question about Rangemaster Proffessional 110 Gas Kitchen Range
Timer i changed the timer unit powered up and reset the clock great. however next day after realising i had set the clock a hour slow tried to change the time and it wont let me (this was the original problem )it keeps going to auto and the only way to clear it is turn of the power off the clock goes back to 12 o'clock
  • 869 Answers
After you set the time ,do you push the Clock button to lock your time??If you set the clock time and walk away its not holding the time ,because its waiting for you to confirm time selected.So after you set the time press the clock key pad 1 more time .Remember this, just because you bought a new clock doesnt mean its a good part.Bad parts get the best of us ,so dont think your new part is ok yet.It probably is not.
Posted on May 18, 2008
6ya staff
SOURCE:
Wolf ovens getting err message after power outage
I had a Wolf 30F wall oven with a similar problem
after power outage. It wouldnt stop beeping with error message related
to temperature control. My solution was to turn power of at circuit
panel, then reset by pressing and holding the clear button for 5
seconds.
Also note: in my case I had to close the display
before switching the panel off. When I tried to the reset process with
the panel showing, it wouldn\'t reset.
To reset other
various parts of the control panel Instructions said:
Time-of-Day Clock
Immediately after the oven is installed, set
the 12-hour clock to the current time of day. It may need to be reset
after a prolonged power failure. The clock is visible on the control
panel during all modes. If the upper oven timer is set, the clock will
not be visible in the upper oven control panel display.
SETTING CLOCK
1) Touch CLOCK.
2) Touch number pads to
set current time of day.
3) Touch CLOCK or ENTER to start
clock.
24-HOUR CLOCK
The time-of-day clock can be
changed from a 12-hour clock to a 24-hour clock. After the clock has
been set, touch TEMPERATURE for three seconds, touch CLOCK, and then
touch ENTER. Follow the same sequence to change back to the standard
12-hour clock setting.
Fahrenheit to Celsius
The
oven can be changed from Fahrenheit (°F) temperature to Celsius
(°C).
Oct 26, 2012 | Wolf Range Ovens
Find manual for woods 59028 programmable timer switch
1) Set current time:
Press reset button to clear all programs , display should flash 12:00 AM Monday
Press and hold CLOCK button.
Press Hour, minute and day buttons until current hour minute and day display.
Release Clock button.
Next step is to program the timer
Example shows how to turn on at 5PM each day and turn off at 11 PM each day.
2) Programming review: Each program requires ON time to be set, and then OFF time to be set For example you set Program1 ON 5:00PM for ALL days. And then you set Program1 OFF 11PM for ALL days. Minimum on-off set time is 1 minute.
3) Programming steps: Press PROG button until Timer 1 ON appears on display Use Hour button to set 5 PM Use MIN button to set :00 Default selects ALL days (If you want other days, press DAY button until display shows correct block of days) Press PROG button again to save Program1 ON 4) Now for Program1 OFF 5) To set Program1 Off Press PROG button until Timer 1 OFF shows in display. Use Hour button to set 11 PM Use MIN button to set :00 Default selects ALL days (If you want other days, press DAY button until display shows correct block of days) Press PROG button again to save Program1 OFF 6) Program 1ON and Program1 OFF have been set ... so press the CLOCK button to return to current time. If you want to set another program, press PROG button until Timer 2 ON displays 7) After setting programs, press Clock button so current time shows. 8) The manual shows one more thing ... if you program the timer during the hours 5-11pm, and the timer should be ON during those hours, you have to 'tell' the timer to turn ON by pressing the manual override ... after that the timer will operate normally.
Nov 21, 2011 | Woods 59028 Programmable Timer Switch...
Problem #1. On model #DT300 the instructions under Set Time of Day # 3 does not change the day. The only place I can get the day/s to change is under the programming. What is wrong with it. I have...
Thank you for very clear question, and timer identification.
1) I don't have repair for defective timer.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#DT300
http://waterheatertimer.org/pdf/DT300-series-manual.pdf
2) Choose DT300 format
#3 says to press-and-hold CLOCK button until display shows 24H or 12H
Then release CLOCK button.
Next press HOUR button to select either 12H or 24H
This lets you choose am-pm format -or- choose military-time format where 11pm is 23
3) Set current time
Press-and-hold CLOCK button throughout whole current time setting.
Do not release CLOCK button until current time settings are finished.
Next, press HOUR button, and then MINUTE button, and then DAYS button until current hour, minute and day display.
If this step does not work, then timer has gone bad.
Replace with locally available Utilitec 155671 from Lowes or Westek TE06WHB from Target
http://waterheatertimer.org/Woods-timers-and-manuals.html#59377
4) How to set DT300 timer program for full week of operation.
Each program requires you to set program 1 ON time and program 1 OFF time
Be careful to avoid program conflicts and overlaps so timer works as expected.
For program 1 ON time, you press PROGRAM button until 1 and ON display.
Release Program button.
Then select hour, minute and days. In this case you want all days of week, so you keep pressing DAYs button until whole week displays: Mo Tu We Th Fr Sa Su
Then you set program 1 OFF time, you press PROGRAM button again until 1 and OFF display.
If you set ON time for all days of week, and OFF time for Tu Tuesday, then timer will not work correctly.
5) Read manual and add a comment for additional help
Aug 18, 2011 | Hardware & Accessories
I have a IIIWoods timer #59203WV and have trouble programming it to turn on and off exterior lights. Thanks for your response.
Manual:
http://waterheatertimer.org/pdf/Woods-59203.pdf
59203 plug-in timer: your outdoor lights have to plug into side of timer.
If you want a timer to replace outdoor light switch: buy in-wall timer Aube T1032 or Lowes sells Utilitec 0192773.
http://waterheatertimer.org/Programmable.html#Aube
Add a comment for more help with in-wall.
Here are instructions for 59203 plug-in timer:
Plug in the timer until battery is charged.
Unplug timer so you can program easily.
Press R reset button with paper clip to clear.
Set the time of day:
Press and hold clock button
Press hour button until current hour shows
Press minute button until current minute shows
Press day button until current day shows.
Release clock button
Program review:
Write out ON-off schedule showing hours minutes and days
For example: timer turns ON 6:00 pm all days of week.
Timer turns OFF 1:00 am all days of week.
First step: Set program1 ON > hour, minute, and day.
Next step: Set program1 OFF > hour, minute, and day
If needed, go to next step: Set program2 ON > hour, minute, and day
Next: Set program2 OFF > hour, minute, and day
How to program timer for ON at 6:00 pm and OFF at 1:00 am all days of week:
Step 1: Press PROGRAM button until display shows 1 ON (this is program1 ON)
Press hour button until 6 pm shows
Press minute button until :00 shows
Press day button until all days of week show (MO TU WE TH FR SA SU)
Step 2: Press PROGRAM button until display shows 1 OFF (this is program1 OFF)
Press hour button until 1 am shows
If you want to set another program, you will repeat same steps for program2
Press PROGRAM button until display shows 2 ON
If you are done programming, press clock button
Press ON/AUTO/OFF button until AUTO displays
Nov 13, 2010 | Woods INDUSTRIES 83660 OUTDOOR SECURITY...
We have a Utilitech timer and can't program to come on or off Please advise...
I bought a Utilitech 2-outlet timer #0155671 last year and have lost the instructions. I was playing around with it today, trying to program it. My screen was blank because it had sat dormant over the last year. This can be remedied by plugging the unit in to recharge the internal battery and pushing the reset button on the front.
Here'e how I programmed the unit. To set the day/time; press and hold the "clock" button then press the "day" button once to advance the arrow at the top of the digital screen to the correct day. Continue to hold the "clock" button while pressing the "hours" button to cycle to the appropriate time. The AM / PM indicator changes automatically as you cycle through the hours. Do the same thing for the "min" button to set the appropriate minute.
It appears that there are 9 different on/off times that can be set in the unit. The timer number is in the lower left corner of the digital screen. Each time one pushes the "prog" button a separate "on" time, then "off" time is selected for each of the 9 instances. Press "prog" to select the desired timer instance (either an "on" of an "off"). Press the 'Day" button to toggle through several different day settings. These are specified by arrows under different days at the top of the digital screen. Then press the "hours" button to select the appropriate hour and the "min" button to select the appropriate minute. Press "prog" again and the "off" instance for that timer setting is selected. Use the hour and min buttons to set off times. Pressing the "Prog" button again will select the next on/off timer instance for programming.
Hopefully you can follow these rudimentary, somewhat confusing instructions.
Nov 10, 2010 | Computers & Internet
How do I set the current time on the Woods Digital Timer Model#59203?
78a8604.jpgWoods 59301
Manual for 59301
Plug timer in wall for 1-2 hours so rechargeable battery charges
If display does not show after 1-2 hours, the battery is dead and timer is no good
After 1-2 hours, you can remove timer from wall to program
Press reset (R) with paper clip to clear memory
Select format: Press and hold Clock button until 12 hour or 24 hour shows on display, then release
Press hour button to change display to 12H
press Clock button and display returns to normal
AM shows in upper left corner
Set current time:
Press and HOLD clock button
While holding clock button, press hour button and minute button until display shows current time
Press and HOLD days button until current day shows in display
Release days button
Further instructions to set ON-OFF times are in manual (click link shown above for manual)
If you have problems, re-post additional question.
Oct 17, 2010 | Woods Indoor 24 Hour Digital Timer (59203)
How to set oven timer on a GE electric stove
that is not a problem. I copied the instructions straight from the manual which you can also review by clicking here.
Using the clock and timer.
To Set the Clock The clock must be set to the correct time of day for the automatic oven timing functions to work properly. The time of day cannot be changed during a timed baking or self-cleaning cycle. Press the CLOCK pad. Press the HOUR and MIN + or – pads to set the time of day. Press the START pad. Make sure the clock is set to the correct time of day. To Set the Timer Press the KITCHEN TIMER ON/OFF pad. Press the HOUR and MIN + or – pads until the amount of time you want shows in the display. The maximum time you can enter in minutes is 59. Cooking times more than 59 minutes should be changed to hours and minutes. For example, enter 90 minutes as 1 hour, 30 minutes. If you make a mistake, press KITCHEN TIMER ON/OFF and begin again. Press the START pad. After pressing the START pad, SET disappears; this tells you the time is counting down, although the display does not change until one minute has passed. Seconds will not be shown in the display until the last minute is counting down. When the timer reaches :00, the control will beep 3 times followed by one beep every 6 seconds until the KITCHEN TIMER ON/OFF pad is pressed. The 6-second tone can be canceled by following the steps in the Special features of your oven control section under Tones at the End of a Timed Cycle. The timer is a minute timer only. The timer does not control oven operations. The maximum setting on the timer is 9 hours and 59 minutes. To Reset the Timer If the display is still showing the time remaining, you may change it by pressing the KITCHEN TIMER ON/OFF pad, then press the HOUR and MIN + or – pads until the time you want appears in the display. If the remaining time is not in the display (clock, delay start or cooking time are in the display), recall the remaining time by pressing the KITCHEN TIMER ON/OFF pad and then pressing the HOUR and MIN + or – pads to enter the new time you want. To Cancel the Timer Press KITCHEN TIMER ON/OFF pad twice.
If you need further assistance follow up with a comment and please let me know and i will be glad to assist you further. Thanks, Midwest-tek
Aug 28, 2010 | GE JTP20 Electric Single Oven
Where can I download instructions for utilitech timer
UTILITECH - Grounded in Quality
Digital 2-Outlet Timer (TE06WHBL)
Instruction Manual & Warranty
Before using your timer please read the following instructions carefully.
FEATURES
- Up to 8 ON/OFF events per day/56 ON/OFF events per week
- Option to program individual days or 8 different weekday groups
- Minimum switching period one minute
- Summertime/wintertime change over
- Easy to read LCD display
- Random automatic ON/OFF security feature
- Countdown feature
- Manual override button
- Rechargeable battery back-up (if there is no LCD display, plug
timer into a wall receptacle, this will recharge the battery)
SETTING TIME
Press and hold CLOCK key, then press DAY key to select correct day,
HOUR key to select correct hour, and MIN key to select minutes. When
MIN key is released, time will be set with seconds starting from 0.
Either holding down or repeatedly pressing appropriate button can
advance days, hours and minutes.
Do not set ON and OFF for same time.
PROGRAMMING EVENTS
The timer has the capacity for 8 ON/OFF events per day.
Save program capacity by using available blocks of days.
Blocks of days are:
1. M,T,W,Th,F,S,Su
2. Individual days of the week
3. M,T,W,Th,F
4. S,Su
5. M,T,W,Th,F,S
6. M,W,F
7. T,Th,S
8. M,T,W
9. Th,F,S
For each ON time and each OFF time--DAY, HOURS and MIN must
be set. Press PROG key onceto set first ON time--"ON" and number
"1" appear to left of LCD display indicating to enter first ON time.
Press DAY button to choose required day or blocks of days, then set
hour and minutes using HOURS and MIN buttons. After setting required
ON time, press PROG button to validate entry and move onto first
OFF time--"OFF" and number "1" appear to left of LCD display
indicating to enter first OFF time by using DAY, HOURS and MIN
buttons as above. Press PROG button to validate this entry. Repeat
remaining 7 ON/OFF settings as required. After setting required
ON/OFF settings, press CLOCK button to return display to clock. Timer
is now ready to operate. Check programmed settings by pressing
PROG button repeatedly--each setting will appear on screen.
MANUAL OVERRIDE
To choose permanent Manual ON, permanent Manual OFF,
Auto ON or Auto OFF, press Manual button. Each mode will be
displayed on screen. When choosing Auto ON, timer turns ON until
next programmed OFF time. The programmed settings will only work
on Auto mode. When Auto mode OFF is chosen, timer is OFF until
next programmed activity. (Inverted black triangle on LCD points
to either AUTO or MANUAL indicating which is selected)
COUNT DOWN FEATURE
To enter count down feature, press CLOCK and PROG buttons
simultaneously. Using HOURS and MIN buttons, set count down time.
(Maximum selection is 9 hours 59 minutes, minimum is 1 minute.)
Press MANUAL button to start countdown. Output will turn ON until
end of count down. Count down may be paused at any time during
period by pressing MANUAL button. To re-start, press MANUAL button
again. To review time during count down period, press and hold
CLOCK button. Release CLOCK button to return to count down display.
Note: To return to timer mode, press CLOCK and PROG buttons
simultaneously.
RANDOM AUTOMATIC ON/OFF SECURITY FEATURE
With this option selected, timer will switch ON and OFF in a random
pattern at least once in every 8 hours. (This may mean timer will
switch OFF within a set ON period, or vice versa.) Ideal for use with
a light--switching it ON and OFF automatically gives appearance of an
occupied home, but not at exactly the same time every day. To enter
Random mode, press DAY and HOURS buttons simultaneously.
An "R" will appear on display and unit will start random switching.
If no programmed times are set, timer will switch ON or OFF
approximately 1 minute after entering Random mode, then continue
randomly. To turn Random mode OFF, press DAY and HOURS buttons
together again.
SWITCH OVER SUMMERTIME/WINTERTIME ZONE CHANGE
To change from wintertime to summertime, press HOURS and MIN
buttons simultaneously. Clock will be set forward one hour and
"S" will appear on display. Repeat same procedure to return to
wintertime.
Note: if unit is purchased during summer, set clock time for one hour
less than correct time, select Auto mode and press HOUR and MIN
keys simultaneously. The unit will then adjust to correct summertime
and "S" will appear on LCD.
RESET
To reset unit for time and programmed ON/OFF settings,
press RESET button.
IMPORTANT SAFETY PRECAUTIONS and
RATINGS
[Contact the manufacturer; I've already wasted too much time typing
this in:
AmerTac
Saddle River Executive Centre,
One Route 17 South, Saddle River, NJ 07458
800-777-0802
www.amertac.com
Made in China
May 05, 2010 | Kitchen Appliances - Others
Need to reset time ,day and date
Setting the Clock
You’ll need to set the clock so that it can
announce the day and time that each
message is received. Press Play/stop to exit
Setting the Clock at any time.
1 Press and hold Clock until the
Message Window displays C, and the
default day is announced.
2 To change the day setting, hold down memo/repeat
or ANNC/Skip until the
correct day is announced. Then
release the button.
3 Press and release Clock. The current
hour setting is announced.
4 To change the hour setting, hold down memo/repeat
correct hour is announced. Then
release the button.
5 Press and release Clock. The current
minutes setting is announced.
6 To change the minutes setting, hold
down memo/repeat or ANNC/skip until the
correct minutes setting is announced.
Then release the button.
7 Press and release C. The new day
and time are announced.
To check the clock, press and release
Clock.
NOTE: In the event of a power failure,
see the instructions on the bottom of the
unit to reset the clock.
Record a memo /
Repeat all or part of a message
I hope this helps! here is the URL to the information provided
http://telephones.att.com/docMgt/public/art/162/1717_manual.pdf
Feb 09, 2009 | AT&T 1717 Digital Answering Machine
Clock
Turn the system on and press the "Clock/Timer" button (located above the eject button for Deck 1). The clock will appear. To change the time, simply hold down either the < or > buttons (the ones you use to change radio stations and begin CD/tape playback). Press "Clock/Timer" again to lock in the time.
Dec 28, 2007 | RCA RS2622 CD Shelf System
Rangemaster Proffessional 110 Gas Kitchen Range Logo
406 people viewed this question
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Thomas F. Schneider
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
