Konica Minolta magicolor 2300DL Laser Printer
Problem for Konica Minolta magicolor 2300DL Laser Printer
Prints from CS3 Photoshop like a streched plastic
By chrisam1 on Mar 20, 2009
When I try to print from Photoshop CS3 it prints like a piece of plastic paper which you pull stretched. It shows it stretched in Print Preview and prints it same. I have tried Vista and XP, same results. Same program and files print fine with any other printer. I have latest Vista driver from Minolta.
Same Problem
May 16, 2009
-   I'm having the same problem and I have a 2500W. What I have to do to get around is to create a new file in photoshop with 8.5x11 size and then copy the image layer to the new file and blow it up. When printing, I have to print to PDF first and then from PDF to 2500W. It's such a hassel. I've tried so many ways to just print from my original image in photoshop but was unsuccessful, wasted soo many papers too! -   Guest
May 09, 2009
-   From photoshop I get a streched out photo that don't come close to fiting the paper. Select any other printer and it is fine. save the photo and print it with any other program and it is fine.-   Guest
Apr 08, 2009
-   i ahve this same problem with a konica magicolor 2400w -   Guest
Solution #1
posted on Nov 03, 2009
Not Rated)
test170
Rank: Apprentice
Rating: 0%, 0 votes
switch the resultion to 600*600 and all is fine.
Was this helpful?
Yes
No
Popular Solutions for Konica Minolta magicolor
Questions and Unsolved Problems for Konica Minolta magicolor
Do you recommend Konica Minolta magicolor 2300DL Laser Printer?
Answer
Answer
Just replaced the drum because I was getting vertical striping on the left side and I'm still... (More)
Answer
What appears bright blue on the screen is coming out a purple sort of colour on the paper. Any... (More)
Answer
Setup completed but which port should be used? Using windows XP Original user was directly connected... (More)
Answer
need driver of magicolor 2300dl to computer 64 process
Answer
black (and sometimes yellow) bar on print page 1 following a label getting stuck in machine
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Konica Minolta magicolor...:
Top Printer Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
