Home | Nikon | COOLPRINT Thermal Printer | USB PORT
Nikon COOLPRINT Thermal Printer
Problem for Nikon COOLPRINT Thermal Printer
USB PORT
By misled143 on Mar 20, 2009
i plug in my ipod into my usb and i keep getting this message.
THE USB DEVICE PERFORM FASTER IF YOU CONNECT IT TO A HI-SPEED USB 2.0 PORT.
Sponsored Links
Solution #1
posted on Mar 20, 2009
Not Rated)
createit
Rank: Wiz
Rating: 89%, 10 votes
Hi, This is nothing to worry about. All it is saying is that you a plugging it in to an older version of usb (usb 1.0) and it would transfer data faster if it was plugged in to a newer port.
http://wiki.answers.com/Q/What_is_difference_between_usb_1.1_and_usb_2.0
I hope this helps, if so, don't forget to rate the answer.
Was this helpful?
Yes
No
Solution #2
Not Rated)
vincent721
Rank: Wiz
Rating: 82%, 184 votes
if u plug in directly u need to update your BIOS and chipset driver.
if you plug it to USB hub..u need a USB with power adapter to make your USB hub 2.0
update your windows too
Was this helpful?
Yes
No
Popular Solutions for Nikon COOLPRINT Thermal
Questions and Unsolved Problems for Nikon COOLPRINT Thermal
Do you recommend Nikon COOLPRINT Thermal Printer?
Answer
Answer
it says i have to download a high speed usb controller for my wireless usb adapter for it to be... (More)
Answer
On IMac OS 10.4 The printer gave me the choice of printing both sides. On )S 10.6 that choice has... (More)
Answer
Canon PIXMA MP 780 paper jam error message at ejection slot remains after paper jam removed. INITIAL... (More)
Answer
Canon MP 780 paper jam error message at ejection slot remains after paper jam removed. INITIAL... (More)
Answer
when i try sending fax it says low memory on display and the fax doesn't go through it stops.-- low... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Nikon COOLPRINT Thermal...:
Top Printer Experts
Rank: Guru Guru
Solutions: 1417
Experience: Self taught, Keep up with the manufacturer's service manuals, Beta Tester
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
