I might be able to help you, but it's important to know the model and
make of the computer because some models are known for certain issues
(Example: Dell Latitude D620 is known for having graphics chip that burn
out after about three years
) You need to tell us the make (Dell,
Emachine, Toshiba, Fujitsu, etc) and the model number (Example: D620,
T4920 etc) So get us that info and mayhaps we can help you <:0)
SOURCE: DV9005US - No post All leds on No beeps
There is a recall on this model for this problem through HP.
SOURCE: Blank screen, led lights on, intermittent beeps
sounds to me like the battery may be at the end of it's useful life..usually around 2 to 3 years..
SOURCE: At power on I get no display (black Screen),
my dear you need to update bios that is right and easy way no need to unscrew or anything else............
SOURCE: Screen is totally blank at startup. HDD light
1. Test using an external monitor. If it works, then either the screen bulb or the inverter board might be defective.
2. Test the inverter. Easiest way to do it if you have a good screen with a good bulb. Connect the good screen to the inverter board & test it. If it lights up, then the inverter board is good. If it did not, then the inverter board is bad & needs to be replaced.
3. If the inverter board is good, then we are left with the possibility that the screen bulb is bad. To fix this, we will need to replace the LCD screen.
SOURCE: samsung r480 turn on blank screen
Does anything ever post to the screen when your turn the laptop on? If not, your video card on the motherboard might be the issue.
Since you mention that the hdd led does not light up, is the hard drive good?
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous. Most times the problemis with the memory or Video Card. Count the Blinking Lights or Beeps and takenote of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.
If you removed or put in the CPU and the Heat Sink did you put a fresh coat of Thermal Paste on them? If not that is like metal touching metal and it will short out when you try to boot up.
The other problem might be that either one of your memory chips is bad or one of the slots on the board that holds the memory is bad.
Maybe your memory is bad or the memory slot is bad.Remove the Power Cord, Remove the Battery, Remove the cover that houses the memory on the bottom of the laptop then remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
