Question about Dell OptiPlex GX260 PC Desktop
Gx260 pc wont start
When powered up there is a flashing orange light on motherboard, no fan running, or any operation at all on cd etc. checked with standard power supply and still same. could it be cpu fan? orange light also flashing in centre of on/off switch
  • workloads Aug 18, 2007
    all checked.
    no light on post.
    will have to try new power supply.
I had just removed dust from the fans on my Dell Optiplex GX260 desktop power supply and processor. I started the PC and it worked fine. I now replaced the the hard disk and suddenly an orange light appeared on the motherboard. Since then the PC has refused to start, and the orange light comes on whenever the system is connected to the power source. HELP!
Posted on Sep 23, 2008
Either the motherboard or power supply are bad. I've had both be the cause of the problem. Check the motherboard for bulging and discolored capacitors. The same can be true of the power supply.
To the guy above who said his were out of warranty. If the motherboard is the cause of the problem, Dell will replace it until near the end of January. Just call them up and try to convince them. We are an educational customer, but everyone should be able to get it. It's a known defect.
Posted on Dec 18, 2007
Needs new motherboard. I had a batch of eight machines. Replace 5 with new MBs. Rest are now out of warranty - ;-(
Posted on Nov 28, 2007
Power supply is bad
Posted on Nov 09, 2007
  • sachin hatagale
    sachin hatagale Jul 07, 2014
    change smps ......if same problem occurs........then add jumper near 'PSWD'
Did you check the Power Volts At the back of the system? you will find one red colored power switch 220/120. If its on 220, and you plugged in 110 power then you will get that light. Regards
Posted on Aug 18, 2007
    Scholar:
  • 181 Answers
Have you checked the post lights located in the back of the system by where the keyboard plugs in? There are is a row of 4 lights; either yellow or green. If the systems gets stuck at a particular post location, the lights will tell where. Good luck
Posted on Aug 16, 2007
  • asarebright1 Oct 20, 2011
    i have similar problem with the light 'b'changed from green to orange..'b'light stands for what?
Jvc x3 projector orange lamp light flashes wont power up
1,Check the fans ,if the fan is running
2,Inductor (Sensing element),near the Color Wheel. Use a cotton swab moistened with alcohol to wipe the Inductor.
Have a good day!
We supply original projector parts: lamp, bulb, Lcd, Lens, DMD,
motherboard, powersupply ... with high quality and competitive price.
Jerry China
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
YM: lampdeng@yahoo.com
http://facebook.com/lampdeng
http://www.lampdeng.com
Nov 02, 2013 | JVC Dla X3 3d Projector
My Dell Optiplex gx260 Pentium 4 Flat CPU doesn't Display anything, and Power light is Orange.. Please help me out
You say the power light is orange--I'm assuming that you mean the monitor.
This indicates the monitor is not receiving a signal from the computer.
Assuming that the computer actually powers up (fan runs, you can hear the hard drive being accessed, etc) then your problem lies in the video card.
If, on startup, you do see the BIOS info and maybe even the Windows splash screen before your monitor goes dark, then the problem lies in the video card drivers. In this case, starting in safe mode will work and allow you to download and install new drivers.
Aug 27, 2011 | Dell OptiPlex GX260 PC Desktop
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
I have dell optiplex gx260 when i power it on its not respond and the fans not work only the light of power switch is being orange its flash, that it being on then off continously. please help me...
First test your PSU or replace it then test all leads that are attached to your hard drive sounds like a faulty lead of some sorts then
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive or
replace them they are probably old and faulty ?
good luck
Sep 06, 2010 | Dell OptiPlex GX260 PC Desktop
Optiplex gx 260 steady amber light - done all things on dell website - still doesnt turn on. got a new PSU and it still has the same problem. theres a whirring sound which is the fan and the power supply...
Steady Amber Power LED generally indicative of a failed MB. Remove all Memory, Expansion Cards, peripheral items, if still same, replace the motherboard. If you get a Green LED with jusr RAM in system, then an expansion card or peripheral might be the issue. 95% sure it is mothebroard
Sep 15, 2009 | Dell OptiPlex GX260 PC Desktop
Orange power switch light Dell Gx260
Gx260-Gx280 have a known issue with the motherboard capaciators. Take a look at the capaciators on the motherboard and check if any look like they have bludges at the top particularly around the memory banks. If any of them look like this the motherboard most likely needs to be replaced.
Dec 29, 2008 | Dell OptiPlex GX260 PC Desktop
Dell PC Desktop Optiplex GX260 Doesn't boot
Open up the case and remove any add in cards and memory modules. Try to start up by adding these back one at a time until the unit stops booting normally. The light combination is not one recognised in the user manual so I am guessing you have a non-descript fault with one of your components. Be careful when you open the case as to not disturb the ribbon to the motherboard which controls the power, I have had a very long experience trying to get one of these reconnected!
Dec 15, 2008 | Dell OptiPlex GX260 PC Desktop
Orange Light permanently on motherboard. PC won't start
1. motherboards for atx form factor pc's are powered even when the computer is off, particularly if you leave the computer plugged in to wall outlet... you better do not work on you computer while power cable is still connected to both, your pc and the wall outlet..
2. I found this thread that may be helpful, it may be the motherboard may have gone bad, cmos is corrupted or something may not be seated properly...it could also be one of these: Bad CPU, BAD ram, Bad power supply.. read the thread for details:
http://www.dellcommunity.com/supportforums/board/message?board.id=oplex_other&message.id=23925&c=us&l=en&cs=&s=gen
Sep 24, 2008 | Dell OptiPlex GX260 PC Desktop
If all you did was change hard drive
I suspect the hard drive has been installed wrong
Ensure blue or red stripe goes to the number 1 pin on M/board and the stripe goes next to the 4 pin power supply on hard drive
Sep 23, 2008 | Computers & Internet
Optiplex GX260 won't boot
I had the same issue and accidentally discovered a temporary solution. Unplug the power from the back of the machine, open the case and unplug the ATX power connection from the motherboard. With the ATX cable unplugged, plug the power cord back in. When you try to turn the computer back on the power light should turn orange and fans should be spinning, with it powered on plug the ATX connector back in. That should turn the computer off. Turn it back on and it should boot fine. You can even shutdown and restart, but when the power is unplugged you will have to go thru the same process to get it back up. This sounds crazy but it worked on mine. Good Luck!
Nov 01, 2007 | Dell OptiPlex GX260 PC Desktop
Dell OptiPlex GX260 PC Desktop Logo
1,060 people viewed this question
Clive
Clive
Alun Cox
