posted by scrapnmama on Aug 16, 2007
I have nothing but troubles with this computer. I have run a Regcure on it several times and it has fixed errors usually about 130 each day but now I have 2 new problems (1) I am getting this new error message that says Microsoft.NET Framework when I click on details it says something about (JlT)debugging. (2) I dont know if it is realated or not but now when I open my microsoft outlook my address book is gone and all emails come in with no address. Please help before I throw this out the window!
Best Solution
posted on Sep 28, 2007
Restore your PC to any previous well worked configuration, by going to
Start->All programs->accessories->system tools
->backup
If this wont work you repair your windows by repair option by entering OS cd.
->backup
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Aug 16, 2007
Please be careful when running any sort of tools on the registry. Since almost everything in windows has a registry entry you MUST be very carefull when doing anything to the registry.
IMPORTENT : Back-up the registry BEFORE doing anything to it.
The problems you are having right now COULD be because of changes made to the registry. It is hard to know because you didn't post EXACTLY what the error messages were.
I can only guess what happened:
1) Possibly references to .net driver paths where re-written or deleted, A re-install of windows .net should fix this problem.
2) The path to your outlook inbox files could have been rewritten and/or possibly deleted. If you cannot find the path to these files (if they are still there) and enter that path in to the registry, then you have probably lost your local copy of your saved email.
In that case there is no fix.
My recommendations:
1) Always back-up, back-up, and back-up some more (you never know when something will go wrong)
2) Always take note of the exact error messages the computer gives you. It is THE only solution to any problem.
Also to save you panicking, most of the registry entries regcure reports on (as with ALL registry repair tools) are NOT a problem. MOST of these entries are MRU entries (recent files applications remember), missing shortcuts, directory's and the like, nothing of which will harm your computer. You really only need to run a registry cleaner once every few months.
My recommendations:
Suggest a new solution for this problem
Post a New problem for Microsoft Network Programming for
Email this problem
Email this problem
Can you Help with these Education and Reference Software problems?
Repair Service
Find Education and Ref. Repairman Near You:
